29th May 2008, 00:56 | #2202 | Link | |
btw, no chance to play dts on the ps3? Last edited by kreegee; 29th May 2008 at 01:13. |
29th May 2008, 13:54 | #2204 | Link |
Still using this fine piece of software, many thanks to 3r1c!
A couple of GUI feature requests that would make using it so much simpler... Please could there be an option for the Browse Destination button to have default actions? For example 3 choices a) Browse from dekstop (as it is now); b) Browse from previous destination (as the Input browse button does) and c) Browse to input folder. Please could the input file box accept drag and drop? Maybe also the queue window could accept drag and drop too, in this case the default destination folder could be a choice of a user-defined default or the source folder. Finally including a "watch folder" could be useful - this could allow finished torrents to be automatically remuxed. Thanks again! |
29th May 2008, 14:41 | #2205 | Link |
I would like to know why the files get always bigger them the original one ? I`m using video transcoding (automatic) and transcoding codec mpeg-2, and I have a lot of movie with like 8.4GB 1080p that fits on a dvd DL and them with mkv2vob it is not possible. Why is that ? |
29th May 2008, 16:21 | #2206 | Link |
FYI: Someone made a certain NYC monster movie in 720p Blu-ray standalone compliant. They included a file called mkv2bluray that converts the file so that it can be burned and played on a PS3 or other Blu-ray player. I wish more movies were done this way.
29th May 2008, 17:56 | #2207 | Link | |
If i open the mkv in question into Mediainfo it states it is AC3 2.0 channel audio, but when I play the actual file back within KMPlayer/Zoomplayer AC3Filter shows input from all channels. After mkv2vob had finished with the mkv, if I open this into Mediainfo again it also states 2 channels AC3 but upon playback AC3Filter is showing input from all channels. How do I fix the AC3 audio manually? I have found h264info to be faster changing 5.1 profile material to 4.1 than mkv2vob but I cannot but it all back together because of the AC3 problem. |
29th May 2008, 19:21 | #2208 | Link |
There is a bug in tsmuxer that causes it not to accept certain ac3 streams.
I reported it months ago but the author seems uninterested in fixing it. I have done my best to try to work around it with the "repairing ac3" step, but there is not much more i can do. |
29th May 2008, 20:51 | #2209 | Link |
Ah well, even when I copied the repaired ac3 file from mkv2vob it still did not accept the stream. The main reason I wanted to try was to see if h264info had worked when I changed its profile because it was alot quicker than the transcoding which took place in mkv2vob.
Is there anyway to know prior to putting it into mkv2vob that it will require a full transcode? |
29th May 2008, 20:59 | #2210 | Link |
No other way will work if mkv2vob wants to transcode the file.
Transcoding is a last resort measure, if there was another way mkv2vob would be using it already. Im trying to fix this ac3 problem now. The problem is the ac3 files are at least partially corrupted. Either they are 6ch with a header that says they are 2ch, or they are 2ch with a header that says 6ch. I dont really know how to tell the difference. Please explain what you mean by "shows input" do you mean it says 6ch on the screen, or there is actually audio coming out of all speakers? Last edited by 3r1c; 29th May 2008 at 21:02. |
29th May 2008, 21:09 | #2211 | Link | |
What I mean is, opening the file in Mediainfo shows that the audio is a 2-channel AC3 but when the file is actually playing, within Zoomplayer for example, and I open the AC3filter dialog it shows there is sound on all channels on input and output. |
29th May 2008, 21:14 | #2212 | Link |
When encoding make sure to use level 4.1.
See here http://www.avsforum.com/avs-vb/showthread.php?t=972503 I see the mediainfo 2ch and player says 6ch. The problem is i do not know yet which one is right. There seems to be only 2 "usable" channels, any attempt i have made to extract all channels has failed, or gave me 6ch with 4 of them being complete silence. My thinking so far is that these are 2ch files, where the broadcaster added fake channels for their decoding equipment which only supports 6ch. I do not have surround sound in my pc only on ps3/tv and because i cant get the stream playable on ps3 i dont know what the problem is. What im asking you is if you can check that sound is actually coming out of all your speakers when playing the original mkv file. |
29th May 2008, 21:20 | #2213 | Link | |
29th May 2008, 21:48 | #2219 | Link |
I will have to test it out with some files.
I have just tried to extract the channels from the file which is coming up as 2-channel AC3 in MediaInfo, I can only select the left and right channel, so it must be only be 2-channel even though AC3filter is detecting it as Stream format: AC3 3/2.1 (5.1) 48000Hz A similar file which is detected as 6-channel AC3 in MediaInfo I am able to extract all channels but both rear channels are completely silent/blank, again AC3filter is detected it as Stream format: AC3 3/2.1 (5.1) 48000Hz. So looks like it is some sort of fake AC3 5.1, though I am unable to try them on a true 5.1 system at present to see if sound would come out of the other speakers. |
