Old 25th October 2014, 08:07   #61  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Originally Posted by HolyWu View Post
Could you please make the editor show the call tips as well when the users type any character within the filter's parenthesis?
Yes, I can. Just realized that's the way I should have done it from the beginning. Autocompletion for function name only and a tooltip for the arguments.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 8th December 2014, 15:07   #62  |  Link
Mystery Keeper
Beyond Kawaii
r4 is finally out with few fundamental changes.
Custom font is not embedded.
Preview is now done completely internally. ALL formats recognized by VapourSynth are supported.
Chroma upsampling is done using zimg library, which adds some little quirks.
Make sure you explore the new settings in preview window and use the right colorspace conversion matrix for each script.
Also, I think this thread deserves to be sticky.
...desu!
Old 8th December 2014, 19:09   #63  |  Link
lansing
the 32bit version crash on start, and where should we install the zimg library? The original post didn't say anything.
Old 8th December 2014, 19:13   #64  |  Link
Mystery Keeper
Beyond Kawaii
zimg library code is integrated, so you don't need to install it for the editor. It doesn't crash for me. I'll test 32bit version in virtual machine again.
Upd: Test works perfectly fine. Try to download and install VapourSynth R25 again. There were versions that made the editor crash.
...desu!
Old 8th December 2014, 19:30   #65  |  Link
lansing
Yup I just found that out, installed r25 and the problems went away. You may want to modify the error message to inform the users to use the correct vapoursynth version.
Old 8th December 2014, 19:41   #66  |  Link
Mystery Keeper
Beyond Kawaii
Modify which error message? It doesn't really care for what VS library it uses as long as API is compatible. The crash was caused by "tcmalloc" library that VS now uses overriding standard functions.
...desu!
Old 8th December 2014, 19:57   #67  |  Link
lansing
When I was using the outdated vapoursynth version before, there's a warning message saying that I need to set up the library folder path.
Old 8th December 2014, 20:04   #68  |  Link
Mystery Keeper
Beyond Kawaii
That happened because it couldn't load vapoursynth.dll, which used dynamically linked tcmalloc. That breaks autocompletion and syntax highlighting, but not preview. That error means "I could not find an instance of vapoursynth.dll that I could load".
...desu!
Old 8th December 2014, 20:05   #69  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
The experimental builds don't get their own version so it can't be detected. Experimental versions are so because they may be very broken.
Myrsloik is offline   Reply With Quote
Old 21st December 2014, 23:37   #70  |  Link
Are_
Ok, now I have kind of a problem and I don't know exactly who is the culprit, so I'm going to throw it here.
Whenever I try to preview a script with finesharp on vsedit, it tells me something like:
Failed to evaluate the script:
Python exception: Expr: Failed to convert '9.9' to float
Traceback (most recent call last):
  File "vapoursynth.pyx", line 1480, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:25191)
  File "/home/dani/rule6/stuff/_stuff.py", line 21, in <module>
    f = finesharp.sharpen(clip=src, mode=1, sstr=2)
  File "/usr/lib64/python3.4/site-packages/finesharp.py", line 153, in sharpen
    xyshrp = core.std.Expr(clips=[shrp, core.rgvs.RemoveGrain(clip=shrp, mode=[20])], expr=expr)
  File "vapoursynth.pyx", line 1379, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:23686)
vapoursynth.Error: Expr: Failed to convert '9.9' to float
But I can't see why the code is wrong.
This only happens when Expr is used, it looks like strings get screwed somehow.
vspipe/mpv don't complain about anything, only vsedit does.
Does this make any sense? :/
Are_ is online now   Reply With Quote
Old 21st December 2014, 23:39   #71  |  Link
Mystery Keeper
Beyond Kawaii
That's a Python error. Something with your expression.
...desu!
Old 21st December 2014, 23:42   #72  |  Link
Are_
Tell me how this is wrong:
            expr   = 'x x y - 9.9 * +'
Also, I have already said it, vspipe and mpv don't throw any error and proces de video correctly.
Old 21st December 2014, 23:48   #73  |  Link
Mystery Keeper
Beyond Kawaii
Sorry, missed the part about vspipe not complaining. I really don't know. I'll try to test expr with vsedit.
...desu!
Old 21st December 2014, 23:49   #74  |  Link
Are_
import vapoursynth as vs
core = vs.get_core()
src = core.std.BlankClip()
def stuff(clip):
    r = core.std.Expr(clips=clip, expr='x 9.9 +')
    return r
r = stuff(src)
r.set_output()
This will fail in vsedit.
Old 21st December 2014, 23:51   #75  |  Link
Mystery Keeper
Beyond Kawaii
It doesn't fail for me.
...desu!
Old 21st December 2014, 23:55   #76  |  Link
Are_
Mmh... then it has something to do with my box (make sure the thing you tested ended with "r.set_output()" because I ninja edited that part ^^U). :/
Old 22nd December 2014, 00:05   #77  |  Link
Are_
Well, don't worry, it also works for me on windows, something should be wrong in my end.
Old 22nd December 2014, 00:10   #78  |  Link
sl1pkn07
Pajas Mentales...
def stuff(clip):
    return r
r = stuff(src)
r.set_output()
fail for me in linux 64bits, VS 54b97e1
  File "vapoursynth.pyx", line 1480, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:25089)
  File "", line 11, in <module>
  File "", line 8, in stuff
  File "vapoursynth.pyx", line 1379, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:23584)
sl1pkn07 is offline   Reply With Quote
Old 22nd December 2014, 01:22   #79  |  Link
Myrsloik
Myrsloik's Avatar
Are you using a locale where the decimal separator isn't a point?
Old 22nd December 2014, 01:35   #80  |  Link
sl1pkn07
Pajas Mentales...
I believe is a ','
edit:
oh, yes, change 9.9 with 9,9 now works
thanks for the point
greetings
