Old 22nd November 2013, 08:22   #281  |  Link
Sharc
I'll just have to caveat the 3D support with "requires Windows 7 or above" and do an O/S check before enabling 3D processing. I'm convinced FRIMDecode/FRIMEncode is the way to go.
Did you try again with DirectShowSource and DirectShowMVCSource? Still no luck?
I am asking because I had for the first time success with DirectShowMVCSource without crashing FRIMEncode or "loosing" one of the views after some time. Thanks to FRIMEncode Version 1.16 or just a lucky punch? I don't know.
Added:
Hmmm......seems to work stably now with FRIMEncode 1.16.
If it truly works, DirectShowMVCSource would be very convenient as one can start from the .ssif directly and add video processing to the .avs script as needed.....
Old 22nd November 2013, 09:47   #282  |  Link
colinhunt
A 77-minute long 3D movie has now been transcoding for 8 hours, with quality set to 3, decoding in software and encoding in hardware. CPU usage hovers around 75-80%.
Videofan3d, would it be possible to implement some sort of percentage display so the user could see how much of the movie has been processed? An "Estimated time remaining" would be even nicer, actually, but not sure if such a thing is possible here.
colinhunt is offline   Reply With Quote
Old 22nd November 2013, 11:00   #283  |  Link
videofan3d
Transcoder operates in multi session, so you can run in parallel several decoding-encoding sessions (you can try it ).
Displying progress for each session would be confusing.
Remember: FRIM are command-line tools (I like unix-style ) which have certain presentation limitations - and on the other hand sigificant advantage in scripting integration.
Transcoder displays dot '.' after each 100 decoded frames.
videofan3d is offline   Reply With Quote
Old 22nd November 2013, 11:05   #284  |  Link
colinhunt
Scripting and all this command line brouhaha is usually too difficult for my limited skills, unfortunately :/
I was wondering about those! OK, the dots are some help in that case.
The transcode finished a moment ago. It took almost exactly 9 hours to process 110237 frames... and it looks like I miscalculated the bitrate, as the output file is larger than the source avc + mvc combined. It should have been smaller to fit on a BD25. Welp, at least I have an excuse to run the same encode again, this time in software only and with slightly lower bitrate
Old 22nd November 2013, 11:10   #285  |  Link
videofan3d
This is why Transcoder uses several sessions in parallel.
You can write par file like e.g. this:
-i::h264 input.avc -o::sink
-i::source -o::h264 output12.h264 -vbr 12000 24000
-i::source -o::h264 output17.h264 -vbr 17000 24000
-i::source -o::h264 output21.h264 -vbr 21000 24000
and create several output within one pass.
Of course, it consume more CPU for several parallel encodings, but only one decoding !
Old 22nd November 2013, 11:14   #286  |  Link
colinhunt
Oh, I understand its use now. That's very clever! I'll give it a shot right away.
Still, I hope that one day soon there'll be a GUI for all this
Old 22nd November 2013, 11:14   #287  |  Link
trevorjharris
Minor update FRIM 1.16 is available.
Key changes:
FRIM Encoder 1.16
- workaround for Avisynth error (occasionally Avisynth 2.5.8 doesn't feed R-eye in -sbs mode) - please try if it helped
FRIM Encoder and Transcoder 1.16
- allowed bitrate higher than 65000 Kbps (although I personally doubt whether it is reasonable and useful )
(rest is in Release notes)
Just tried an avs file and it still does not work.
trevorjharris is offline   Reply With Quote
Old 22nd November 2013, 11:20   #288  |  Link
videofan3d
What is your script?
And please describe symptoms of the problem.
Old 22nd November 2013, 11:35   #289  |  Link
Cedvano
FRIMTranscode GUI 1.04
version 1.04
- Add SSIF and MPLS support
- Include tsMuxer by Roman/Physic
Cedvano is offline   Reply With Quote
Old 22nd November 2013, 11:48   #290  |  Link
colinhunt
Originally Posted by Cedvano View Post
version 1.04
Thanks!
