31st August 2015, 04:33 | #1241 | Link | |
r1774 (c4972da) is definitely the culprit; it even had this comment:
r1773: r1774: I believe this is the issue that spawned that/those commit(s). Edit: old commit that might be relevant to this issue: https://github.com/AviSynth/AviSynth...f5af7dfab2c1a5 Last edited by Reel.Deel; 29th May 2016 at 12:46. Reason: link |
31st August 2015, 17:21 | #1242 | Link |
I'd like to request the addition of Rec. 2020 support for UHD Blu-rays & corresponding conversion options to compare UHD screenshots with normal Blu-ray screenshots. Otherwise we'd have to do it all manually.
Would be nice if the developers could add this in the future.
1st September 2015, 05:14 | #1244 | Link | |
1st September 2015, 05:30 | #1245 | Link | |||
1st September 2015, 14:01 | #1246 | Link |
Thanks, looking back at the change I made, that makes sense since I actually forgot to apply it to the rest of file and only fixated on the lines listed in that commit mentioned earlier and assumed the rest of it would work itself out (bad idea!). I'll test it fully at home and hopefully my idea pans out.
I found this comment very interesting as AVS 2.6 utilizes it in the "troubled" area: Code:
// Hack note :- Use of SubFrame will require an "InterlockedDecrement(&retval->refcount);" after // assignement to a PVideoFrame, the same as for a "New VideoFrame" to keep the refcount consistant. Code:
if (0 == frame->refcount) { delete frame; } EDIT: I did do a build where I reverted that commit and it does rectify the issue but it doesn't seem right to be using it as is... Last edited by Elegant; 1st September 2015 at 23:20. |
6th September 2015, 00:36 | #1247 | Link |
Retried Guesser
AviSynth+_v0.1.0_r1779.exe
http://avisynth.nl/index.php/AviSynth%2B#Downloads Code:
Colorbars(pixel_type="YV12") return Histogram("audiolevels") ConvertAudioTo16bit does not help. v2.60 Jan 14 2013 is OK. |
6th September 2015, 02:38 | #1248 | Link | |
6th September 2015, 03:29 | #1249 | Link |
Retried Guesser
It's not only ColorBars:
Colorbars(pixel_type="YV12") #[[ choose a source A=WAVSource("pinknoise.wav") ## mono A=MonoToStereo(A, A) ## 2 ch, 16 bit, 44100 #][ # A=Tone # ## 2 ch, float, 48000 #]] AudioDub(A) #[[ choose one or more - any of these causes divide-by-zero # ConvertAudioToFloat # ConvertAudioTo32bit # ConvertAudioTo16bit #]] Histogram("audiolevels") Info return Last |
20th September 2015, 17:49 | #1251 | Link |
Development has entered a hiatus again, so there's nothing past r1825 to build (pull requests notwithstanding, but aside from #64 those wouldn't add very much to the end-user's experience).
I nearly start having an anxiety attack when I try to jump back into working on the SIMD splitting necessary for the Linux (or generally GCC, really) branch. The RC1 integration majorly sidetracked it. |
21st September 2015, 02:29 | #1252 | Link | |
21st September 2015, 05:09 | #1253 | Link |
There is amazingly little that changed between 2.6 RC1 (which was already merged into AviSynth+ in the early 1700s revision range) and 2.6.0 Final that were a concern to avsplus, or otherwise. The changes that do apply to avsplus are in the RC2 integrate branch/pending pull request - which AFAICT, along the whatever the resolution of the QTGMC slowdown issue a few posts back happens to be, are really all that are blocking 0.2 being tagged and released.
If classic's CVS isn't beyond the state of 2.6.0, then there's nothing else to merge from classic at the moment. Finding that out basically requires running a full cvsimport and doing a commit comparison unless you want to wander aimlessly through Sourceforge's CVS webviewer. The last time I did that was just after 2.6.0 was released. |
23rd September 2015, 10:56 | #1254 | Link |
Acid fr0g
I have tried to search and read the wiki but can't find:
- which is the criteria to put a plugin inside plugin or plugin+? - is there a list of tested plugins that fill that criteria?
@turment on Telegram |
23rd September 2015, 11:09 | #1255 | Link | |
However, AVS+ r1576 (the "official" stable version) supports only interface version 5. There are already a few plugins that are based on interface version 6 (KNLMeansCL for example), so these won't work. Also, the latest builds of ffmpeg require interface version 6. A workaround would be to install r1576 and then replace the DLLs with r1825. |
23rd September 2015, 11:21 | #1256 | Link | |
Acid fr0g
23rd September 2015, 11:31 | #1258 | Link |
Acid fr0g
I am playing back and forth between Avisynth 2.6.0MT and AviSynth+ 1825 MT, testing speed and image quality.
I went thru the following image corruption. AviSynth output: from script: PHP Code:
