#3622 | Link |
New build.
Avisynth r4507 https://github.com/pinterf/AviSynthP...3.7.6pre-r4507 Full change log: https://avisynthplus.readthedocs.io/...gelist376.html Code:
20260213 3.7.5.r4507 (pre 3.7.6)
Fix Layer "add" 8 bit, regression in r4504
20260212 3.7.5.r4504 (pre 3.7.6)
* Fix: inaccurate ColorBarsHD 10+ bit values. Now they are derived from the 32-bit float
RGB definitions instead of upscaling a 8 bit precalculated YUV value.
Add Ramp section the lead-in-lead-out.
* Fix: GreyScale + SSE2 + RGB32 + matrix="RGB" overflow.
Rare usage; "RGB" matrix (Identity) uses a 1.0 coefficient which exceeds the signed 16-bit
SIMD limit of 32767 at 15-bit precision. Added bounds checking to fallback to C-code for any
coefficients >= 1.0 or < −1.0.
* Fix: YUV->RGB limited range matrix accuracy for 10-16 bits.
* Use a different rounding in matrix coefficient's integer approximation.
* "ConvertToPlanarRGB": ``bits`` parameter: on-the-fly bit-depth conversions to YUV->RGB conversion.
- Full range target: 8-16 bits internal calculation is in 32-bit float.
- Limited range target: a quicker, bit accuracy optimized integer calculation path.
* Not Fixed: Speed degradation when in-constructor GetFrame(0) (e.g. frame-property getter)
is used. Disable internal Cache object creation. Does not work in complex scripts, preparation
is 5-10 min instead of <1 sec. Investigation continues (Issue #476: https://github.com/AviSynth/AviSynthPlus/issues/476)
* Avoid MTGuard and CacheGuard creation if filter returns one of its clip parameter unaltered.
* Add some avx2 stuff to Layer and Invert
* Optimization: Overlay "Blend": aarch64 NEON optimization
20260203 3.7.5.r4483 (pre 3.7.6)
* rst documentation update: RGBAdjust https://avisynthplus.readthedocs.io/en/latest/avisynthdoc/corefilters/adjust.html
* rst documentation update: ColorYUV https://avisynthplus.readthedocs.io/en/latest/avisynthdoc/corefilters/coloryuv.html
* optimization: add AVX2 TurnLeft/TurnRight/Turn180 (R/L: 1,5-3x speed).
* optimization: ConvertBits AVX2 integer->float
* optimization: ConvertToPlanarRGB(A): YUV->RGB add AVX2 (2-3x speed)
* optimization: ConvertToPlanarRGB(A): YUV->RGB 16 bit: a quicker way (1,5x)
* Fix: C version of 32-bit ConvertToPlanarRGB YUV->RGB to not clamp output RGB values.
* ConvertToPlanarRGB(A): add bits parameter to alter target bit-depth.
* ConvertToPlanarRGB(A): from YUV->RGB full range output: optimized in-process when bits=32, other cases call ConvertBits internally.
* Fix: Packed RGB conversions altering the bit-depth (e.g. rgb32->ConvertToRGB64() worked always in full range.
* Add more AVX512 resampler code. (WIP)
* Add more AVX512_BASE code paths (Resamplers)
* Build: add _avx512b.cpp/hpp pattern in CMake to detect source to compile with base (F,CD,BW,DQ,VL) flags.
However AVX512_BASE itself is set only when AVX512_FAST found.
For pre-Ice Lake (older AVX512) systems you can enable it with SetMaxCPU("avx512base+") and get the optimized AVX512_BASE functions.
* Build: add new architecture z/Architecture
#3623 | Link | |
https://avisynthplus.readthedocs.io/...n_objects.html EDIT: or in function parameter https://avisynthplus.readthedocs.io/...nalfilter.html and in Avisynth source (runtime functions accept function objects) https://github.com/AviSynth/AviSynth...tional.cpp#L61 Last edited by pinterf; 12th February 2026 at 16:03. |
#3624 | Link |
https://github.com/pinterf/AviSynthP...dc7e3c00b321c8
I don't know why are minor DEBUG fixes added? Code:
cache.cpp:745:146: error: macro "_RPT3" passed 6 arguments, but takes just 5
745 | _RPT3(0, "CacheGuard::SetCacheHints called. cache=%p hint=%d (%s) frame_range=%d\n", (void*)this, cachehints, hintname.c_str(), frame_range); // P.F.
