14th December 2004, 16:42 | #1 | Link | |
mencoder + XviD + win32 - Quant Matrice's?
Environment
------------ Windows XP MPlayer-mingw32-dev-CVS-041211 command: mencoder dvd://1 -oac copy -ovc xvid -xvidencopts <stuff> So I've gotten to a point in testing out different bitrates & settings for the built-in XviD codec that comes with mplayer that I'm upto trying out different Matrice's. Problem is I can't load any.... It says in the man pages that I can make one using xvid4conf... Quote:
Is there a way to either convert the various matrices that come with the koepi & co XviD binaries to use with mencoder? OR Is there a way I can get mencoder to use my installed XviD (win32 binary) instead of the inbuilt XviD?? I've tried searching for various things but nothing is turning up Last edited by SoreGums; 14th December 2004 at 16:54. |
15th December 2004, 03:16 | #4 | Link |
Thanks
After a shaky start I found out I could just copy my windows GTK2 over the top of my cygwin dirs and everything started working I couldn't download GTK2 from my local source of cygwin. Thanks again |
15th December 2004, 08:26 | #6 | Link | |
ffdshow/AviSynth wrangler
16th December 2004, 12:55 | #8 | Link |
I have a problem with the MEncoder(win32 build, by celtic_druid) with xvid encoding,
I'm successfully create the intra and inter matrix file with the xvid4conf, but the mencoder was unabble to use them, when i add an option to mencoder -xvidencopts :quant_intra_matrix="F:\mplayer\intra.txt":quant_intre_matrix="F:\mplayer\intre.txt" When start encodind, the mencoder show the similar message: unable to load \mplayer\intra.txt" unable to load \mplayer\intre.txt" although the encoding process strat normally. please help me |
17th December 2004, 00:26 | #10 | Link | |
So /dir - mencoder.exe - intra_matrix.txt - inter_matrix.txt |
23rd November 2021, 13:12 | #12 | Link | |
None
I'm using mencoder on Windows 10 64-bit.
How do I load xvid custom quantization matrices in mencoder? I found the following in mencoder manual: Quote:
23rd November 2021, 21:18 | #13 | Link |
Alternatively you could use: https://forum.doom9.org/showthread.php?t=73666
(LigH posted a link to his editor and a link to a collection of matrices, works fine on Win10 and Win11) |
