#262 | Link | |
see previous edit
ie Quote:
EDIT: I dont use AvsRepo, no idea what it does, maybe ChaosKing could comment.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st April 2022 at 23:47. |
#264 | Link |
Well wherever your plugins directory is, does it contain "AvsInit.avsi" ?
EDIT: eg VDub2 x86, uses x86 plugins , Vdub2 x64 uses x64 plugins, you need AvsInit.avsi, and appriopriate SysInfo64.dll or SysInfo32.dll and RT_Stats.dll (x86 or x64), as bare minimum in each of x86 or x64 plugins. EDIT: And a check on Debugview working, Code:
V=RT_VersionString RT_DebugF("RT_Stats Version = %s",V,name="Screamingtrees_Test: ") BlankClip.RT_subtitle("Hello World RT_Stats " + V) return Last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd April 2022 at 00:08. |
#266 | Link |
What about this here thingy
V=RT_VersionString Bits = SI_ProcessBitness # 32 or 64 RT_DebugF("RT_Stats Version = %s : Bits = %d",V,Bits,name="Screamingtrees_Test: ") BlankClip.RT_subtitle("Hello World RT_Stats %s : bits = %d",V,bits) return Last
#267 | Link | |
#268 | Link |
You are better off with v2.0Beta13:- https://www.mediafire.com/file/xa3t1...01229.zip/file
And a bit more Code:
V=RT_VersionString Bits = SI_ProcessBitness # 32 or 64 SI_Path = SI_ModulePath RT_DebugF("RT_Stats Version = %s\nBits = %d\nSI_Path=%s",V,Bits,SI_Path,name="Screamingtrees_Test: ") BlankClip(width=1024).RT_subtitle("Hello World RT_Stats %s\nbits = %d\nSI_Path=%s",V,bits,SI_Path) return Last Code:
00001390 00:21:19 Screamingtrees_Test: RT_Stats Version = 2.00Beta13 00001391 00:21:19 Screamingtrees_Test: Bits = 64 00001392 00:21:19 Screamingtrees_Test: SI_Path=C:\VideoTools\AvisynthRepository\AVSPLUS372_x64\plugins
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd April 2022 at 00:35. |
#269 | Link |
00000001 0.00000000 [9916] Screamingtrees_Test: RT_Stats Version = 2.00Beta13 00000002 0.00002490 [9916] Screamingtrees_Test: Bits = 32 00000003 0.00004660 [9916] Screamingtrees_Test: SI_Path=%USERPROFILE%\Downloads\UniversalAvisynthInstaller_20210119\AvisynthRepository\AVSPLUS010_x86\plugins |
#270 | Link | |
See My Avisynth Stuff |
#271 | Link |
R.F. post should fix it, if you have no use for AvsInit.
