18th August 2022, 15:57 | #1621 | Link | |
25th August 2022, 13:51 | #1622 | Link |
I'm trying to learn more how the dictionaries work. I'm completely baffled why I can't find one word for example.
plaît in French I know the soft recognizes this. It proposes this when there is plait. But I can't find it in any dictionaries. Is it not stored in plain text? I have used 2 software to search in the folder for text and they can't find it! Where is it?! |
17th September 2022, 04:14 | #1623 | Link |
Please, add an option to auto set an adjusted encoding when saving any file.
Say you open File A but it's encoded as ANSI, you modify it then save it or you just save it, then SE should set the encoding to what we set in the options. |
24th September 2022, 11:04 | #1626 | Link | |
I want to report something, I'm using "Fix common errors" with Spanish, but for some reason words like "Atella" or "Amana" are "fixed" into "A tell a" and "A man a", can you look into this? Last edited by darksen; 24th September 2022 at 11:33. |
24th September 2022, 12:26 | #1627 | Link |
@tormento: thx. Detecting position would require ASSA format and a whole lot of coding...
@darksen: You can turn off the auto-word-split of unknown words in Options - Settings - Tools - Fix common errors - Use word split list. If you're using a whole Spanish subtitle, then the words should probably be added to the user-word or names list (or use a better spell check dictionary). Last edited by Nikse555; 25th September 2022 at 12:15. Reason: typo |
24th September 2022, 22:51 | #1628 | Link | |
21st October 2022, 02:06 | #1631 | Link |
Ok, following my issues from before I'm having a problem now that SE is applying "fixes" to words that are inside the name list when using "Fix common errors", can this be disabled? I can't find an option in the configuration, also I thought that was a function of the spell check tool, not the OCR fixes. Words like "kung-fu" are getting "fixed" to "Kung-fu" everywhere, to give an example, there are several words that are used also as names in the Spanish language. Please, help.
24th October 2022, 10:26 | #1632 | Link |
Thanks for new release:
https://github.com/SubtitleEdit/subt...ases/tag/3.6.8 |
7th November 2022, 12:05 | #1633 | Link |
Banana User
Download problem is back again [Win7 / v3.6.8]:
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
20th November 2022, 21:24 | #1634 | Link |
https://github.com/SubtitleEdit/subt...ases/tag/3.6.9 |
20th November 2022, 23:05 | #1635 | Link |
Banana User
Downloads still doesn't work in v3.6.9.
21st November 2022, 08:56 | #1638 | Link |
Banana User
Better is not to add the version numbers to the thread tiltles, because ~soon it will "freeze", if it's not frozen already.
21st November 2022, 22:04 | #1639 | Link |
https://github.com/SubtitleEdit/subt...ses/tag/3.6.10 |
5th January 2023, 18:04 | #1640 | Link |
Why isn't it possible to set linebreaks as shown in video preview of an ass -file "WrapStyle 0"
F.E. I have a long line and the preview in videoplayer shows it with line breaks, but if I want to create really this breaks with auto break the breaks are set on another position. Why does no tool (aegisub also) have a function to set line breaks as seen in the preview? (I want to save the subs as SRT and so I need hard breaks) |