Old 22nd November 2013, 11:48   #291  |  Link
Sharc
Key changes:
FRIM Encoder 1.16
FRIMEncode 1.16 works now with DirectShowMVCSource here. The crashes and/or skips of 1.15 seem to be gone
Old 22nd November 2013, 11:50   #292  |  Link
colinhunt
So I tested running several sessions in parallel. Here's the par file contents:
-sw -i::mvc left.264 right.mvc -o::sink -length 3500
-hw -i::source -o::mvc clip_hw_33mbps_labrc.264 -labrc 33000 0 -profile high -level 4.1 -u 4 -l 6 -cpbsize 3750 -gop 24 4 0 O
-hw -i::source -o::mvc clip_hw_33mbps_vbr.264 -vbr 33000 48000 -profile high -level 4.1 -u 4 -l 6 -cpbsize 3750 -gop 24 4 0 O
-sw -i::source -o::mvc clip_sw_33mbps.264 -vbr 33000 48000 -profile high -level 4.1 -u 4 -l 6 -cpbsize 3750 -gop 24 4 0 O
And this is what happened:
Transcoding started
Return on error: error code -16,        .\src\pipeline_transcode.cpp    858
Return on error: error code -16,        .\src\pipeline_transcode.cpp    693
Transcoding finished
MFX session 0 transcoding FAILED
Processing time: 491.41 sec
Number of processed frames: 2154
MFX session 1 transcoding FAILED
Processing time: 303.34 sec
Number of processed frames: 1060
MFX session 2 transcoding FAILED
Processing time: 491.61 sec
Number of processed frames: 1077
MFX session 3 transcoding FAILED
Processing time: 491.59 sec
Return on error: error code 1,  .\src\sample_multi_transcode.cpp        629
It actually ran quite a while before "Return on error" happened. Could this be caused by LA BRC, i.e. look-ahead bitrate control? Should I have used -async (and how)?
update: ran the exact same params, but with one addition to line 1: "-async 2". Transcoding finished without errors this time.
This is a bit odd:
Session 3:
Media SDK impl          SOFTWARE (C:\Users\xxx\encoders\libmfxhw32.dll)
Media SDK version       1.7
Memory type             system
Session 3 is encoding on software, and yet it lists the Hardware DLL. Correct DLL is listed for sessions 0-2, however.
Old 22nd November 2013, 12:36   #293  |  Link
videofan3d
Transcoding started
This all is likely related to -hw option, maybe some constraints of GPU.
(I cannot test HW acceleration yet - hopefully in next few weeks I'll have access to Haswell to check and tune it )
Old 22nd November 2013, 12:49   #294  |  Link
colinhunt
Probably. Adding -async seems to have solved it, though.
Old 22nd November 2013, 13:21   #295  |  Link
colinhunt
Haven't got the foggiest idea how this happened or who did it... but some software/hardware encoding comparison files are located here.
Old 22nd November 2013, 13:43   #296  |  Link
frencher
French Love
Key changes:
FRIM Encoder 1.16
Cool interest update
Thank's videofan3d
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 22nd November 2013, 13:59   #297  |  Link
colinhunt
What the... For poops and giggles, I tried to run FRIMTranscode in Hardware mode on i7-3930K. I was under the impression 3930K lacks the required hardware entirely, but nope, Transcode proceeded to run with -hw option just fine.
1000 frames on 3930K (u4)
hw decode 61.33 sec
hw encode (LA BRC) 62.01 sec (garbled output)
sw decode 58.66 sec
hw encode (LA BRC) 59.31 sec
sw decode 56.77 sec
hw encode (vbr) 57.42 sec
sw decode 52.04 sec
sw encode (vbr) 52.75 sec
sw decode 51.92 sec
sw encode (LA BRC [shouldn't work with -sw]) 52.66 sec
Compared -sw vbr and -sw labrc encoded outputs. Both are the same size, 84 523KB, but MediaInfo reports something interesting:
VBR: Maximum bit rate - 21.8 Mbps (-vbr 34000 40000)
LA BRC: Maximum bit rate - 62.5 Mbps (-labrc 34000 0)
Old 22nd November 2013, 14:06   #298  |  Link
Sharc
Only with Stereoscopic Player, not with TMT6.
For me, I think is SP.
I don't think it's Stereoscopic Player.
- the base and dependent views of the transcoded combinedMVC.h264 seem to be ok. Both views playback without problems.
- the glitch (garbled picture) comes only after remuxing the combinedMVC.h264 to .m2ts or ISO with tsMuxeR => the dependent view gets garbled and playback stops.
I noticed that tsMuxeR had to modify the h264 bitstream by inserting nal unit delimiters for some reason.
Anyway, I did it again using pipes instead of transcode and everything seems to be ok now.
I guess I put this problem aside for now. I may try transcoding later again with version 1.16.
Old 22nd November 2013, 14:44   #299  |  Link
videofan3d
Understand it might be "strange"...
I will check and tune -hw option once being able to use I7 for development...
Old 22nd November 2013, 19:06   #300  |  Link
nunub
@cedvano
Thanks for ur effort in producing a gui for frim transcoder but it would be still nicer for the whole 3d community to get a gui for frim encoder too.
nunub is offline   Reply With Quote
encoders, mvc
