Old 30th November 2022, 13:01   #1  |  Link
Easy
Capturing - Monitor Color Space
Good day everyone,
I have a simple question with probably not an easy answer.
I want to capture (or prefered pipe the bitstream of) a video with the color space of my monitor.
So an exact copy of the image what is displayed. The only way I could think of is to use a calibrating tool to save and apply the .icc to my video. But I thought maybe there is a way to detect and calculate the color space without additional hardware.
Does someone has an idea ?
Easy is offline   Reply With Quote
Old 30th November 2022, 19:44   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Whatever the capturing monitor might be capable of should be of no concern.
Capturing means to take as-is, just don't clip, and take care of processing later.
Depending on capture device you might be able to match the analog pedestal range
(and if gain, black slope, white slope etc are available)
using a monochrome waveform monitor to make sure nothing clips before digitizing.
After that comes preprocessing, colour correction, editing etc.
and now you need full gamut for whatever you may aim for.
The capturing monitor's .icc only represents a correction curve somebody found to make any odd monitor just bearable,
and does not represent any absolute luminous density which you should base any decision on.
bitstream, capture, color space
