5th July 2010, 08:13 | #122 | Link |
MKVToolNix author
You can also use 4.1.1 but you have to disable extra compression for the audio tracks if you intend to play the file with such a player.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
6th July 2010, 10:15 | #124 | Link |
Forced and Default flags
This is probably a very basic things bug I'd like to clarify it in my mind. I thought that the default and forced flags are booleen values but there are 3 choices in the drop/down box in the mkvmerge dialog (YES|NO|DEFAULT) ? Note: from the header editor dialog it's only possible to set them to Yes|No Regards Christophe |
6th July 2010, 11:04 | #125 | Link |
MKVToolNix author
mmg has a lot of booleans that contain 'yes', 'no' and either 'default' or an empty value. 'yes' means 'definitely set this value to "yes"'. 'no' means 'definitely set this value to "no"'. 'default' or an empty value means 'please mkvmerge, decide yourself'.
For the 'forced display' flag this means that mkvmerge will keep the value from the source container -- e.g. if you're remuxing from a Matroska file to another Matroska file. For the 'default track' flag this means that mkvmerge will decide on the information from the source containers and the values of the 'default track' flags of all the other tracks whether or not to set this value. In all cases mkvmerge will either set the value to 'yes' or to 'no'. That's why the header editor also only lets you chose between 'yes' and 'no'.
7th July 2010, 07:26 | #127 | Link |
MKVToolNix author
No support for Flash video files is planned.
7th July 2010, 11:43 | #129 | Link |
MKVToolNix author
Not really, no. There's nothing in the specs telling a player how to sort the tracks, so most players simply use the order in which they appear in the track headers. Neither mmg's editor nor mkvpropedit allow the track headers to be re-ordered, and such a feature is not planned at the moment.
8th July 2010, 10:42 | #130 | Link |
I have recently bought new Samsung LED TV which is unable to play MKV files with new audio compression. I have to specify "none" each time I add an audio stream. This is easy, but also easy to forget about it. Muxing of 30 GB file to external HDD takes about 40 minutes. And sometimes this time is wasted due to wrong compression setting. It is very unlikely that Samsung will correct its firmwares, and therefore I would be very grateful that You add in program options a checkbox, which will make "audio compression - none" as default.
8th July 2010, 11:03 | #131 | Link |
@Mosu
I think that you should disable audio compression by default. It only causes more confusion. You've added that feature too late
8th July 2010, 11:58 | #132 | Link |
MKVToolNix author
Sorry, but I won't.
8th July 2010, 12:01 | #133 | Link |
MKVToolNix author
Sorry, but I won't. Users have several options (some better suited than others for different kinds of users): keep using an earlier version; force compression off; use the command line which makes forcing easier; get the player vendors to support this feature that's been part of the specifications for eight years now.
8th July 2010, 12:13 | #134 | Link |
Why is it so important for you that the default be enabled? Don't you care at all about the grief this causes users? Isn't it a trivial matter to enable the option if you want it? Doesn't backward compatibility mean anything to you?
Please don't get mad at me. I'm just inquiring as a concerned user. |
8th July 2010, 12:20 | #135 | Link |
MKVToolNix author
I'm concerned about backwards compatibility, but at the specs level. The specs haven't changed in this regard, this feature just has never seen very wide use until now. Haali's muxer has always supported header compression (muxer, not only the demuxer!), but it hasn't been enabled by default.
What I'm trying to do at this very moment is to get companies to update their software to support a wider range of the specs. Now is a good time for such a move due to an already existing major change in mkvtoolnix 4.0.0 (default values aren't written anymore) and due to the changes necessary for WebM playback. That's why I'm pushing for it now. The Matroska project has always been about pushing into unchartered territory. If we were satisfied with the status quo then we'd still all be using AVIs or MP4 and neither OGM nor Matroska would have seen the light of day. Yes, this process is often painful, but you don't get (technical) advancement for free.
8th July 2010, 12:45 | #136 | Link | |
8th July 2010, 12:55 | #137 | Link |
MKVToolNix author
I'm not about forcing everyone to push my agenda for them. I like to give the users a choice. The choices themselves are often not what the user would prefer though (e.g. use older versions of the software).
There's a technical reason why I don't let users chose in the 'default values' case: the libraries mkvtoolnix uses makes it very hard to not write default values and still create valid WebM files. I don't have that much time to fix this properly. The 'compression' case is different. It's technically trivial to let the user chose in this case. Even the modifications in mmg were trivial because the 'compression' selection box was already present, it just couldn't be used for non-subtitle tracks.
8th July 2010, 13:33 | #138 | Link |
I second the request for an option in mmg to turn off audio compression by default. I compared a file (1*AVC/3*AAC/1*SUB/IDX) muxed with 3.4.0 and 4.1.1 and the latter is 0,002% smaller (45kB out of 2.12 GB) and didn't work on any of my hardware. There is zero gain and lots of trouble with that feature.
8th July 2010, 13:39 | #139 | Link |
MKVToolNix author
There's no header removal compression with AVC and AAC tracks. VobSub tracks have always been compressed with zlib.
And no, I won't add such an option. Sorry.
