13th July 2013, 20:21 | #281 | Link |
Alright, well tried it, with some modifications, and well went pretty much the same as before.
Took along time to compile though. And well, it became less in size, guess thanks to no vp8. But damn, i still get the artifact problem. 4 frames work, then the rest is just blended colors in a mess:S |
13th July 2013, 20:40 | #282 | Link |
Problably a latest commit broke something.
If you want to build an old version you can do a : git checkout <HASH> for <HASH> you need to know the commit hash look here http://git.chromium.org/gitweb/?p=webm/libvpx.git under commit (h=XXX) or git checkout HEAD~<number> for example HEAD~20 gives you an old version of 20 commits back |
13th July 2013, 21:57 | #283 | Link | |
You can see which pass it's on when it's encoding as it is displayed with the current frame: Pass 1/2 frame x ... Pass 2/2 frame x |
14th July 2013, 09:21 | #284 | Link | |
Probably, if someone could test the latest commit, just encode like 10 frames, and watch it with chrome (you can watch while encoding, though itīs FPS isnīt correct so it plays to fast, but you see the artifacts anyway).
14th July 2013, 16:11 | #285 | Link | |
And in this 'mode' the statistics which would normally be stored in a file (-fpf=<file>) during the first pass is instead stored in allocated memory and from there used in the automatically started second pass. If you specify a pass using '--pass N' however, it will exit after each pass and store the statistics in the file you specify using '--fpf=<file>', just the way it works in x264 for example. I also verified this by encoding a clip using only '--passes=2' and then the same clip using '--pass=1' followed by '--pass=2' and the webm files created where bit identical (confirmed by md5sum). So in other words, if you have no interest/use of the statistical data generated, you can supply only '--passes=2' (without --pass N) and it will automatically do the two passes after eachother with no manual intervention. |
17th July 2013, 00:05 | #286 | Link |
It seems like what you are saying is true.
Saves a line of code;P But is anyone able to encode with vp9? I still get the artifacts. It seems weird that it still hasnīt been solved, i am starting to suspect something on my side. |
17th July 2013, 00:53 | #287 | Link | |
Given that I have no problems and I am using vpxdec to losslessly decode the vp9 video to watch it rather than use Chrome which you've stated you are using, I dare say that the problem lies with your version of Chrome not being compatible with the vp9 stream generated by the latest vpxenc builds and that this is what is causing problems for you during playback. |
17th July 2013, 01:40 | #291 | Link |
Hmm... maybe they aren't that gung-ho about keeping the bitstream compability in the middle of development and will instead fix it in time for a final release?
I don't use Chrome so I don't have it installed and thus haven't tried it with VP9, but decoding the vp9 streams with vpxdec works perfectly fine for me. edit: missed that you added a vp9 file, it decoded just fine and I then encoded it using x264 and it played fine aswell when I watched it. steps I took if you are interested: vpxdec --i420 -o i420.mkv dead.webm x264 --crf 0 --input-res 1920x1080 i420.mkv -output h264.mkv Last edited by BadFrame; 17th July 2013 at 01:59. |
17th July 2013, 23:22 | #296 | Link | |
http://portableapps.com/apps/interne...hrome_portable Scroll down for the beta versions. The only thing missing is the auto-updater service, which depending on the person may actually be a good thing. |
18th July 2013, 18:15 | #297 | Link |
BTW, some news from Opus codec.
Opus 1.1 beta. A new WebM audio codec (Opus+VP9) |
19th July 2013, 02:04 | #298 | Link | |
Angel of Night
If vendors don't move quickly on HEVC, VP9 may well steal their thunder for a few years. |
20th July 2013, 15:27 | #299 | Link |
I doubt that. It's Google who will be moving slowly (as with VP8), because they will probably again be the sole provider of VP9 encoders.
On the other hand, handful companies already announced or even offer H.265 encoders, and the competition is bound to push quality and speed of them up. Basically, it's open environment (somebody might find it paradoxical, but the MPEG stuff really is open in all ways but the royalty requirement). |
20th July 2013, 19:53 | #300 | Link | |
I still think you are right as far as the actual result though, given that Google gives away a free fully open source codec which is the 'standard', I think there's very little commercial opportunity to compete. Compare that to HEVC where it's unlikely to be any quality open source and free offering until the x264 devs get a mature h265 encoder out (go guys go! ), that situation leaves a lot of room for commercial closed source h265 encoders. |
google, ngov, vp8, vp9, vpx, webm |
