29th October 2013, 16:59 | #20621 | Link |
QB the Slayer
One other thing to realize is that madVR is assuming that those test patterns are limited range (pull up the OSD) and that changes things. From what I understand, the best setup is to have everything in your chain setup up to output Full Range (0-255) and madVR will do it's magic properly. madVR full, GPU full, Receiver (if you have one) full, TV full. Then when using those test patterns, if you want to see the WTW and BTB you tell madVR that the input is Full range (Ctrl+Shft+I I think since I don't have madVR running right now). The only time you should be telling madVR to output limited range is when you have a TV or Receiver that can not do full.
QB
29th October 2013, 17:23 | #20622 | Link | |
The only way I can get WTW with everything set to full without disturbing the absolute black level is to set a custom level. It does not make sense because using 0-255 does not work when you expect it should. If I use a custom level setting in madVR the results are weird with the AVSHD white clipping test (picture of the test I'm using posted on the previous page of this thread). It goes as follows. custom level set at 0-255 = white at 235 custom level set at 0-253 = white at 237 custom level set at 0-250 = white at 239 custom level set at 0-248 = white at 242 and so on. Last edited by Razoola; 29th October 2013 at 19:07. |
29th October 2013, 20:29 | #20623 | Link |
Media Browser 3 > madVR
I hope it's okay to post my query here.
On behalf of Luke, who does an amazing job with Media Browser 3, I seek someone who can help with this issue: fullscreen exclusive mode is not active Some screenshots of MB3 internal player |
29th October 2013, 23:51 | #20625 | Link |
@MSL_DK
I've learned how to do a directshow player based on this code : DirectShowPlayer.cs so I quite know this code Is this the last version of the internal player ? I guess there's an issue in MadvrInterface.EnableExclusiveMode(bool enable, MadVR madvr) where eModeControl.DisableExclusiveMode(pBool) is called with the wrong value: pBool should be false when enable is true, so that exclusive mode is not disabled. If the iVideoWindow is the exact size of the screen (which seems to be the case) it would fix the issue Last edited by sebdelsol; 3rd November 2013 at 23:53. |
30th October 2013, 01:47 | #20627 | Link | |
Good luck. |
30th October 2013, 06:01 | #20628 | Link | |
Looks correct. |
30th October 2013, 08:23 | #20631 | Link | |
Kid for Today
The 7790 would be too slow when there's also luma to upscale IMO, for instance the 650Ti barely makes it. Last edited by leeperry; 30th October 2013 at 08:29. |
30th October 2013, 09:12 | #20633 | Link |
Please for compare shots with chroma upscaling because i have only problem with chroma upscaling when put options to Jinc 3 AR with others no problem and video is played well!
i want to see that there is a big difference when is active, give me a reason to buy video card AMD HD7850 or HD7870 for future! |
30th October 2013, 10:51 | #20635 | Link | |
or chroma be best when encode is 4:4:4 ? |
30th October 2013, 11:23 | #20636 | Link |
few noob question:
1. How to "use" the 4:4:4 test picture from the first page, (I use a PC monitor) what should I see? If I use a TV which only supports "lesser" chroma (<4:4:4), what should I see? 2. Is there use for Upscaling at all when watching HD content on an HD monitor? 3. Bluray 4:2:0 Chroma, still need Upsampling to 4:4:4 when watching on a PC monitor? |
30th October 2013, 13:38 | #20639 | Link | |
Kid for Today
2/3. 4:2:0 YV12 chroma conversion to 4:4:4 RGB has to be upscaled. I'm no AMD sales rep and indeed J3AR chroma wouldn't make much sense if your TV doesn't accept 4:4:4 input to begin with. Last edited by leeperry; 30th October 2013 at 13:48. |
