#1362 | Link |
After remuxing movie (Bob Marley- One Love 2024) with tsmuxer Gui (from 05.12.2024) Dolby Atmos sound is not synchronized with the movie and subtitles. The sound on the Bluray disc without remux works flawlessly! Has anyone else encountered this problem?
#1363 | Link |
I don't know what you exactly imported in tsMuxer, but when importing the proper playlist (*.mpls file from BD's native PLAYLIST folder), IME certain issues can be avoided.
You can use BDInfo to see what mpls points to what m2ts file(s). |
#1364 | Link |
I import 00001.mpls in tsmuxer gui. After remuxing movie (Bob Marley- One Love 2024) with tsmuxer Gui (from 05.12.2024) Dolby Atmos sound is not synchronized with the movie and subtitles.
The sound on the Bluray disc without remux works flawlessly! Has anyone else encountered this problem? Last edited by malimuc; 28th May 2024 at 14:58. |
#1365 | Link |
Hi malimuc, try this test to verify the problem, extract the tracks with DGDemux then remux them with tsMuxer, adding them following the initial Bluray scheme, finally test to see if you have synchrony with Atmos audio.
https://www.rationalqm.us/dgdemux/dgdemux.html Last edited by ocean; 27th May 2024 at 18:56. |
#1366 | Link |
Yes, DGDemux is the best BD demuxer in my book too.
Also, when using tsMuxer to mux to BD (ISO or folder structure), type value 524280 in the "45 KHz clock" window (Blu-ray tab). It's said to be vital for a proper BD mux and it indeed proofed to be working for the BD remuxes I did. If one is interested in reading about this, see https://forum.doom9.org/showthread.p...10#post1916110 |
#1367 | Link | |
Thanks man. If there were more people like you in the world, the world would be a much better. |
#1368 | Link | |
#1369 | Link |
hello, want to ask, why tsmuxer gui can't recognized it ?
Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 2 h 1 min Bit rate mode : Variable Bit rate : 2 761 kb/s Maximum bit rate : 4 044 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 2.35 GiB (7%) Title : BTM TrueHD Atmos 7.1 Language : English Default : Yes Forced : Yes Source : Universal Studios Blu-ray (2024) Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE |
#1370 | Link | |
Life's clearer in 4K UHD
#1371 | Link |
it's 2.6.12 , i try with another , it's same , not recognized
Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 1 h 43 min Bit rate mode : Variable Maximum bit rate : 7 125 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Bit depth : 24 bits Compression mode : Lossless Language : English Default : Yes Forced : No Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE |
#1372 | Link |
You need to use the newer open source 'git builds'.
See post 1 in this topic for links.
#1376 | Link |
Many thanks to everyone who took the time to bring this wonderfull application to this level.
Personally I can't think of any improvements that can be made to it. Very nice work indeed
#1377 | Link |
Hello justdan96!
Many thanks for all the work that you and everyone involved put into this outstanding one-of-its-kind software. It is and will be indispensable to me and probably to many others for many, many years to come. Thank you! Best regards, varekai |
#1378 | Link |
Big Bit Savings Now !
![]() Join Date: Feb 2007
Many thanks from me too to all involved for all that effort.
Where would be be without...
#1380 | Link |
Another one that adds to the thanks for all the great work done to provide us with this indispensable tool. Hopefully it can be continued in its development by others.
Thank you very much justdan96 and all the team that invested so many hours in the development! |
| Thread Tools | |
| Display Modes | |
