9th May 2015, 21:08 | #1381 | Link | |
there were issues about CPU (people trying to load the 32-bit version because the project is configured for 32-bit but the DLL is 64-bit and vice-versa), about strings (which were deleted but still used by the calling app, I use temporary strings now), and many others I forgot.
Want to know all about your media files? http://mediaarea.net/MediaInfo |
12th May 2015, 08:19 | #1382 | Link |
Greetings Zenitram. Many thanks for sharing this wonderful piece of work.
Have a question on how delay is dealt with. For example, mediainfo reported a video delay of 67ms and audio delay of 70ms for an mkv clip, resulting in net a/v delay of 3ms. Other software(s), however, reported a net a/v delay of -67ms. Would appreciate if you could kindly explain the discrepancy. Many thanks and best regards. |
12th May 2015, 08:42 | #1383 | Link |
It may be a bug. Without the file (at least the first MB), I can not say more.
12th May 2015, 10:52 | #1384 | Link | |
Would appreciate if you could advise the proper steps to use MVVtoolNix (or other software) to cut a sample without messing up the delay info. Many thanks and best regards. |
12th May 2015, 13:54 | #1386 | Link | |
As I suspected, delay has been altered. |
12th May 2015, 14:07 | #1387 | Link | |
12th May 2015, 14:43 | #1389 | Link | |
https://www.sendspace.com/file/umdxee |
12th May 2015, 14:50 | #1391 | Link | |
First cluster timecode is 67ms, 70ms is the first audio timecode >67ms so maybe MediaInfo does not handle correctly negative (in relation to cluster timecode) SimpleBlock timecode or something like that? It's a signed int. Last edited by sneaker_ger; 12th May 2015 at 15:06. |
22nd May 2015, 12:34 | #1392 | Link | |
22nd May 2015, 12:39 | #1393 | Link |
I quicly check and issue may be inside MediaInfo. I did not have the time yet for a deep analysis. Work in progress
30th May 2015, 19:55 | #1395 | Link |
Software Developer
Zenitram, I'm getting this compilation error with MediaInfo 0.7.74 release:
3>..\..\..\Source\MediaInfo\File__Analyze.cpp(2323): error : identifier "Trace_Activated" is undefined 3> if (Trace_Activated) 3> ^ 3> 3>..\..\..\Source\MediaInfo\File__Analyze.cpp(2325): error : identifier "Config_Trace_Format" is undefined 3> switch (Config_Trace_Format) 3> ^ 3> 3>..\..\..\Source\MediaInfo\File__Analyze.cpp(2329): error : class "MediaInfoLib::File__Analyze::element_details" has no member "ToShow" 3> size_t Details_lt_Pos=Element[Element_Level].ToShow.Details.rfind(__T("<")); [EDIT] Just commenting out the whole "if(Trace_Activated)" block seems to have fixed it. Hopefully this doesn't break anything. But, AFAICT, it should be fine, since it's just some "tracing" code. I supposed the "#ifdef" guards are missing in the code? [EDIT 2] Anyway, new MediaInfoXP builds (including MediaInfo 0.7.74) are available now: https://github.com/lordmulder/mediai...ases/tag/v2.16
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 31st May 2015 at 18:03. |
2nd June 2015, 16:45 | #1396 | Link |
@Zenitram, Is it true that MediaInfo on sourceforge is bundled with adware? One of the reviews: "project now contains what I would consider malware -- it installs the Mezaa advertising client. ...". What happened?
2nd June 2015, 16:56 | #1397 | Link | |
But actually Sourceforge is not the main download site (actually it is no more linked from my websie for years, only old links not controlled by me go to Sourforge), please use the official website instead.
Want to know all about your media files? http://mediaarea.net/MediaInfo Last edited by Zenitram; 2nd June 2015 at 20:41. |
3rd June 2015, 13:19 | #1398 | Link | |
3rd June 2015, 13:28 | #1399 | Link | |
I never abandonned the account (which is a mirror, no more the main download site), and for me it was back as normal (no ads) 1 hour after I pinged them.
3rd June 2015, 16:47 | #1400 | Link | ||
Life's clearer in 4K UHD
Cheers
