16th June 2010, 00:54 | #8042 | Link |
No problem. I have that issue in previous version. I was trying this and it have worked. I've wrote "2 Pass" and it was given that issue instead of "2-Pass".
The last issue i have tried is to installed the 3 softwares requirement in a order. Try this: - Uninstall everything. - Reboot Install softwares in that order: 1. Avisynth 2.5.8 stable version; 2. Haali Mastroska (recommanded version from Atak_Snajperač 3. FFDSHOW (clsid rev) *latest* 4. Installation Ripbot in the c:\ripbot264\*.* 5. Configure ffdshow video; VC-1 config to WMV9. Reboot, and try! Give me some news again. Thanks.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
16th June 2010, 09:18 | #8043 | Link |
Hi 8ternity,
could you please give me your address. I just want to send a pressentbasket. Just want to say it worked!!! Great thanks for that. I can't imagine why the order of installation was that important. Again, thanks for that and have a nice day! |
16th June 2010, 15:57 | #8044 | Link | |
16th June 2010, 21:34 | #8045 | Link |
At the moment I suspect problem with accuracy in x264 encoder. Last night I encoded BD Avatar -> AVCHD (720p, AC3 640kbps). Calculated bitrate was 2966 kbps but I got 2973 kbps! So instead of <4480 i got 4483MB!
C:\>"C:\Users\Dawid\Documents\Delphi_Projects\RipBot264\tools\avs2yuv\pipebuf.exe" "C:\Users\Dawid\Documents\Delphi_Projects\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\temp\RipBot264temp\job1\job1.avs" - : "C:\Users\Dawid\Documents\Delphi_Projects\RipBot264\tools\x264\x264_x64.exe" --pass 1 --bitrate 2966 --stats "C:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 232606 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "C:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1280x720p 1:1 @ 10000000/417083 fps (cfr) x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (25000) > level limit (20000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile Main, level 4.0 C:\temp\RipBot264temp\job1\job1.avs: 1280x720, 10000000/417083 fps, 232606 frames x264 [info]: frame I:2585 Avg QP:21.94 size: 77743 x264 [info]: frame P:127010 Avg QP:25.21 size: 22406 x264 [info]: frame B:103011 Avg QP:27.12 size: 5308 x264 [info]: consecutive B-frames: 23.2% 46.3% 14.5% 15.9% x264 [info]: mb I I16..4: 33.5% 0.0% 66.5% x264 [info]: mb P I16..4: 21.5% 0.0% 0.0% P16..4: 57.7% 0.0% 0.0% 0.0% 0.0% skip:20.8% x264 [info]: mb B I16..4: 1.8% 0.0% 0.0% B16..8: 24.4% 0.0% 0.0% direct: 6.7% skip:67.1% L0:28.0% L1:49.6% BI:22.4% x264 [info]: final ratefactor: 22.92 x264 [info]: coded y,uvDC,uvAC intra: 41.4% 46.3% 15.8% inter: 19.1% 13.6% 1.6% x264 [info]: i16 v,h,dc,p: 31% 22% 24% 23% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 20% 18% 4% 10% 6% 7% 6% 8% x264 [info]: i8c dc,h,v,p: 57% 18% 19% 6% x264 [info]: Weighted P-Frames: Y:3.2% x264 [info]: kb/s:2963.26 encoded 232606 frames, 14.96 fps, 2963.26 kb/s C:\>"C:\Users\Dawid\Documents\Delphi_Projects\RipBot264\tools\avs2yuv\pipebuf.exe" "C:\Users\Dawid\Documents\Delphi_Projects\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\temp\RipBot264temp\job1\job1.avs" - : "C:\Users\Dawid\Documents\Delphi_Projects\RipBot264\tools\x264\x264_x64.exe" --pass 2 --bitrate 2966 --stats "C:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 232606 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "C:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1280x720p 1:1 @ 10000000/417083 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 4.0 C:\temp\RipBot264temp\job1\job1.avs: 1280x720, 10000000/417083 fps, 232606 frames x264 [info]: frame I:2585 Avg QP:24.80 size: 57831 x264 [info]: frame P:127010 Avg QP:26.47 size: 22768 x264 [info]: frame B:103011 Avg QP:28.90 size: 5478 x264 [info]: consecutive B-frames: 23.2% 46.3% 14.5% 15.9% x264 [info]: mb I I16..4: 14.4% 68.3% 17.3% x264 [info]: mb P I16..4: 2.4% 9.5% 2.0% P16..4: 42.3% 11.8% 2.7% 0.4% 0.3% skip:28.6% x264 [info]: mb B I16..4: 0.3% 1.0% 0.1% B16..8: 40.3% 5.0% 1.0% direct: 1.6% skip:50.6% L0:37.2% L1:57.7% BI: 5.1% x264 [info]: 8x8 transform intra:68.5% inter:74.9% x264 [info]: coded y,uvDC,uvAC intra: 62.3% 65.0% 32.1% inter: 18.4% 15.9% 2.4% x264 [info]: i16 v,h,dc,p: 32% 19% 8% 41% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 14% 15% 7% 10% 10% 10% 9% 9% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 16% 13% 7% 12% 10% 11% 7% 7% x264 [info]: i8c dc,h,v,p: 57% 17% 18% 8% x264 [info]: Weighted P-Frames: Y:3.7% x264 [info]: ref P L0: 62.4% 22.4% 10.5% 4.4% 0.3% x264 [info]: ref B L0: 93.1% 6.9% x264 [info]: kb/s:2973.21 encoded 232606 frames, 14.18 fps, 2973.21 kb/s
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th June 2010 at 21:40. |
16th June 2010, 22:42 | #8046 | Link |
AVCHDCoder developer
I encounter the same oversizing problems since I upgraded from r1352 to r1583 in AVCHDCoder. I don't get many oversizing reports. Only a few. Mostly somewhere between 2 and 8 MB oversizing.
16th June 2010, 23:24 | #8047 | Link |
Aging Video Hobbyist
Well, FWIW in my case I was not referring to x264 not matching the desired bitrate; it has hit-or-been-slightly-less for me always. I was instead referring to the final muxxed output from tsMuxeR.
It seems that RipBot's calculator chooses a too-high bitrate for x264 to use, if including a DTS@1510 audiotrack (COPY STREAM). |
17th June 2010, 09:04 | #8049 | Link | |
17th June 2010, 22:19 | #8051 | Link | |
18th June 2010, 01:11 | #8055 | Link | |
"--keyint 240 --min-keyint 24" whereas I prefer "--keyint 24 --min-keyint 2" Thanks. |
18th June 2010, 01:26 | #8056 | Link | |
Custom Installer Maker
I don't think it has to do with DTS-core or not because one of my two oversized encodes used AC3 640kbps. Could it be the version of the x264 encoder? While this is sorted out I keep a margin or 10mb just to be safe. Thanks.
Applications: VistaTweaker, Launch, ServiceTweaker. Custom installers: iTunes without QuickTime, Skype and more. |
18th June 2010, 12:38 | #8057 | Link | ||
18th June 2010, 15:09 | #8058 | Link |
Hi Atak ,
I'm encoding at least 2 files / day , and regarding the audio files , when select a DTS file to be encoded , the result will be - each time - an AC3.. Only ONE time a DTS file encoded and resulted a DTS encoded files and I didn't understand WHY ??? Which is the trick or the..secret ??? It requires different setings ??? The original DTS files should have special caracteristics to be encoded and resulted as ...DTS too ??? |
