Old 4th January 2020, 11:11   #201  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Originally Posted by Michi View Post
I tested several UHD-DV remuxes on my Sony X800M2 and the Sony crashed on all DV remuxes. UHD remuxes without DV plays the Sony without problems.
How are you playing these Dolby Vision UHD re-muxes. Are you burning discs?
Old 4th January 2020, 11:28   #202  |  Link
Michi
I burn the remuxes on BD-RE 50
Michi is offline   Reply With Quote
Old 4th January 2020, 11:34   #203  |  Link
SeeMoreDigital
Originally Posted by a5180007 View Post
@SeeMoreDigital I thought having fixed this weeks ago. Have you tried to mux TrueHD+AC3 core with latest version ?
To confirm...
THD with AC3 core works fine. This is what I see when I try to import a Dolby TrueHD elementary stream without core, which is what @filler56789 was asking about: -
Cheers
Old 4th January 2020, 14:32   #204  |  Link
outgoing
With the last build (nightly-2020-01-02--01-10-53) in some tests the bluray remux have the correct stn table, which was not the case with the penultimate build (nightly-2020-01-01--01-10-57). On the other hand, without being exhaustive, when I make a negative delay for syn for more than a 1000 ms (pe: -1234) in DTS-HDMA audios the final remux does not play well in the players. If I apply this delay with the eac3to it makes valid remux.
outgoing is offline   Reply With Quote
Old 4th January 2020, 15:22   #205  |  Link
SeeMoreDigital
I've just tested '2020-01-04--01-10-41' with some Dolby Vision sources and sadly it's not able to create muxes that can be played with my OPPO
Old 4th January 2020, 16:37   #206  |  Link
Michi
DV remuxes with the github version plays my Sony X800M2 without problems. I used Bluray-Folder for muxing and I have chapters.
Old 4th January 2020, 17:17   #207  |  Link
Bandits
Request if someone can post a copy of a Meta file output from a UHD disc with DV, all tracks selected, chapters present, and output set to Blu-Ray folder.
I do not own any UHD disc's but I would like to see the new Meta file settings for UHD with DV.
Blu-Ray Ripper 0.112b/0.2b
Bandits is offline   Reply With Quote
Old 5th January 2020, 04:44   #208  |  Link
xledentaldj
Fury UHD BDMV meta from MacOS
jan.5th nightly build:
https://mega.nz/#!QYpUQKzT!l2AcTzu30...jur-4fkOZML39M
Ive noticed a my MacOS 10.13.6 tsmuxer GUI bug when trying to save as UHD BDMV folder it tries to save to a folder
location as a .ts file. Also if you use UHD BD iso
you get no option to create Volume Lable of movie
iso.
__________
M9702 Oppo 203 Clone
xledentaldj is offline   Reply With Quote
Old 5th January 2020, 06:01   #209  |  Link
Bandits
iso.
That meta file doesn't seem to show Dolby Vision. Also the output options and video type seem strange for a UHD movie.
Old 5th January 2020, 12:32   #210  |  Link
maxibon
Hi
Ive tested latest build 2020-01-05--01-10-23 trying to replace audio and subtitles in a UHD Bluray folder but with no succes.
Audio is fine but subtitles disappear, chapters remain
Tested on Oppo 203
maxibon is offline   Reply With Quote
Old 5th January 2020, 12:33   #211  |  Link
HaDiHo
Mkv to UHDIso (Player 0ppo203) now and then pixel errors in the film when changing chapters
HaDiHo is offline   Reply With Quote
Old 5th January 2020, 12:48   #212  |  Link
SeeMoreDigital
I've just tested the '2020-01-05--01-10-23 w64-nightly' build with some Dolby Vision sources and it's not able to create muxes that can be played with my OPPO...
Old 5th January 2020, 13:31   #213  |  Link
xledentaldj
Oops, I though Fury had DV, My Halloween does but once I add
the playlist, MacOS TsMuxer build spits up an error:
Assertion failed: (num<=Int_Bit), Function skipbits, file /_w/tsmuxer/tsmuxer/tsmuxerbitstream.h, line 119.
__________
Old 5th January 2020, 13:58   #214  |  Link
tymoxa
That's because NAL AUD was stripped when movie was muxed into mkv. Presence of NAL AUD is mandatory in UHD-BD. mkv>udh-bd is always bad idea without proper reconstructing nal-aud.
tymoxa is offline   Reply With Quote
Old 5th January 2020, 14:52   #215  |  Link
SeeMoreDigital
Out of interest, what application was used to create the .MKV file in the first place?
Old 5th January 2020, 16:14   #216  |  Link
a5180007
@HaDiHo The hevc stream must repeat the AUD and SEI nals between each frame, plus VPS/SPS/PPS before each I-frame (which must be at the start of each chapter). If your stream has been mkv-muxed (or re-encoded) then it possibly does not follow these specs.
Edit: In the future, tsMuxer might include automatic inclusion of AUD nal if absent.
EDIT 2 : Chapters now work with UHD Bluray folder option in latest bintray build.
a5180007 is offline   Reply With Quote
Old 5th January 2020, 20:34   #217  |  Link
sandrino3867
I try to add srt. subtitle to UHD movie and i got this error: video-width, video-height and fps parameters MUST be provided for SRT tracks. TsMuxer w64-nightly-2020-01-05--01-10-23 can add subtitle to UHD Movie 4K and how ? Sorry for my bad english.
sandrino3867 is offline   Reply With Quote
Old 5th January 2020, 21:40   #218  |  Link
a5180007
@sandrino3867 please cut the first 20MB of the m2ts with an hex editor (e.g. HxD), zip it with the srt, upload it somewhere and send me the link via PM.
Old 6th January 2020, 02:28   #219  |  Link
MrVideo
MrVideo's Avatar
Minor fixes for GUI:
1) The About doesn't show that the program has support for the HEVC codec.
2) Cannot correctly set the fps for 720p/59.94 HEVC elementary stream. Since the frame rate can't be found in a HEVC stream, the frame rate must be forced, but there is no option for 60000/1001.
My Total Eclipse 2017 Photos
Old 6th January 2020, 04:11   #220  |  Link
MrVideo
MrVideo's Avatar
How about adding a link in the first post to the bintray location of the nightly builds?
