29th October 2013, 22:53 | #61 | Link |
Got it. The sum of the integer coefficients was sometimes off by 1 or 2 units. The bug is now fixed and the change will be available in the next release.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
18th November 2013, 19:40 | #63 | Link |
It builds fine with clang/gcc http://forum.doom9.org/showpost.php?...0&postcount=53
27th November 2013, 17:51 | #64 | Link |
fmtconv r7: Warning—I left an important bug in the resizer, you’d better wait for the next version.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding Last edited by cretindesalpes; 30th November 2013 at 10:21. |
29th November 2013, 02:12 | #65 | Link |
Beyond Kawaii
This script
from __future__ import print_function vapoursyth_plugins_path = 'E:\\vapoursynth-plugins\\x64\\' import vapoursynth as vs import sys sys.path.append(vapoursyth_plugins_path + 'E:\\vapoursynth-plugins\\py\\') core = vs.get_core(threads=8) core.set_max_cache_size(16000) import os for filename in os.listdir(vapoursyth_plugins_path): if filename[-4:] != '.dll': continue try: core.std.LoadPlugin(vapoursyth_plugins_path + filename) except Exception as e: print("Error: ", e, end='\n', file=sys.stderr) core.std.LoadPlugin(path = 'D:\\Programming\\TempLinearApproximate-VapourSynth\\build\\release-x64\\templinearapproximate.dll') #fun = core.list_functions() #print(fun, end='\n', file=sys.stderr) d2vfile = 'F:\\Video to Process\\Riaru Onigokko 2\\VTS_01_1.d2v' ret = core.d2v.Source(input=d2vfile) ret = core.vivtc.VFM(ret, order=1, mode=5) ret = core.vivtc.VDecimate(ret) def tvToPC(input): c = core.fmtc.resample (clip=input, css="444") c = core.fmtc.matrix (clip=c, mats="601", matd="709") c = core.fmtc.resample (clip=c, css="420") c = core.fmtc.bitdepth (clip=c, bits=8) return c z = ret #z = tvToPC(z) ret = tvToPC(ret) diff = core.std.MakeDiff(z, ret) line1 = core.std.StackHorizontal([z, ret]) line2 = core.std.StackHorizontal([diff, ret]) compare = core.std.StackVertical([line1, line2]) compare.set_output() I've also managed to crash VirtualDub with this crash report.
...desu! |
30th November 2013, 12:15 | #66 | Link |
ftmconv r8:
25th February 2014, 04:53 | #68 | Link |
I wanted to convert color space from YV12 to RGB to load some Virtualdub filters, and I'm getting the error "VFW module doesn't support RGB24 output". How should I do this?
ret = core.fmtc.resample (ret, css='444') ret = core.fmtc.matrix (ret, mats="709", col_fam=vs.RGB) ret = core.fmtc.bitdepth (ret, bits=8) |
21st May 2014, 08:07 | #71 | Link |
Yes it is more or less a leftover from Dither, because I want to keep the same base code to backport it from fmtconv to Dither later. It should be harmless anyway.
2nd August 2014, 14:12 | #72 | Link |
import vapoursynth as vs core = vs.get_core() import os ext = '.png' dir = r'PNG/' srcs = [dir + src for src in os.listdir(dir) if src.endswith(ext)] v = core.imgr.Read(srcs,24,1) v = core.fmtc.matrix(v, mat="709", col_fam=vs.YUV, bits=16, fulls=1, fulld=1) v = core.fmtc.bitdepth(v, bits=10, dmode=1) enable_v210=True v.set_output() Code:
Failed to evaluate the script: Python exception: matrix: only constant pixel formats are supported. Traceback (most recent call last): File "vapoursynth.pyx", line 1148, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:18441) File "D:/TRAILERS/DCP/MOCKINGJAY-PT1_TLR-1_S_RU-XX_RU_51_2K_LION_20140729_DLA_IOP_OV/myVapourScript.vpy", line 8, in <module> v = core.fmtc.matrix(v, mat="709", col_fam=vs.YUV, bits=16, fulls=1, fulld=1) File "vapoursynth.pyx", line 1071, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:17443) vapoursynth.Error: matrix: only constant pixel formats are supported. |
12th February 2015, 14:27 | #73 | Link |
In the documentation of dither for avs there is a very handy quick explanation of what a dithering algo is good for.
I used to use the stucki error diffusion because seemed the best of the list. In the vs version you added two new algos: Sierra-2-4A error diffusion and Ostromoukhov error diffusion. Can you please give me a quick explanation like the ones on the avs doc?? |
12th February 2015, 16:28 | #74 | Link |
Sierra-2-4A is comparable to Floyd-Steinberg, but slightly faster.
