5th November 2012, 23:03 | #20321 | Link | |
Broadband Junkie
For example, on Win7 the VIA2021 chip from the Gigabyte Z77 UD3H has an extremely messed up non-linear curve in Volume Mixer: Volume Sliders @ 100% + Source Level @ 0.86+ = 100% Volume Mixer(clipped). Volume Sliders @ 100% + Source Level @ 0.85 = ~100% Volume Mixer. Volume Sliders @ 100% + Source Level @ 0.75 = ~75% Volume Mixer. Volume Sliders @ 100% + Source Level @ 0.60 = ~45% Volume Mixer. Volume Sliders @ 100% + Source Level @ 0.50 = ~25% Volume Mixer. Volume Sliders @ 100% + Source Level @ 0.25 = ~10% Volume Mixer. Volume Sliders @ 100% + Source Level @ 0.15 = ~5% Volume Mixer. The Realtek chip on my secondary P55 system has 1:1:1 scaling of Volume Sliders to Source Level to Volume Mixer on Win7. Same with the Creative card I used on my previous WinXP/Win7 AMD 939 system. Last edited by cyberbeing; 5th November 2012 at 23:14. |
6th November 2012, 00:25 | #20322 | Link |
I had assumed that the Volume Mixer worked similarly to Windows 7's and that adding support for it in Windows 8 would be unnecessary. I could be totally wrong though.
It could also be to do with drivers as you say - I think right now I'm using Windows' built-in drivers since there are no Windows 8 drivers for my motherboard at all (yet). One interesting change in the handling of audio, which could be down to either Windows 8 or the generic driver, is that my headphones (plugged into the front line out socket) are now treated as a separate audio device, with their own master volume setting.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
6th November 2012, 15:32 | #20323 | Link |
Is there any way to force MPC to auto resize all videos to a particular %? Like %100 Width and %130 height?
Edit: There is! View->video frame->keep aspect ratio" and then go to Play->Filters->ffdshow video decoder->resize & aspect tick "resize", go down to the aspect ratio section at the bottom and select "manual", then change 1.33 to whatever you want. 1.6 would be wider, 1.0 would be taller. Last edited by IceFiend; 6th November 2012 at 16:51. |
7th November 2012, 15:14 | #20326 | Link | |
MPC-HC Helper xD
7th November 2012, 20:02 | #20328 | Link | |
works in IE9, but not FF10. My builds Last edited by v0lt; 7th November 2012 at 20:04. |
7th November 2012, 20:35 | #20329 | Link |
wrong colors with under windows 8
Since I am using the official windows 8 version i get wrong colors with evr (custom) and madvr. By now I have now clue what could be wrong. Does anyone have an Idea or at least the same problem. When I switch to evr the colors are fine.
Everyting seems to be redish. White actually is pink. Red seems to be purple and so on. In between I tried all the different renderers. The only ones that produce correct colors are: Overlay VMR 7 and EVR All other renderers produce wrong colors. Does anyone have an idea? Thomas Last edited by tdoll; 7th November 2012 at 22:47. |
8th November 2012, 07:15 | #20335 | Link |
Crash when mixing DTS and some other audio formats
The problem appeared after (b4c70f207264bdf9f56e45d08c5a0c4c8dc00db9) commit. FFmpeg bugs |
8th November 2012, 11:42 | #20337 | Link |
MPC-HC Developer
I would rather try to disable JS, it will fallback to legacy mode and should work for everyone. Anyway if you have any poblems you should report it to h5ai developers and if they say that it's configuration/server fault then report it to XhmikosR's
9th November 2012, 10:23 | #20338 | Link |
Anybody else having troubles with Catalyst 12.11 beta drivers and MPC-HC? After updating to these drivers the MPC-HC window is just black and does not render any video. Only way to get a picture is to use windowed VMR-7/9 or madVR.
My graphics card is a Radeon 7950 and I'm using Win 7 x64. |
9th November 2012, 12:23 | #20340 | Link | |
Intel UHD Graphics 750; Win 10 22H2 |
