22nd December 2014, 01:57 | #81 | Link |
Professional Code Monkey
It's a bug in vapoursynth. I forgot that stof() is locale dependent. The next version will correctly always use a point as the decimal separator.
17th May 2015, 13:09 | #83 | Link |
Here are updated binaries with a small fix to work with VapourSynth R27.
Simply overwrite the exe files in the official packages.
11th August 2015, 11:57 | #85 | Link |
The cult of personality
I have this issue for quite a long time:
Failed to evaluate the script: Python exception: No attribute with the name ffms2 exists. Did you mistype a plugin namespace? Traceback (most recent call last): File "vapoursynth.pyx", line 1467, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:24719) File "C:/Users/VEGETA/Desktop/Untitled.vpy", line 5, in <module> File "vapoursynth.pyx", line 1088, in vapoursynth.Core.__getattr__ (src\cython\vapoursynth.c:18921) AttributeError: No attribute with the name ffms2 exists. Did you mistype a plugin namespace? I've put ffms2.dll (and index..) in plugins32 and in core32/plugins but still doesn't get it. I also tried loading it manually but didn't work! it says it can not load it. However, before that... I tried to print the version but didn't work on the editor while worked well in the shell itself. it wrote that it couldn't detect plugins1,2,3,4... I guess this is the main problem. I tried putting the plugins' directory manually into the editor but still no use. I hope you can help. thanks |
11th August 2015, 17:38 | #88 | Link |
Just tried it on my laptop, Windows 7 x86... Same issue.
I use this script: Code:
import vapoursynth as vs core = vs.get_core() a= core.std.blankclip() a.set_output() Code:
Failed to evaluate the script: Python exception: There is no function named blankclip Traceback (most recent call last): File "vapoursynth.pyx", line 1467, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:24719) File "", line 3, in <module> File "vapoursynth.pyx", line 1247, in vapoursynth.Plugin.__getattr__ (src\cython\vapoursynth.c:21557) AttributeError: There is no function named blankclip Code:
a=core.std.blankclip() it outputs: Code:
Traceback (most recent call last): File "<pyshell#9>", line 1, in <module> a = core.std.blankclip() File "vapoursynth.pyx", line 1247, in vapoursynth.Plugin.__getattr__ (src\cython\vapoursynth.c:21557) AttributeError: There is no function named blankclip Code:
import vapoursynth as vs core = vs.get_core() print(core.version()) Code:
Failed to get the script output node. Observing that, my guess is: 1- It doesn't recognize/use the .std stuff, only core. (no libs loaded)? 2- Something is wrong with the editor as it can not even show the version (while the python IDE can). looking forward to your help. |
11th August 2015, 19:17 | #90 | Link |
I downloaded the fixed exe from previous post and it works now.
Still, another issue... which is: it doesn't load any native plugins like ffms2 and flash3kyuu. what to do? here is my script: import sys import vapoursynth as vs core = vs.get_core() core.std.LoadPlugin('D:\\plugins32\\ffms2.dll') core.std.LoadPlugin('D:\\plugins32\\flash3kyuu_deband.dll') last = core.std.BlankClip() last = core.f3kdb.F3kdb(last, y=49, output_depth=10, dither_algo=2)[:10] last.set_output() |
11th August 2015, 20:35 | #92 | Link | |
TL;DR: I have a problem of loading native plugins such as ffms2 and f3kdb. They work nice when loading them as avs plugins not native. |
12th August 2015, 08:20 | #93 | Link |
ангел смерти
Your script shows you loading them natively, though; avisynth loading is core.avs.LoadPlugin(). Ohhhh, I get it, you assume you're loading an avisynth plugin... both of those plugins include both avisynth and vapoursynth in one dll. You're already done!