I note that AVSPLUS101_x86 is VERY old version AVS+. Current version a LOT better. Code:
00001822 00:36:56 AvsInit_ShowInfo: 00001823 00:36:56 AvsInit_ShowInfo: AvsInit_Version = 1.10 00001824 00:36:56 AvsInit_ShowInfo: GScript Available = AVS+ 00001825 00:36:56 AvsInit_ShowInfo: RT_Stats Version = 2.00Beta13 00001826 00:36:56 AvsInit_ShowInfo: SysInfo Version = 0.129000 00001827 00:36:56 AvsInit_ShowInfo: SysInfo.dll DIR = C:\VideoTools\AvisynthRepository\AVSPLUS372_x64\plugins 00001828 00:36:56 AvsInit_ShowInfo: VersionString = AviSynth+ 3.7.2 (r3642, master, x86_64) 00001829 00:36:56 AvsInit_ShowInfo: SetMemoryMax = 4096 00001830 00:36:56 AvsInit_ShowInfo: Avisynth Bitness = 64 00001831 00:36:56 AvsInit_ShowInfo: WorkingDir = C:\VideoTools\AvisynthRepository\AVSPLUS372_x64\plugins\ 00001832 00:36:56 AvsInit_ShowInfo: ProcessName = C:\NON-INSTALL\MeGUI_x64\tools\ffmpeg\ffmpeg.exe 00001833 00:36:56 AvsInit_ShowInfo: ParentProcessName = cmd.exe 00001834 00:36:56 AvsInit_ShowInfo: OSVersionString = Windows 10 (x64) (Build 18363) 00001835 00:36:56 AvsInit_ShowInfo: OSVersionNumber = 10.000000 00001836 00:36:56 AvsInit_ShowInfo: OS Bitness = 64 00001837 00:36:56 AvsInit_ShowInfo: CPUName = Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz / Coffee Lake (Core i7) 00001838 00:36:56 AvsInit_ShowInfo: Cores = 06:12 (Phy:Log) 00001839 00:36:56 AvsInit_ShowInfo: CPU Extensions = MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, FMA3, RDSEED, ADX, AVX, AVX2 00001840 00:36:56 AvsInit_ShowInfo: Total Memory = 32620MB 00001841 00:36:56 AvsInit_ShowInfo: Avail Memory = 28134MB' 00001842 00:36:56 AvsInit_ShowInfo: Screen Res = 2560x1440 00001843 00:36:56 AvsInit_ShowInfo: Screen BitsPerPixel = 32 00001844 00:36:56 AvsInit_ShowInfo: Time = Saturday 02 April 2022 00:36:56[GMT Summer Time] 00001845 00:36:56 AvsInit_ShowInfo: User TEMP Dir = C:\Users\steve\AppData\Local\Temp 00001846 00:36:56 AvsInit_ShowInfo: ComSpec = C:\Windows\system32\cmd.exe 00001847 00:36:56 AvsInit_ShowInfo: Computer Name = OMEN-W10P5 00001848 00:36:56 AvsInit_ShowInfo: User Name = steve Code:
Return Version # mine is x64 ![]() OR x86 ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd April 2022 at 00:46. |
#274 | Link |
This is what my (slightly modified) Universal Installer dir looks like
![]() This is whats inside each of those directories ![]() Get latest dlls from, files only:- https://github.com/AviSynth/AviSynthPlus/releases Choose the highest version folders in YOUR Universal Installer setup (mine are AVSPLUS372_x64 and AVSPLUS372_x86) and copy the appropriate avisynth dlls into those folders. Copy appropriate Avisynth.dll and DevIL.dll to your chosen folders [might as well setup x86 and x64 both, if you can]. Then Execute as Administrtor, "setavs.cmd", and choose the versions as per folder names you chose and setup dlls in. (version numbers shown will likely be wrong, but should be last two options for x64 and x86). Move your dlls and avsi scripts into the Plugins directories in those chosen folders. Hope you can follow that. OR, just install one of the other Avisynth Installer options from above link [might be easier]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd April 2022 at 01:13. |
#275 | Link |
it's GRunT IIRC, also yes it required
#277 | Link |
20 years and counting...
I can't get this to run on my Windows 11 machine. It works on both my Windows 10 machines. Same installation, same Avisynth+ version 3.7.2, r3661.
Error message: "Cannot load file '...\SysInfo64.dll'. Platform returned code 126: Module not found." Is there any dependancy I may be missing? |
#278 | Link | |
https://github.com/lucasg/Dependencies/releases |
#279 | Link | |
CPU: AMD 3700X | GPU: RTX 3070Ti | RAM: 32GB 3200MHz Discord: @Julek#9391 || GitHub |
#280 | Link |
Big Bit Savings Now !
sysinfo needs Microsoft VisualStudio 2010 to run.
sysinfo64.dll wants msvcr100.dll 10.0.30319.1 (18.03.2010 809KB) in system32 Later versions will not work ! Thanks kedautinh12 for the link to Dependencies.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..." Last edited by Emulgator; 15th January 2023 at 20:42. |
