17th January 2021, 21:20 | #1 | Link |
hlg-tools Maintainer
Confounded by YUV<->RGB Conversaion
What the devil is going on here...
I took that from Wikipedia. The article it's from specifically states that Y is linear light and that Y' is gamma-corrected, perceptual light. It also states specifically that RGB is linear light. So how in blue blazes do you get a gamma-corrected Y' value for output when taking linear-light values in as input...using nothing but multiplication? |
17th January 2021, 22:23 | #2 | Link |
I would follow the original ITU-R BT.601-7 and ITU-R BT.709-6 specification rather than one of its many interpretations. Perhaps it helps to clarify your questions.
There are some doubts and questions about this article in its 'talk' page by the way ..... Last edited by Sharc; 18th January 2021 at 16:13. |
17th January 2021, 23:50 | #4 | Link |
You may find the answer here:
http://poynton.ca/notes/colour_and_g....html#RTFToC18 see also para. 7. .... 12. https://web.archive.org/web/20120403...onversion.html http://poynton.ca/notes/colour_and_gamma/GammaFAQ.html Last edited by Sharc; 18th January 2021 at 15:41. |
18th January 2021, 16:42 | #5 | Link |
Have you checked if you can use my avs plugin here for doing what you want ? (Maybe also check zimg).
I've also added a pdf document to try to explain the linear/non-linear part in my plugin.
My github. |
25th March 2021, 10:28 | #6 | Link | ||
http://poynton.ca/papers/SMPTE_98_YYZ_Luma/index.html Quote:
26th March 2021, 03:26 | #7 | Link |
I ended up assuming that the HOWTO on Wikipedia was irrational. I wrote my own method for RGB->YCbCr using strictly linear light. From that, I then refined an inverse of YCbCr->RGB.
https://github.com/wswartzendruber/p...mod/src/rgb.rs Note that my bt1886_oetf function there should really be bt1886_ieotf. |
12th September 2021, 21:42 | #8 | Link | |
The bad things happens when processing of different outputs of YUV matrix performed in different frequency bands paths (like sub-sampled chroma to 4:2:2 or 2:0 or 1:1 etc). To completely reverse operations the equal data channels required. It is shadows from the poor old days when frequency spectrum and bitspeeds where very limited and engineers designed lots of compression stages to moving pictures data - interlace, gamma, chroma subsampling and mpeg. But not all of compression stages are fully-reversible. From modern systems interlace is mostly killed and I think the chroma subsampling need to be killed too. Though it makes less visible distortions in compare with interlace scan and mostly at the transients of very saturated colours that is rare at natural scenes. |
24th September 2021, 18:10 | #9 | Link | |
Those are using analog Y'U'V', NOT Y'Cb'Cr'!! Nobody needs it no longer. This is just for historical info. The BT.709 /BT.2020 matricies and inverses are in YCbCr article (also added by me). As for how. This is just a typo, though linear RGB were also in use in russian SECAM IV, but then you get linear YUV. Fixed. About linear RGB is also just a typo, long since removed. Last edited by Balling; 24th September 2021 at 18:41. |
25th September 2021, 00:15 | #10 | Link |
'the dark band seen between the green and magenta color bars of the standard video test pattern'
The old and current ITU motion pictures imaging systems do have build-in bugs for colour imaging but they are expected to be rarely seen because of: 1. Natural imaging rarely have saturated colours. 2. If ever saturated colours happens - they much more rare close to each and form high saturated colour transient. So colour bars test pattern is sort of never-happen in reality image. Just sad bug for colour imaging systems of old days and todays. Unfortunately the designers of synthetic images are not knows these limitations so typical broadcast 4:2:0 TV are highly loaded with top-saturated advertisements and clips and shows and displays these bugs. |