Just remember that VapourSynth is case sensitive from here out and you'll be ok. |
12th August 2015, 21:06 | #94 | Link | |
23rd August 2015, 20:11 | #95 | Link |
SIGSEGV problem
I'm using Manjaro Linux 3.18.20-1, vapoursynth from git and just after the last update of Manjaro it prompts me this error when I try to check or preview the script. Sometimes it doesn't do anything at all and sometimes does only one of the two operation above ( check or preview ), otherwise it crashes with any sort of script, from the simplest to the one more complex.
Here is what gdb prompted me ( i'm not a computer programmer so I surely didn't debug it correctly ) Code:
(gdb) start Temporary breakpoint 1 at 0x415610 Starting program: /home/Vapoursynth/vap-editor/build/release-64bit-gcc/vsedit [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". Temporary breakpoint 1, 0x0000000000415610 in main () (gdb) continue Continuing. QWidget::insertAction: Attempt to insert null action [New Thread 0x7fffea8e1700 (LWP 6738)] Program received signal SIGSEGV, Segmentation fault. 0x00007ffff7de4045 in do_lookup_x () from /lib64/ld-linux-x86-64.so.2 (gdb) continue Continuing. [Thread 0x7fffea8e1700 (LWP 6738) exited] Program terminated with signal SIGSEGV, Segmentation fault. The program no longer exists |
23rd August 2015, 21:43 | #97 | Link |
SIGSEGV problem
Sorry for being late, the debug version was built in another directory and I couldn't find it at first ! So stupid I am.
Anyway, here is the output. Code:
gdb vs* Excess command line arguments ignored. (vsedit.svg) GNU gdb (GDB) 7.9.1 Copyright (C) 2015 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-unknown-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from vsedit-debug-64bit-gcc...done. "/home/Vapoursynth/vap-editor/build/debug-64bit-gcc/vsedit.ico" is not a core dump: File format not recognized (gdb) start Temporary breakpoint 1 at 0x46bab2: file ../src/main.cpp, line 7. Starting program: /home/Vapoursynth/vap-editor/build/debug-64bit-gcc/vsedit-debug-64bit-gcc [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". Temporary breakpoint 1, main (argc=1, argv=0x7fffffffe768) at ../src/main.cpp:7 7 QApplication application(argc, argv); (gdb) continue Continuing. QWidget::insertAction: Attempt to insert null action [New Thread 0x7fffea8e1700 (LWP 11972)] Program received signal SIGSEGV, Segmentation fault. 0x00007ffff7de4045 in do_lookup_x () from /lib64/ld-linux-x86-64.so.2 (gdb) bt full #0 0x00007ffff7de4045 in do_lookup_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #1 0x00007ffff7de4d3f in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #2 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #3 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #4 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #5 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #6 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #7 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. ---Type <return> to continue, or q <return> to quit--- #8 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #9 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #10 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #11 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #12 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #13 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #14 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #15 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 ---Type <return> to continue, or q <return> to quit--- No symbol table info available. #16 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #17 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #18 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #19 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #20 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #21 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #22 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #23 0x00007ffff7de5213 in _dl_lookup_symbol_x () ---Type <return> to continue, or q <return> to quit--- from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #24 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #25 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #26 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #27 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #28 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #29 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. #30 0x00007ffff7de5213 in _dl_lookup_symbol_x () from /lib64/ld-linux-x86-64.so.2 No symbol table info available. ---Type <return> to continue, or q <return> to quit---q Quit (gdb) continue Continuing. [Thread 0x7fffea8e1700 (LWP 11972) exited] Program terminated with signal SIGSEGV, Segmentation fault. The program no longer exists. Last edited by dontrythisathome; 23rd August 2015 at 21:47. |
25th August 2015, 02:09 | #100 | Link |
ангел смерти
Looking for that error I found one copy-paste bug in previewdialog.cpp:869 (m_pPreviewContextMenu->addAction(m_pActionSaveSnapshot); should be m_pPreviewContextMenu->addAction(m_pActionFrameToClipboard);). Try changing that and see if it works.