Ostromoukhov helps fighting the artefacts seen on Floyd-Steinberg, giving more homogenous flat areas. See also: A Simple and Efficient Error-Diffusion Algorithm
14th February 2015, 16:55 | #75 | Link |
Ok thanks, i read the article [even i didn't understood it very well], i even tried to make a 2bit image to compare stucki and ostromoukhov, but vs doesn't allow me to output 2bit image afaik.
Then i tried to see the difference between the different ED methods and i was unable to see any difference in the LSB, but very little in the MSB [on a 16bit image decomposed using nativetostack16, with 8bit image i didn't saw any difference at all]. Probably i made my tests in an erroneous way, so i'd like to know your opinion if the difference are really so unnoticeable or very little differences can make an image looks better I used this script for my tests and the first two exr frames from BBB Code:
src = core.imwri.Read("C:/Users/MonoS/Desktop/%04d.exr", firstnum=1).fmtc.bitdepth(flt=1) yuv = core.fmtc.matrix(src, mats="RGB", matd="709", bits=32, col_fam=vs.YUV) core.std.MakeDiff(core.fmtc.bitdepth(yuv, flt=0, bits=16, dmode=7, fulls=False, fulld=False).fmtc.nativetostack16(),\ core.fmtc.bitdepth(yuv, flt=0, bits=16, dmode=4, fulls=False, fulld=False).fmtc.nativetostack16()).set_output() |
14th February 2015, 18:19 | #76 | Link |
You are trying to dither floating point data to 16 bits, the difference between dithering methods will be insignificant. Actually I don’t even bother dithering when converting down to 16 bits. If you want to see the difference, dither to 8 bits. And even at 8 bits, it will be quite hard to spot any quality difference. Only Bayer dithering can really stand out on low-res pictures because of its specific pattern.
14th February 2015, 19:16 | #77 | Link |
unsigned int
Try something like this:
import vapoursynth as vs c = vs.get_core() c.std.LoadPlugin(".libs/vszimg.so") shades = [] fmt = c.register_format(color_family=vs.RGB, sample_type=vs.INTEGER, bits_per_sample=14, subsampling_w=0, subsampling_h=0) for i in range(1200): shades.append(c.std.BlankClip(width=1, height=120, format=fmt.id, color=[i] * 3, length=1)) src = c.std.StackHorizontal(shades) none = c.z.Depth(src, depth=8, dither="none").text.Text("none") ordered = c.z.Depth(src, depth=8, dither="ordered").text.Text("ordered") random = c.z.Depth(src, depth=8, dither="random").text.Text("random") ed = c.z.Depth(src, depth=8, dither="error_diffusion").text.Text("error diffusion") src = c.std.StackVertical([none, ordered, random, ed]) src.set_output()
Buy me a "coffee" and/or hire me to write code! |
14th February 2015, 19:19 | #78 | Link | |
So in the end, if i understood correctly, it's better to use a compression resilient algo if i really need to dither down and only for 8bit output [but i usually pipe the 16bit video directly to x264/5], at 16bit differences are almost unnoticeable and i can use the one i like most. If so, why bother implementing 7 different algos?? |
14th February 2015, 19:50 | #79 | Link |
Thanks jackoneill, i was able to see some difference between the different algos, my favorite remain the stucki ED, it seems pretty similar to Ostromoukhov and Sierra 2-4A, but stucki seemed to be a bit more random in adding dithering and maybe is a plus, the other ones seemed to generate some artifact [like the worm like "artifact" of Atkinson].
Are my observation right in some sense?? |
7th March 2015, 14:58 | #80 | Link |
interlocked:181 assertion failed
Hi everybody,
I made a fresh install to try the vapoursynth plus HAvsFunc. the compiling from git was success. When i try to use the fmtc functions it gives Assertion failed: vspipe --y4m zod.vpy - | ffplay -i pipe: ----- vspipe: ./conc/Interlocked.hpp:181: static int64_t conc::Interlocked::cas(volatile int64_t&, int64_t, int64_t): Assertion `is_ptr_aligned_nz (&dest)' failed ---- archlinux 32bit, ubuntu 32bit as well my script is simple : ----------------------------------- import vapoursynth as vs core = vs.get_core() c = core.std.BlankClip(width=100, height=200, format=vs.YUV420P8, color=[64, 64, 64]) c = core.fmtc.resample(c, w=100, h=100) c.set_output() ------------------------------ when I leave the original size : c = core.fmtc.resample(c, w=100, h=200) I see the green box what can I miss ? thanx -- metyo /* EDIT : AchLinux x86_64 , packages from AUR everything works ok ! thank sl1pkn07 for maintaning */ Last edited by metyo; 16th March 2015 at 21:43. |
