27th March 2023, 05:12 | #2241 | Link |
Vulkan device. Look under Requirements
https://github.com/Asd-g/AviSynthPlus-RIFE |
27th March 2023, 06:41 | #2243 | Link | |
Friend of a friend..
28th March 2023, 09:56 | #2250 | Link |
21 years and counting...
From my experience: KNLmeansCL and BM3D surely will run faster on a RTX 30 card. DGDenoise needs a Nvidia GPU to run at all anyway.
If you think about buying one, do NOT go for a 3050 or 3060 8GB with 128bit memory bus. They are significantly slower than a 3060 with 192bit mem bus. Learned this the hard way. Last edited by LeXXuz; 28th March 2023 at 10:58. |
28th March 2023, 11:08 | #2251 | Link | |
And I just checked my RTX's, and they are only 128bit |
28th March 2023, 11:35 | #2252 | Link | |
SMDegrain does not use GPU in general, the setting may be a little misleading. Only for some prefilters like the aforementioned and subpixel processing if you explicitly use subpixel=4 (with gpu=0) which means you use GPU based NNEDI3CL. See its dependencies section at the very beginning of the script. If you don't use subpixel=4, or prefilter=6,7,8 it will not make any difference if you set gpu=0 or -1. Everything else is CPU processed to my knowledge. I think Dogway set gpu=0 by default, so unexperienced users will use the faster GPU based processing automatically IF they choose to use any of those prefilters or subpixel processing. Don't get me wrong. They will still be faster than processing BM3D or KNLM entirely on CPU. But they are not as fast as a 3060 12GB / 3060TI 8GB and above. My advice was only for people who think about buying a new graphics card. For those it means: stay away from RTX 3050 and RTX 3060 8GB. Buy a RTX 3060 12GB or RTX 3060TI 8GB instead. Last edited by LeXXuz; 28th March 2023 at 11:48. |
28th March 2023, 12:09 | #2253 | Link | |
29th March 2023, 09:43 | #2254 | Link | |
Posts: n/a
to use STTWM as prefilter i should skip below pre=ex_Median(mode="IQMST",thres=155) ex_blend(pre,"blend",opacity=0.3).ex_sbr(1,UV=3) and replace it by one of below? # STTWM(sw=20,tw=80,aw=100,sthres=255,tthres=7) # Strong temporal # STTWM(sw=40,tw=60,aw=100,sthres=255,tthres=5) # Strong spatial pre= STTWM(sw=50,tw=50,aw=100,sthres= 5,tthres=5) # Balanced # STTWM(sw=50,tw=50,aw= 10,sthres= 5,tthres=5) # Light |
29th March 2023, 10:47 | #2255 | Link | |
29th March 2023, 11:00 | #2256 | Link | |
Posts: n/a
i'm not really sure what you mean. Could you please provide example code for your suggestion? i see from my test that this pre= STTWM(sw=50,tw=50,aw=100,sthres= 5,tthres=5) # Balanced have more details but keep also some grain compare to below pre=ex_Median(mode="IQMST",thres=15) ex_blend(pre,"blend",opacity=0.2).ex_sbr(1,UV=3) i'm very happy with resoults of this STTWM(sw=50,tw=50,aw=100,sthres= 5,tthres=5) # Balanced, but i would like to know how to adjust it strengh. STTWM i can adjust it strengh by rising these sthres= 5, tthres=5 ? Last edited by madey83; 29th March 2023 at 11:05. |
29th March 2023, 12:19 | #2257 | Link |
If you use it as a prefilter within SMDegrain you may use this:
pre=STTWM(sw=50,tw=50,aw=100,sthres= 5,tthres=5).ex_sbr(1,UV=3) SMDegrain("your settings here", prefilter=pre) If the filtering is too weak try raising "thSAD" and/or "tr" of SMDegrain a little. If that is not enought the grain of your source may be too strong for STTWM or you need a different prefilter. In that case try ex_Minblur or ex_Median with "IQM" via the internal prefilters 0-3 if IQMST is too strong and STTWM is too weak for your source. |
29th March 2023, 12:53 | #2258 | Link | |
Posts: n/a
edit: Results are very nice with higher TR Last edited by madey83; 29th March 2023 at 13:35. |
29th March 2023, 13:34 | #2259 | Link |
Posts: n/a
For sharpening i use this call:
LSFplus(strength=50, preset="LSF", secure=true, Lmode=3, soft=-2, soothe=true, Smode=3, Smethod=3, Szrp=16, Spwr=4, SdmpLo=4, SdmpHi=48, overshoot=1, undershoot=1, Overshoot2=1, Undershoot2=1, keep=20, edgemode=0) is it any possibility to improve it or replace it by better approach for sharpening? Could you advice please.... |
29th March 2023, 14:04 | #2260 | Link |
I hardly use Limited Sharpen anymore. I don't like the results, especially on HD sources.
I use contrasharp=true within SMDegrain. And if that is too strong, something more subtle like ex_unsharp() with lower settings after SMDegrain. try: Code:
SMDegrain(...) ex_unsharp(0.3) for clean anime Code:
SMDegrain(...) ex_unsharp(0.15).ex_unsharp(0.15, Fc=width()/1.5) Last edited by LeXXuz; 29th March 2023 at 14:11. |
avisynth, dogway, filters, hbd, packs |