In file included from cache.h:38,
from cache.cpp:35:
avisynth.h:157: note: macro "_RPT3" defined here
157 | #define _RPT3(a,b,c,d,e) ((void)0)
cache.cpp: In member function 'virtual int CacheGuard::SetCacheHints(int, int)':
cache.cpp:745:7: error: '_RPT3' was not declared in this scope
#3628 | Link | ||
Formerly davidh*****
![]() Join Date: Jan 2004
unresolved external symbol "public: class PFunction __cdecl AVSValue::AsFunction(void)const " (?AsFunction@AVSValue@@QEBA?AVPFunction@@XZ) ![]() Is it something to do with this? Quote:
PFunction AsFunction() const; // internal use only Last edited by wonkey_monkey; 13th February 2026 at 19:59. |
#3629 | Link | |
if (real_name == nullptr) {
// if name is not given, evaluate expression to get the function
eval_result = func->Evaluate(env);
if (!eval_result.IsFunction()) {
env->ThrowError(
"Script error: '%s' cannot be called. Give me a function!",
GetAVSTypeName(eval_result));
//auto& func = eval_result.AsFunction(); // c++ strict conformance: cannot Convert PFunction to PFunction&
const PFunction& func = eval_result.AsFunction();
real_name = func->GetLegacyName();
real_func = func->GetDefinition();
#3630 | Link |
Meanwhile a hotfix, 8 bit Layer "add" mask problems
New build, sorry for that. Avisynth r4507 https://github.com/pinterf/AviSynthP...3.7.6pre-r4507 |
#3631 | Link | |
Broadcast Encoder
x86-xp build Tested and working on Windows XP Professional x86 ![]() x64-win7-19.44.35221-17.14 build Tested and working on Windows Server 2008 R2 but there seems to be a problem with assembly optimizations somewhere in x64. Code:
SetMaxCPU("none")
video=LWLibavVideoSource("M2991374.mxf")
ch1=LWLibavAudioSource("M2991374.mxf", stream_index=1, fill_agaps=1)
ch2=LWLibavAudioSource("M2991374.mxf", stream_index=2, fill_agaps=1)
audio=MergeChannels(ch1, ch2)
AudioDub(video, audio)
propClearAll()
ConvertBits(16)
Limiter(min_luma=4096, max_luma=60160, min_chroma=4096, max_chroma=60160)
SinPowerResize(1024, 576)
Info()
![]() however if I remove the Code:
SetMaxCPU("none")
![]() which is clearly wrong. Even a simple SetMaxCPU("SSE2") produces the same result which means that only the C++ code is "fine" and there's a problem somewhere in the manually written intrinsics in assembly. Digging a bit further, this seems to be related to 4:2:2 10bit planar and can be reproduced with a simple: Code:
ColorBars(848, 480, pixel_type="YV16") ConvertBits(10) Info() In other words: 8bit planar 4:2:2 with assembly optimizations is fine Code:
ColorBars(848, 480, pixel_type="YV16") Info() ![]() 32bit float 4:2:2 with assembly optimizations is fine Code:
ColorBars(848, 480, pixel_type="YV16") ConvertBits(32) Info() ![]() 10bit, 12bit, 14bit, 16bit planar 4:2:2 with assembly optimization from SSE2 onwards are not Code:
ColorBars(848, 480, pixel_type="YV16") ConvertBits(10) Info() ![]() Code:
ColorBars(848, 480, pixel_type="YV16") ConvertBits(12) Info() ![]() Code:
ColorBars(848, 480, pixel_type="YV16") ConvertBits(14) Info() ![]() Code:
ColorBars(848, 480, pixel_type="YV16") ConvertBits(16) Info()
#3633 | Link | ||
Broadcast Encoder
Jokes aside I triple checked and I can confirm that it only happens on x64 in the Windows 7 build. x86-xp isn't affected. Quote:
![]() Tomorrow morning I'll try the x64-xp build. EDIT: I did, final results: Avisynth_3.7.6_20260213_tst_r4507 - x64-xp - x64-win7-19.44.35221-17.14 8bit planar and 32bit float 4:2:2 ok. problem with 10bit, 12bit, 14bit, 16bit planar 4:2:2 when assembly optimization are used (SSE2 onwards). SetMaxCPU("none") forces C++ which is error free. - x86-xp all ok (8bit, 10bit, 12bit, 14bit, 16bit planar and 32bit float) 4:2:2. Everything is fine both with assembly optimization (tested up to SSE4.2 which is the maximum XP supports). Last edited by FranceBB; 16th February 2026 at 09:41. |
#3634 | Link |
Thanks FranceBB, I thought, it would be super-easy, but I was not able to reproduce it.
