15th December 2009, 00:59 | #6322 | Link | ||
Moreover movies are alot easier to compress. Stop asking me for placebo effect , ok!? @magmo Quote:
video=AVCSource("C:\temp\RipBot264temp\job1\job1.dga").ConvertToYV12()
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th December 2009 at 01:02. |
15th December 2009, 14:21 | #6324 | Link | |
Still the same error ?
Replace old x264_x86.exe with newer http://komisar.gin.by/old/1373/x264....eneric.x86.exe
15th December 2009, 16:02 | #6325 | Link | |
15th December 2009, 22:57 | #6326 | Link |
7.1 flac -> 5.1 flac
So after rummaging around I found the solution to my 7.1 FLAC problem. See the problem is most devices (PS3, XBMC, etc.) have a problem with 7.1 FLAC directly. EAC3TO can easily downmix to 5.1 FLAC. Unfortunately, it requires demuxing the completed file, processing the audio with eac, and then remuxing the audio back in. So it is possible, but tedious. Since RipBot uses eac3to already, would it be possible to add a 7.1 -> 5.1 FLAC DownMix option? Or is there someway I can add it to the script before encoding?
Any help would be great. Atak keep up the great work! |
15th December 2009, 23:04 | #6327 | Link | |
16th December 2009, 00:15 | #6328 | Link |
CQ vs 2 Pass question
Atak,
I have a quick question in regards to CQ vs 2 Pass. I know that 2 Pass should be used if you need to burn your media to a disk. Other than saving disk space, what is the benefit of CQ? Does CQ produce a better picture quality that 2 Pass? I really do not need to burn my media to disks since I used a WHS to store all my Blu-rays and then stream them throughout the house to all the clients. Thanks in advance, Duramaximus |
16th December 2009, 00:24 | #6329 | Link | |
17th December 2009, 03:26 | #6333 | Link |
Oh also with 1.14.6 every time I try to start a rip, after the demux process, video.mkv gets deleted somehow and MPC pops up saying "video.mkv can not be found" my video - log.txt says:
eac3to v3.17 command line: "C:\RipBot264v1.14.6\Tools\eac3to\eac3to.exe" "G:\namedeleted\" 1) 2: "E:\Temp\RipBot264temp\job2\video.mkv" -seekToIFrames 3: "E:\Temp\RipBot264temp\job2\audio.1.dtsma.wav" -down16 7: "E:\Temp\RipBot264temp\job2\7_Subtitles_English.sup" 1: "E:\Temp\RipBot264temp\job2\chapters.txt" -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 4 audio tracks, 4 subtitle tracks, 0:50:40, 24p /1.001 1: Chapters, 6 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 7.1 channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 4: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 5: AC3, Spanish, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 6: AC3, French, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 7: Subtitle (PGS), English 8: Subtitle (PGS), Spanish 9: Subtitle (PGS), French 10: Subtitle (PGS), Portuguese Creating file "E:\Temp\RipBot264temp\job2\chapters.txt"... [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [v02] Muxing video to Matroska... [s07] Extracting subtitle track number 7... [a03] Decoding with ArcSoft DTS Decoder... [a03] Reducing depth from 24 to 16 bits... [a03] Writing WAV... [a03] Creating file "E:\Temp\RipBot264temp\job2\audio.1.dtsma.wav"... [s07] Creating file "E:\Temp\RipBot264temp\job2\7_Subtitles_English.sup"... [a03] The ArcSoft DTS Decoder reported an error while decoding. <ERROR> Aborted at file position 7906023424. <ERROR> and job.avs says: Code:
#MT #VideoSource video=DirectShowSource("E:\Temp\RipBot264temp\job2\video.mkv",audio=false).ConvertToYV12() #Deinterlace #Decimate #Crop #Resize #Colors #Denoise #Subtitles #AudioSource #DownMix #Delay #Tempo #Normalize #AudioDub #Triming #AVSameLength #ColorSpace Last edited by gohamstergo; 19th December 2009 at 03:56. |
17th December 2009, 05:30 | #6334 | Link |
Stuck at " Gathering information"
Hey all,
Any hints as to why RipBot may be eternally stuck @ 'Gathering information' after Demuxing streams is successful: BD 'GI_Joe Region B, Ripped with AnyDVD. Tested same rip thru BD Rebuider & HDConvertToX without any sort of issue > RipBot the much preferred GUI... Have to eventually abort the process to close. |
17th December 2009, 06:46 | #6335 | Link |
Ok, you got me on this one. If you don't convert to FLAC, how are you going to retain the 7.1 audio? Dolby Digital does not allow for 7.1. I don't believe there is a "standard" for 7.1 AAC. Dolby TrueHD and DTS-HD MA cannot be muxed into either MKV or MP4. What would you do with it or am I missing the point?
