Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Thread Tools Display Modes
Old 14th July 2002, 01:16   #41  |  Link
dogman-x
dogman-x's Avatar
Brand: [OptoDisc]
Type: [DVD-R 4.7G for General]
Format: [DVD-R]
Max write speed: [1x]
Unit price: [$1.60]
Retailer: [www.rima.com]
DVD Burner: [Pioneer DVR-104]
DVD burning software: [Nero 5.5.8.2]
Compatibility: [Works in the Recorder, and in 1 of my 2 DVD-ROMs, but in many set-top DVD players it doesn't work well]
Additional notes: [a 10 disc pack jewel cases]
dogman-x is offline   Reply With Quote
Old 14th July 2002, 01:21   #42  |  Link
dogman-x
dogman-x's Avatar
Brand: [Ritek]
Type: [DVD-R 4.7G for General (Silver)]
Format: [DVD-R]
Unit price: [$2.10]
Retailer: [www.mediasupply.com]
Compatibility: [Excellent - Works in every player I've tested except one]
Additional notes: [a 10 disc pack in jewel cases - well packed - I'm ordering more of these]
Old 15th July 2002, 14:30   #43  |  Link
Artur
Dvd Master
Artur's Avatar
Brand: [Infiniti]
Type: [DVD-R 4.7G for General ]
Format: [DVD-R]
Unit price: [$2.10]
Retailer: [www.dvd-and-media.com]
DVD burning software: [Nero 5.5.8.0]
Compatibility: Plays on the A04/104 and my Sony dvp-s-525d and Phillips.
Burnned 10, all worked fine
Artur is offline   Reply With Quote
Old 15th July 2002, 21:46   #44  |  Link
golfextreme
Brand: [DVDPro true 2x]
Type: [DVD-R for genral purpose]
Format: [DVD-R]
Max write speed: [2x]
Unit price: [$2.18]
Retailer: [www.supermediastore.com]
Listed as DVDRPRO2X-025
Bought 25 of these, burned 21, 2 work. CRAP, CRAP, CRAP!
Either thay won't play at all, or they will play to the end and screw up around 3.8gbs.
Pioneer 104
Sony DVP-S360
Still waiting for a reply from supermediastore.
golfextreme is offline   Reply With Quote
Old 15th July 2002, 21:59   #45  |  Link
thxtof
DVD-R Terminator
Brand: [Ritek Gold]
ADVDINFO: ["RITEKG..03"]
Type: [DVD-R]
Format: [v2.0]
Unit price: [$1.29]
Retailer: http://www.supermediastore.com
DVD Burner: [Pioneer A104]
DVD burning software: [Nero 5.5.9]
Compatibility: Plays on the A04 and my Apex 1500.
Did not try on other players.
Nice media, packaged in 2x25 spindle. No problem so far.
Folks could you from now on use ADVDINFO.EXE so we can tell which manufacturer is actually making the DVD ? That would be very helpfull because this way we could tell that 2 different brand in 2 different stores are actually the same.
A good example is Meritline General V2.0 Gold $1.79 = supermediaStore Ritek Gold $1.29 !!! Both are "RITEKG..03" ...
Cheers
THXtoF
thxtof is offline   Reply With Quote
Old 18th July 2002, 05:24   #46  |  Link
ilovecatbus
Brand: [OptoDisc]
Format: [DVD-R]
Unit price: [$1.60]
Retailer: [www.newegg.com]
DVD Burning Software: [Prassi Primo DVD]
Compatability: Toshiba 4700: start skipping around 50% (2.4g)
Apex 1100w : start skipping around 50% (2.4g)
Additional notes: Don't buy this.......
