13th March 2020, 22:04 | #601 | Link | |
Life's clearer in 4K UHD
I'm yet to find one in an elementary form...
13th March 2020, 23:08 | #602 | Link | |
Maybe somebody on doom9 has access to a professional TS muxer and will manage to mux this sample... |
14th March 2020, 00:27 | #603 | Link | |
14th March 2020, 09:25 | #604 | Link | |
Anyway, it throws error, that numblkscod shall be set to 11b (6 blocks per syncframe), but actual numblkscod is set to 0 |
14th March 2020, 15:26 | #605 | Link | |
The version I downloaded from Dolby's web site way back in 2007 included an AC3 core, so it's great to have this version without a AC3 core too. Many thanks. When the EAC3 audio stream is muxed together with a 24fps HEVC or AVC video stream into the .m2ts container, my findings are as follows: - My LG TV detects the .m2ts file okay however, the audio stream is not recognised. My OPPO detects the .m2ts file okay, however, the video runs at around twice normal speed. But the EAC3 audio stream plays perfectly. By contrast, if I mux the same audio and video streams into the .mkv container, the LG TV and the OPPO plays them perfectly including the audio.
14th March 2020, 18:53 | #606 | Link | |
Edit: [ATSC A/52:2018 Annex G] "six blocks of audio data from every substream present in the E-AC-3 stream shall be included in the PES packet payload. As an E-AC-3 syncframe may contain fewer than six blocks of audio data, it may be necessary to group multiple syncframes to accumulate the required six blocks." Last edited by a5180007; 14th March 2020 at 19:03. |
14th March 2020, 19:31 | #607 | Link |
Don't all EAC3 audio streams as used with the Blu-ray disc format contain an AC3 core?
EDIT: Scratch the above... I've just backed-up the 'Black Panther' 4K UHD disc and it contains three 7.1 channel EAC3 tracks without an AC3 core!
14th March 2020, 21:50 | #609 | Link |
Sorry for the confusion. I've just checked again and the 7.1 channel EAC3 audio streams 'do' have an AC3 core.
14th March 2020, 23:34 | #611 | Link |
As i can see, standard 7.1 eac3 can be muxed only as secondary audio in mpeg-ts for 1080 blu-ray only. I can do this but it's useless i think. For main audio we need "BD compatible" eac3 (BD target|eb3)
15th March 2020, 17:28 | #613 | Link | |
The subtitles bug continue. When i remux a movie with DV to bluray folder the subtitles littler a littler go out of sync. Movies with no DV subtitles work ok. baker99 say: I regularly get the message "B-pyramid level 2 detected. Shift DTS to 3 frames", I think it's normal and to do with timestamps, some information here: https://bitmovin.com/docs/encoding/f...ied-by-default In a movie with DV i not see that message. DV tsMuxeR version git-11fcb24. github.com/justdan96/tsMuxer HEVC muxing fps is not set. Get fps from stream. Value: 23.976 HEVC muxing fps is not set. Get fps from stream. Value: 23.976 Decoding TRUE-HD stream (track 3): AC3 core+TRUE-HD. Peak bitrate: 3363Kbps (core 448Kbps) Sample Rate: 48KHz Channels: 7.1 Decoding AC3 stream (track 4): Bitrate: 192Kbps Sample Rate: 48KHz Channels: 2 Decoding AC3 stream (track 5): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 5.1 Decoding AC3 stream (track 6): Bitrate: 192Kbps Sample Rate: 48KHz Channels: 2 Decoding AC3 stream (track 7): Bitrate: 192Kbps Sample Rate: 48KHz Channels: 2 Decoding PGS stream (track 9): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 10): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 8): Resolution: 1920:1080 Frame rate: 23.976 Processed 187324 video frames Processed 187324 video frames Flushing write buffer Creating Blu-ray stream info and seek index Creating Blu-ray playlist Mux successful complete Muxing time: 20 min 28 sec No DV tsMuxeR version git-11fcb24. github.com/justdan96/tsMuxer HEVC muxing fps is not set. Get fps from stream. Value: 23.976 Decoding TRUE-HD stream (track 2): AC3 core+TRUE-HD. Peak bitrate: 7800Kbps (core 640Kbps) Sample Rate: 48KHz Channels: 7.1 Decoding AC3 stream (track 3): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 5.1 Decoding AC3 stream (track 4): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 5.1 B-pyramid level 2 detected. Shift DTS to 3 frames Decoding PGS stream (track 5): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 6): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 7): Resolution: 1920:1080 Frame rate: 23.976 AC3 stream (track 3): overlapped frame detected at position 00:11:53,823. Remove frame. AC3 stream (track 4): overlapped frame detected at position 00:11:53,823. Remove frame. Processed 146513 video frames Flushing write buffer Creating Blu-ray stream info and seek index Creating Blu-ray playlist Mux successful complete Muxing time: 5 min 32 sec |
15th March 2020, 17:52 | #614 | Link |
@cogira this is an old GUI. V2 was former Bluray format for AVC, V3 is the newer format for HEVC/UHD. Now the V3 mode is selected automatically when HEVC is detected, and there is a checkbox option to force V3 if needed for AVC.
15th March 2020, 19:36 | #616 | Link |
Error in tsMuxer at following progress:
1. Add to tsMuxer UHD Bluray with HEVC and select automatically Bluray V3 format 2. Remove from tsMuxer UHD Bluray 3. Add Bluray with h.264 and Bluray V3 format is always selected (checked) |
15th March 2020, 20:21 | #617 | Link | |
My LG TV detects the 'HEVC+AC3+EAC3.m2ts' file okay, and plays the AC3 audio stream perfectly. But it can't detect the EAC3 audio stream. My OPPO detects the 'HEVC+AC3+EAC3.m2ts' file okay, and plays the AC3 audio stream perfectly. But as soon as I select the EAC3 audio stream the OPPO becomes unstable and plays the video a twice normal speed!
15th March 2020, 21:41 | #618 | Link |
@SeeMoreDigital it is normal that your version does not work with EAC3, the EAC3 patch has just been merged. Could you please carry out the test with tomorrow's bintray version. Note that 7.1 EAC3 will not work.
15th March 2020, 23:07 | #619 | Link |
Okay... Will do...
19th March 2020, 22:09 | #620 | Link | |
From yusesope