18th December 2009, 00:23 | #6337 | Link | |
@prospeed what streams did you select in gui? Does this happen with all your movies? Did you try to reinstall ffdshow,Haali media splitter and avisynth? small test 1) When you stuck at 'gathering...' do not press abort. Instead go to job1 folder and copy video.mkv to new folder. 2) close ripbot 3) open copied video.mkv in ripbot. Does it hang now as well? Also show mediainfo report of that copied video.mkv
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th December 2009 at 00:36. |
18th December 2009, 02:50 | #6338 | Link |
Hello Atak,
My first post, so just wanted to say thanks for doing such a great job with ripbot. Now for my question. I am trying to convert Kill Bill, and I can't get forced subtitles to work. I have tried every practical method. And it's either all subtitles on or off. I can't get only forced subtitles to work. Any help? |
18th December 2009, 10:58 | #6339 | Link |
Failed Disc: Terminator Salvation Australian Version BR
v1.14.6 - After a lengthy wait for it to demux and what-not, I'm greeted to MPC-HC open running an AVS error message, something about something else "not talking to me." Going to try again with .5, if that fails I will screen cap the error message for more accurate bug report. The BR uses Seamless branching for two different cuts of the film, might be the problem. EDIT: I've used .5 release for 3 other BR's and they worked fine. I haven't changed any codecs or anything since then either. EDIT: Failure with .5 too. The error is: "DirectShowSource: RenderFile, the filter graph manager won't talk to me (D:\temp\ripbot254temp\job1\getinfo.avs, line 2)" this is the getinfo.avs file, the first line is blank, the second is what you see here... Code:
video=DirectShowSource("D:\temp\RipBot264temp\job1\video.mkv",audio=false).ConvertToYV12() LoadPlugin("C:\Users\Joshie\Downloads\RipBot264v1.14.5\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=RaWavSource("D:\temp\RipBot264temp\job1\audio.1.dtsma.wav",1) AudioDub(video,audio) WriteFile("D:\temp\RipBot264temp\job1\info.txt","Framecount") WriteFile("D:\temp\RipBot264temp\job1\info.txt","Framerate") WriteFile("D:\temp\RipBot264temp\job1\info.txt","AudioRate") WriteFile("D:\temp\RipBot264temp\job1\info.txt","AudioChannels") WriteFile("D:\temp\RipBot264temp\job1\info.txt","AudioLength") WriteFile("D:\temp\RipBot264temp\job1\info.txt","Width") WriteFile("D:\temp\RipBot264temp\job1\info.txt","Height ") Trim(0,-1) Code:
eac3to v3.17 command line: "C:\Users\Joshie\Downloads\RipBot264v1.14.5\Tools\eac3to\eac3to.exe" "H:\" 2) 2: "D:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 4: "D:\temp\RipBot264temp\job1\audio.1.dtsma.wav" -down16 9: "D:\temp\RipBot264temp\job1\9_Subtitles_English.sup" 1: "D:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers ------------------------------------------------------ M2TS, 2 video tracks, 5 audio tracks, 10 subtitle tracks, 1:57:40, 63.514p 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: h264/AVC, 480p24 /1.001 (20:11) 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 5: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 6: DTS Master Audio, Italian, 5.1 channels, 16 bits, 48khz (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz) 7: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 8: DTS Express, English, 2.0 channels, 16 bits, 192kbps, 48khz 9: Subtitle (PGS), English 10: Subtitle (PGS), English 11: Subtitle (PGS), Italian 12: Subtitle (PGS), Danish 13: Subtitle (PGS), Finnish 14: Subtitle (PGS), Hindi 15: Subtitle (PGS), Norwegian 16: Subtitle (PGS), Swedish 17: Subtitle (PGS), English 18: Subtitle (PGS), Italian Creating file "D:\temp\RipBot264temp\job1\chapters.txt"... [v02] Extracting video track number 2... [v02] Muxing video to Matroska... [s09] Extracting subtitle track number 9... [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Reducing