EDIT: It's the display, which is using ConvertToRGB32() after that. EDIT: fixed, exchanged G and B in bit-depth changing YUV->RGB full scale code. Last edited by pinterf; 16th February 2026 at 15:28. |
#3635 | Link |
New build.
Avisynth r4523 https://github.com/pinterf/AviSynthP...3.7.6pre-r4523 For online documentation check https://avisynthplus.readthedocs.io/en/latest/ Actual: https://avisynthplus.readthedocs.io/...gelist376.html Code:
20260216 3.7.5.r4523 (pre 3.7.6) -------------------------------- - Fix r4504 regression YUV->RGBP bit-depth changing full-scale SSE2/AVX2 bug (exchanged G,B storage) - "Layer" YUV mul/add/subtract/lighten/darken: refactor chroma placement calculation, allowing SIMD optimization in the main frame processing - "Layer" YUV/RGBP mul/add/subtract/lighten/darken: refactor function dispatchers, add AVX2 path (LLVM/clangcl recommended) - Fix C-only vertical resampling code which added more rounding than needed (regression since pre-3.7.5 20250427) - Invert: per-plane processing for planar formats, use C even in AVX2, proper chroma inversion - New: AddAlphaPlane opacity parameter - New: ResetMask opacity parameter - rstdoc: document "opacity" in AddAlphaPlane and ResetMask - rstdoc: detail Layer "use_chroma" and opacity - Overlay "Blend": more speed, but keep accuracy, use float only where really needed - Layer: use YV16 internally for YUY2 (lessen source bloat) 20260213 3.7.5.r4507 (pre 3.7.6) -------------------------------- Fix Layer "add" 8 bit, regression in r4504 20260212 3.7.5.r4504 (pre 3.7.6) -------------------------------- * Fix: inaccurate ColorBarsHD 10+ bit values. Now they are derived from the 32-bit float RGB definitions instead of upscaling a 8 bit precalculated YUV value. Add Ramp section the lead-in-lead-out. * Fix: GreyScale + SSE2 + RGB32 + matrix="RGB" overflow. Rare usage; "RGB" matrix (Identity) uses a 1.0 coefficient which exceeds the signed 16-bit SIMD limit of 32767 at 15-bit precision. Added bounds checking to fallback to C-code for any coefficients >= 1.0 or < −1.0. * Fix: YUV->RGB limited range matrix accuracy for 10-16 bits. * Use a different rounding in matrix coefficient's integer approximation. * "ConvertToPlanarRGB": ``bits`` parameter: on-the-fly bit-depth conversions to YUV->RGB conversion. - Full range target: 8-16 bits internal calculation is in 32-bit float. - Limited range target: a quicker, bit accuracy optimized integer calculation path. * Not Fixed: Speed degradation when in-constructor GetFrame(0) (e.g. frame-property getter) is used. Disable internal Cache object creation. Does not work in complex scripts, preparation is 5-10 min instead of <1 sec. Investigation continues (Issue #476: https://github.com/AviSynth/AviSynthPlus/issues/476) * Avoid MTGuard and CacheGuard creation if filter returns one of its clip parameter unaltered. * Add some avx2 stuff to Layer and Invert * Optimization: Overlay "Blend": aarch64 NEON optimization 20260203 3.7.5.r4483 (pre 3.7.6) -------------------------------- * rst documentation update: RGBAdjust https://avisynthplus.readthedocs.io/...rs/adjust.html * rst documentation update: ColorYUV https://avisynthplus.readthedocs.io/.../coloryuv.html * optimization: add AVX2 TurnLeft/TurnRight/Turn180 (R/L: 1,5-3x speed). * optimization: ConvertBits AVX2 integer->float * optimization: ConvertToPlanarRGB(A): YUV->RGB add AVX2 (2-3x speed) * optimization: ConvertToPlanarRGB(A): YUV->RGB 16 bit: a quicker way (1,5x) * Fix: C version of 32-bit ConvertToPlanarRGB YUV->RGB to not clamp output RGB values. * ConvertToPlanarRGB(A): add bits parameter to alter target bit-depth. * ConvertToPlanarRGB(A): from YUV->RGB full range output: optimized in-process when bits=32, other cases call ConvertBits internally. * Fix: Packed RGB conversions altering the bit-depth (e.g. rgb32->ConvertToRGB64() worked always in full range. * Add more AVX512 resampler code. (WIP) * Add more AVX512_BASE code paths (Resamplers) * Build: add _avx512b.cpp/hpp pattern in CMake to detect source to compile with base (F,CD,BW,DQ,VL) flags. However AVX512_BASE itself is set only when AVX512_FAST found. For pre-Ice Lake (older AVX512) systems you can enable it with SetMaxCPU("avx512base+") and get the optimized AVX512_BASE functions. * Build: add new architecture z/Architecture |