Even I put the same files in the pioneer DVD-RW
And played in the above two players,
the pioneer can play perfectly......
ilovecatbus is offline   Reply With Quote
Old 19th July 2002, 16:21   #47  |  Link
kilikili
Brand: [PrimeDisc]
ADVDINFO: "VIVAST..AR"
Type: [DVD-R]
Format: [v2.0]
Unit price: [$1.50]
Retailer: http://www.shop4tech.com/
DVD Burner: [Pioneer A03/w1.80 firmware]
DVD burning software: [Stomp Record Max]
Compatibility: Panasonic A110 :Perfect
Compatibility: Apex 1100 :Perfect
Compatibility: Playstation2! :YES!!! Absolutely!
I'm simply amazed for such an inexpensive price.
-Kilikili
kilikili is offline   Reply With Quote
Old 22nd July 2002, 17:27   #48  |  Link
Acreff
Brand: [Verbatim]
Type: [DVD+R 4.7G]
Format: [DVD+R]
Unit price: [$6.60]
Retailer: [Local Store]
DVD Burner: [HP-200i]
DVD Burning Software: [Nero 5.5.9.0]
Compatability: Pioneer 525: Perfect
Acreff is offline   Reply With Quote
Old 24th July 2002, 10:25   #49  |  Link
exodious0
Brand: [Verbatim]
Type: [DVD-R for data storage]
Format: [DVD-R]
Unit price: [~€7.00]
Retailer: [local store]
ADVDInfo Lead In (0E): -
DVD Burner: [Pioneer A04]
DVD burning software: [Nero 5.5.9.0]
Compatibility: [Works with Samsung 611]
exodious0 is offline   Reply With Quote
Old 29th July 2002, 00:58   #50  |  Link
bbiandov
Brand: [Generic]
Type: [DVD-R]
Format: [DVD-R]
Unit price: [$1.29]
Retailer: [www.allmediaoutlet.com]
ADVDInfo Lead In (0E): LEAD DATA
Compatibility: [Toshiba SD-2200, xbox, PS/2]
bbiandov is offline   Reply With Quote
Old 1st August 2002, 08:51   #51  |  Link
digisei
Brand: [Datatrack]
Type: [DVD-R]
Format: [DVD-R]
Unit price: [€3,0]
Retailer: [www.nierle.de]
DVD Burner: [Pioneer 104]
Compatibility: [Pinoeer DV525, Sony and a very picky Denon which refuses everything but Pioneer!]
High quality media made in Germany with similar compatibility like Pioneer.
digisei is offline   Reply With Quote
Old 6th August 2002, 17:24   #52  |  Link
jcraven
STI Certified
Brand: STI Certified
Type: DVD-R
Format: DVD-R
Max Write Speed: 1x
Unit Price 5 for $20
Retailer: http://www.sticertified.com
DVD Burner: Panasonic AO3
Software: Nero, Spruce, Prassi
Compatibility: Sony (and probably others)
I know they're not the cheapest but I've never had a bad disk from them. After many frustrations with the cheaper media this seems to be a comfortable middle-ground.
jcraven is offline   Reply With Quote
Old 7th August 2002, 05:19   #53  |  Link
atreides93
Brand: Princo
Type: [DVD-R]
Format: [DVD-R]
Unit price: $1.15
Retailer: meritline
DVD Burner: [Pioneer A03]
Compatibility: I got a 25 pack spindle. So far, no coasters, I only have 3 left. They all play fine on my Oritron DVD600 and my Sony 530D. I also tried two of them on a Pioneer(not sure the model number) DVD player.
ADVDinfo reports them as being Princo, but meritline didn't specify the brand, just said they were unbranded generics.
________
fake weed
atreides93 is offline   Reply With Quote
Old 19th August 2002, 08:35   #54  |  Link
gooki
RITEKG..01
Brand: [Unbranded Printable Discs]
Type: [DVD-R, Printable]
ADVDInfo [RITEKG..01]
Format: [DVD-R]
Colour [Purple/Gold/White printable top]
Max write speed: [No Idea]
Unit price: [$3.00USD]
Retailer: [Privately, New Zealand]
DVD Burner: [104]
DVD burning software: [Primo DVD]
Compatibility, Works 100% in:
XBOX
SOny Playstation 2
Pioneer 105 PC DVD ROM
Sony DVP-S525D standalone
Pioneer DV-525 standalone.
