Thread Tools Display Modes
Old 11th June 2025, 16:17   #821  |  Link
Bily
Why does the screen flicker when we open a 4K video in mpc-hc madvr? When we switch to full screen and lower resolutions, this doesn't happen?
Thanks
Bily is offline   Reply With Quote
Old 11th June 2025, 19:01   #822  |  Link
the switch to HDR trigger a resync.
real FSE will also do that so it changing the resolution.
Old 11th June 2025, 19:25   #823  |  Link
Bily
I installed here: msi afterburner
and noticed that with my configuration the GPU usage is at 80%
What is the maximum percentage of GPU usage you recommend for use with madvr?
Thanks
Old 11th June 2025, 20:38   #824  |  Link
there is no general answer to that. as long as madVR isn't dropping frames actively it is fine.
Old 12th June 2025, 19:43   #825  |  Link
Bily
How to remove compression noise (macroblocks) in madvr? Or by another resource of mpc-hc?
And other types of noise, what is the most appropriate way to remove them?
Thanks
Old 12th June 2025, 22:11   #826  |  Link
remove compression artifacts and remove random noise should be the stuff you are looking for.
they are very expensive to use.
Old 12th June 2025, 22:57   #827  |  Link
Bily
Is there any shader or filter for mpc-hc that does this well and is lightweight?
Another question :
Is there any feature, in VGA or MADVR, that reduces the image quality of the video over time? Even if the options in the folder: trade quality for performance are turned off?
Thanks
Old 13th June 2025, 06:02   #828  |  Link
over time no.
Old 15th June 2025, 20:27   #829  |  Link
Bily
Here the quality drops after 30 minutes of filming.
The GPU usage does not exceed 88%.
Is there any configuration I can do so that the image quality does not drop over time?
Thanks
Old 16th June 2025, 03:31   #830  |  Link
filming?
there is nothing in madVR, mpv or any other renderer i know that can drop quality over time.
Old 7th July 2025, 23:03   #831  |  Link
Gladzilla
Thanks
Not sure but the 2070 super I am using hits 90+ % usage. I cannot tell a real difference when using madvr.
Gladzilla is offline   Reply With Quote
Thread Tools