#3636 | Link |
Broadcast Encoder
Thanks for the new build and for fixing the issue, Master Ferenc.
Avisynth_3.7.6_20260216_tst_r4523 x64-win7-19.44.35221-17.14 Windows Server 2008 R2 x64 Now 4:2:2 10bit/12bit/14bit/16bit work correctly with assembly optimizations up to SSE4.2 as well. ![]() x86-xp Windows XP Professional x86 works normally as usual
#3638 | Link |
Here's a new pre-release build.
Latest test build Avisynth+ v3.7.6pre-r4529 test build (20260220) For online documentation check https://avisynthplus.readthedocs.io/en/latest/ Actual full change log: https://avisynthplus.readthedocs.io/...gelist376.html As a result of a chain reaction. After ColorBarsHD 10+ bit was fixed, I did the same update to ColorBars, with almost a full rewrite. Additionally I fixed the reported color matrix as well. I wanted then to visualize the changes, and it turned out that the existing vectorscope (color, color2) is quite basic. So I added a lot of options to them (for details, see https://avisynthplus.readthedocs.io/...histogram.html), made them matrix and color range aware. Made them accurate (rounding, proper scaling to visible vectorscope area from full or limited range colors). That was another 3/4 rewrite, refactor. So enjoy this new build, I'm sure FranceBB will be happy to test the new color/color2 overlay flags and you all would give me additional ideas.Code:
20260220 3.7.5.r4529 (pre 3.7.6) -------------------------------- - Fix Colorbars inaccurate 10+ bit, by using ground truth linear RGB, similarly to ColorBarsHD. - Fix reporting 709 matrix instead of the 601 (170m) - Full refactoring. - update doc: https://avisynthplus.readthedocs.io/...colorbars.html - Histogram "color" and "color2" (Vectorscope modes) - almost full refactoring. - Drawing is now matrix and color range aware. target positions (75%) +-I and +Q. - add individual overlay options: added ``matrix``, ``graticule``, ``targets``, ``axes``, ``iq``, ``iq_lines``, ``circle`` parameters - Fix: copy alpha from clip, initialize alpha to zero in the histogram area. - Accurate pixel positioning and scaling to the active histogram area, limited/full range aware. - update doc: https://avisynthplus.readthedocs.io/...histogram.html 20260216 3.7.5.r4523 (pre 3.7.6) -------------------------------- - Fix r4504 regression YUV->RGBP bit-depth changing full-scale SSE2/AVX2 bug (exchanged G,B storage) - "Layer" YUV mul/add/subtract/lighten/darken: refactor chroma placement calculation, allowing SIMD optimization in the main frame processing - "Layer" YUV/RGBP mul/add/subtract/lighten/darken: refactor function dispatchers, add AVX2 path (LLVM/clangcl recommended) - Fix C-only vertical resampling code which added more rounding than needed (regression since pre-3.7.5 20250427) - Invert: per-plane processing for planar formats, use C even in AVX2, proper chroma inversion - New: AddAlphaPlane opacity parameter - New: ResetMask opacity parameter - rstdoc: document "opacity" in AddAlphaPlane and ResetMask - rstdoc: detail Layer "use_chroma" and opacity - Overlay "Blend": more speed, but keep accuracy, use float only where really needed - Layer: use YV16 internally for YUY2 (lessen source code bloat) |
#3639 | Link |
Great. We again can use the good skin tone mark at the vectorscope.