Will keep testing with other players.
Additional notes: Nice discs, I've had two coasters because the dye had flaked, but other than that rather good discs.
gooki is offline   Reply With Quote
Old 28th August 2002, 20:26   #55  |  Link
FWMan
Posts: n/a
Format: [DVD-R]
Colour [Purple/White top]
Max write speed: 2x and 1x]
Unit price: [$1.50USD of 2x and 1.05USD for 1x]
Online: www.caloptic.com
DVD Burner: [A03, 103, 104]
XBOX
SOny Playstation 2
Apex DVD Player
Sony - Table top (forgot the model#)
BOSE DVD player
Inkjet printable DVD available, good discs, made a coaster because did not check DVD complian in the Tool Option of PrimoDVD.
Old 4th September 2002, 08:30   #56  |  Link
bbiandov
Brand: [Memorex]
Type: [DVD-R]
Format: [DVD-R]
Unit price: [$6.29]
Retailer: [www.compusa.com]
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 87 0D 13 .B...@....P.....
88 99 80 00 03 43 4D 43 30 30 52 00 04 47 32 30 .....CMC00R..G20
DVD burning software: [Ulead DVD Movie Factory]
Sold as Memorex DVD-R UPC barcode 3470705510
Part number 3202-2210, works great but pricy and NOT 2x
Old 8th September 2002, 19:23   #57  |  Link
alexnoe
Banned
alexnoe's Avatar
Burner: DVR-A03 (1.80)
Brand: TraxData 1x-2x for general (cdrecord-proDVD says: Vivastar)
Type: DVD-R
Price: 2,50¤
Max Write Speed: 1x (even with 1.90 and even in DVR-A04!!)
Software: DVD Maestro
Player: Panasonic DVD RV32
movie jumps/skips/hangs
Brand: Verbatim DVD-R for general 2.0
Type: DVD-R
Price: 3,70¤
reseller: www.snogard.de
Max Write Speed: 2x
works fine
Brand: Verbatim DVD-RW ver. 1.1
Type: DVD-RW
Price: 5,40¤
Max Write Speed: 1x
works fine
alexnoe is offline   Reply With Quote
Old 14th September 2002, 17:51   #58  |  Link
thxtof
DVD-R Terminator
TDK X2 from eBay
Burner: DVR-A04 (1.30)
Brand: TDK x2 unbranded
Type: DVD-R
Price: $1.99 (100 pack)
reseller: www.ebay.com
ADVDINFO:
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 8A 0D 14 .B...@....P.....
88 88 80 00 03 54 44 4B 47 30 32 00 04 30 30 30 .....TDKG02..000
30 30 30 00 05 CC C0 00 00 00 00 00 00 00 00 00 000.............
Max Write Speed: 2x
Software: Nero 5.5.9.0
Player: Apex 1500
works fine
THXtoF
Old 20th September 2002, 05:32   #59  |  Link
teddykgb
I use a pioneer DVD-106 and stomp recordnow max and I get my dvd-r's from www.americal.com. They have either professional grade or standard grade. I use the standard grade and if memory serves out of over 100 dvd-r's I've had one that did not work. Just one is pretty darn good if you ask me. They burn at 2X and they're not all that pricey either, around $.79 a piece for the standard grade, they come in either white or silver tops and spindles of pretty much any size. Hope this helps yall.
teddykgb is offline   Reply With Quote
Old 20th September 2002, 18:37   #60  |  Link
FWMan
Posts: n/a
Yo ol' fool... Ur RecordMac stated 2x but it does not burn at 2x...You can not get true 2x at $0.79 as of now yet.
How long does it burn?... I bet you it's more than 28min for 4.7GB BTW it doesn't matter how the recording program says, timing is the best way to tell the burnning speed.
Thread Tools
