24th February 2008, 22:02 | #1141 | Link | |
retired developer
Detritus Software |
24th February 2008, 22:08 | #1142 | Link | |
24th February 2008, 22:18 | #1143 | Link |
Not necessarily. Many use two displays so full-screen playback is maintained on the TV while being able to do other visual tasks on the other (typically smaller PC monitor) -i.e. read imdb or check on a download, and so on
24th February 2008, 23:14 | #1144 | Link | |
Btw:If Set CCC to theatermode,The Screen Saver keeping kick in when I am watching movie.I have to set it back to standard mode under CCC and restart the VISTA to fix the problem. |
24th February 2008, 23:25 | #1145 | Link | |
ffdshow/AviSynth wrangler
Unless you're using a plasma monitor there's no need to fear the image being burnt in... np: Markus Guentner - Donaunebel (Pop Ambient 2002)
now playing: [artist] - [track] ([album]) |
25th February 2008, 01:14 | #1146 | Link |
Otaku
@Sirber
Isn't that in the Options=>Internal Filters=>Transform Filters=>H264/AVC (DXVA)? MPC HC rev421
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
25th February 2008, 09:19 | #1147 | Link | |
25th February 2008, 10:23 | #1151 | Link | |
BTW:TheaterMode for EVR is useless,And disable it will prevent Screensaver kicking in when I play full screen on TV. Last edited by luojs; 25th February 2008 at 10:34. |
25th February 2008, 10:48 | #1154 | Link | |
Thank you for posting this. The VC-1 bitstream decoder with DXVA runs great on my system. Would it be possible to compile 2 separate MPC Video Decoder .ax filters? One for WVC1 and one for H264? I ask because I have an ATI card that seems to have problems when playing H264 files but no problems with WVC1. I am having trouble getting the filter merits worked out and I either get the MPC filter taking control of everything or taking control of nothing (unregistered). 2 separate versions of the decoder for each FOURCC would help greatly. If it is not possible, thanks for this great stuff anyways! Awesome! |
25th February 2008, 13:43 | #1156 | Link | |
Download the latest Build with .ax Files. http://rs339.rapidshare.com/files/94...lters.r421.zip The MPC VideoDecoder.ax is the Decoder with DXVA for VC1 and H264 Simply use/set it for VC1 and H264 in any DShowplayer. I use it in Zoomplayer, works perfect I have a ATI HD3870 and DXVA for H264 works perfect. Last edited by ACrowley; 25th February 2008 at 13:48. |
25th February 2008, 14:21 | #1157 | Link | |
Do you think I should also install Net.3 on my HTPC (2800+ Barton, ATI 9800 Pro) which I use MPC HT/Zoom Player, always with Reclock and always VMR9 Renderless? Would I see an improvement in performance etc? |
25th February 2008, 15:33 | #1158 | Link |
Kid for Today
no need for .net
here's a package I updated with the latest EVR.DLL from Vista SP1 final : http://www.badongo.com/file/7985462 |
25th February 2008, 17:26 | #1160 | Link | |
retired developer
Detritus Software |