About program text comments of linear RGB: The colour bars are not in linear RGB (scene linear light). They are in system transfer domain encoding. The RGB sources for colour bars in the documents are defined simply to check the matrix/dematrix in distribution but not check transfer conversion too. With 2-levels current colour bars sources it is not an issue because they do not contain transfer-dependent transients. Though some old documents indirectly point to the 'conditioning domain' or colour bars and it is a system transfer domain (not linear-light RGB). It may be designed to make DAC and levels checking at waveform monitors more easy. As I understand, close to zero waveform monitors can do transfer conversion to linear before DAC or other way of interpolated (upscaled) waveform draw (render). So it may be put to the notes section of ColorBars filter: The output is not conditioned to any transfer domain (and it is partially good) and has direct switch transients between levels. The levels are set as defined in the colour bars standard but it is not 75% linear RGB. It is 75% RGB still in system transfer domain encoding (to mark it sometime and in the ITU/EBU documents used R'G'B'). To condition in any required domain for frequency-limited (Nyquist) channel can be used sequence of: Code:
#to condition transients in transfer domain R'G'B' with 75% in transfer domain ColorBars(target_width*10, target_height*10, pixel_type="RGB") UserDefined2Resize(width/10, height/10) #not perfectly match the recommended ITU filter response #to condition transients in linear domain RGB with 75% in transfer domain ColorBars(target_width*10, target_height*10, pixel_type="RGB") #convert transfer to linear RGB (no AVS+ filter currently exist - use avsresize ?) UserDefined2Resize(width/10, height/10) #not perfectly match the recommended ITU filter response #convert transfer to target domain R'G'B' (no AVS+ filter currently exist - use avsresize ?) Also additional frame/clip properties to mark: 1. Current transfer domain 2. Target conditioning transfer domain for resizing About real ITU transients shaping filter: https://www.itu.int/dms_pubrec/itu-r...0-W!!PDF-E.pdf 1 Formulae : the filter impulse response is a Blackman window. We have BlackmanResize with the same (or close) window function https://github.com/AviSynth/AviSynth...tions.cpp#L133 . To make required frequency shaping filter we need to use this window as filter kernel and scale for timing as defined in the recommendation: for –3T < t < 3T, R(t) = 0.42 + 0.50 cos(π t/ 3T) + 0.08 cos(2π t/ 3T) – otherwise R(t) = 0 (filter_support is 3T ?) . The value of T is 74 ns for digital waveforms A1, A2, A3 and A4 and 148 ns for A5 and A6. To make filtering more simple - all colour bars may be filtered with a single filter of T=74ns (very close to 1 step between target samples, 1/74ns is 13.513 MHz and 1 sample step in PAL/rec.601 is duration of 1/13.5 MHz).A separate 'resize' named filter can be added to Resize filters like BlackmanITUResize(). Users can use it for getting better conditioned ColorBars or for some other conditioning workflows if the exact Blackman-type response is required. Last edited by DTL; 22nd February 2026 at 10:03. |
#3640 | Link | ||||
Broadcast Encoder
I'm so happy right now. This is a very unexpected present, so thank you!
About the colorbars, we've got ColorBars() for BT.601, ColorBarsHD() for BT.709, are we gonna get ColorBarsUHD() for BT.2020? ![]() Something appears to be off in Histogram, though, as this: Quote:
![]() This was tested using the x86-xp build on Windows XP Professional x86 and using the x64-win7-19.44.35221-17.14 build on Windows Server 2008 R2 Standard x64. Other than that, I can happily confirm that Quote:
![]() ![]() ![]() Left: x86-xp build on Windows XP Professional x86 --- Right: x64-win7-19.44.35221-17.14 build on Windows Server 2008 R2 Standard x64 Last edited by FranceBB; 2nd March 2026 at 10:15. |
| Thread Tools | |
| Display Modes | |