depth from 24 to 16 bits... [a04] Writing WAV... [a04] Creating file "D:\temp\RipBot264temp\job1\audio.1.dtsma.wav"... [s09] Creating file "D:\temp\RipBot264temp\job1\9_Subtitles_English.sup"... [a04] Original audio track: max 24 bits, average 16 bits, most common 16 bits. [a04] The processed audio track has a constant bit depth of 16 bits. [a04] Caution: The WAV file is bigger than 2GB. <WARNING> [a04] Some WAV readers might not be able to handle this file correctly. <WARNING> [a04] Audio overlaps for 7ms at playtime 0:01:57. <WARNING> [a04] Audio overlaps for 12ms at playtime 0:08:21. <WARNING> [a04] Audio overlaps for 8ms at playtime 0:10:30. <WARNING> [a04] Audio overlaps for 8ms at playtime 0:13:38. <WARNING> [a04] Audio overlaps for 6ms at playtime 0:16:28. <WARNING> [a04] Audio overlaps for 6ms at playtime 0:38:02. <WARNING> [a04] Audio overlaps for 6ms at playtime 0:54:38. <WARNING> [a04] Audio overlaps for 10ms at playtime 0:59:20. <WARNING> [a04] Audio overlaps for 6ms at playtime 0:59:30. <WARNING> [a04] Audio overlaps for 8ms at playtime 1:01:02. <WARNING> [a04] Audio overlaps for 8ms at playtime 1:04:13. <WARNING> [a04] Audio overlaps for 6ms at playtime 1:18:37. <WARNING> [a04] Audio overlaps for 11ms at playtime 1:39:33. <WARNING> [a04] Audio overlaps for 8ms at playtime 1:42:44. <WARNING> [a04] Audio overlaps for 7ms at playtime 1:46:29. <WARNING> [a04] Starting 2nd pass... [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Reducing depth from 24 to 16 bits... [a04] Writing WAV... [a04] Realizing RAW/PCM gaps... [a04] Creating file "D:\temp\RipBot264temp\job1\audio.1.dtsma.wav"... [a04] The processed audio track has a constant bit depth of 16 bits. [a04] Caution: The WAV file is bigger than 2GB. <WARNING> [a04] Some WAV readers might not be able to handle this file correctly. <WARNING> Added fps value (24 /1.001) to MKV header. Video track 2 contains 169291 frames. Video track 3 contains 151302 frames. Subtitle track 9 contains 798 captions. eac3to processing took 48 minutes, 32 seconds. Done. Code:
eac3to v3.17 command line: "C:\Users\Joshie\Downloads\RipBot264v1.14.5\Tools\eac3to\eac3to.exe" "H:\" -------------------------------------------------------- 1) 00632.mpls, 2:01:59 [100+143+102+104+300+144+183+182+180+145+178+146+176+175+173+172+170+147+168+148+166+149+163+161+152+159+158+156+155+153+151+141].m2ts - Chapters, 10 chapters - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, English, multi-channel, 48khz - DTS Master Audio, Italian, multi-channel, 48khz - DTS Express, English, stereo, 48khz - AC3, English, multi-channel, 48khz 2) 00002.mpls, 1:57:41 [100+101+102+301+300+184+183+181+180+179+178+177+176+174+173+171+170+169+168+167+166+165+162+161+160+159+157+156+154+153+139+142].m2ts - Chapters, 16 chapters - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, English, multi-channel, 48khz - DTS Master Audio, Italian, multi-channel, 48khz - DTS Express, English, stereo, 48khz - AC3, English, multi-channel, 48khz 3) 00001.mpls, 1:54:47 [100+101+102+104+300+184+183+182+180+179+178+177+176+175+173+172+170+169+168+167+166+165+164+163+161+160+159+158+156+155+153+139+235+141].m2ts - Chapters, 16 chapters - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, English, multi-channel, 48khz - DTS Master Audio, Italian, multi-channel, 48khz - DTS Express, English, stereo, 48khz - AC3, English, multi-channel, 48khz 4) 00700.mpls, 0:29:47 [319+318+314+321+320+317+316+315+311+312+313+307].m2ts - Chapters, 11 chapters - h264/AVC, 1080p24 /1.001 (16:9) - AC3, English, stereo, 48khz 5) 00634.mpls, 00308.m2ts, 0:19:01 - h264/AVC, 1080p24 /1.001 (16:9) - AC3, English, stereo, 48khz Last edited by Ingram; 18th December 2009 at 11:55. |
18th December 2009, 14:22 | #6340 | Link | |
Re-ran the Job to get back the 'gathering' stall -- wtf.. it worked as per normal ?? - No idea what happened.. Anyway, Thanks again. |
