Old 23rd September 2021, 16:59   #1101  |  Link
von Suppé
von Suppé's Avatar
Originally Posted by r0lZ View Post
Yes, the subtitle order bug has been fixed. Anyway, it was present only when it displayed or demuxed the subtitle streams (and, for a 3DBD, their 3D-planes) of a commercial BD with the order of the PIDs not matching the order of the streams in the MPLS. AFAIK, when tsMuxeR muxes a BD, it creates always a MPLS with the streams in the order of their PIDs. But I don't use tsMuxeR to remux, only to demux. Therefore, I may be wrong.
Clear. Good to know. Thanks, r0lZ
Old 23rd September 2021, 19:08   #1102  |  Link
oniiz86
According to the screenshot, the problem (if any) is that it shows the streams it demuxes (and possibly also muxes) when it encounters them. Since the subtitle streams can start at different times, the order of the messages is not necessarily identical to the order of the streams in the source or target file.
oniiz86, have you verified the order of the streams with another program, such as MediaInfo ? Is it correct ?
Yes, MediaInfo has them in the correct order, it could be what you are claiming regarding the slightly shorter subtitle stream duration as 8 of them run 2 minutes shorter at 2h 18mins compared to the other 5 at the same duration as the feature at 2hrs 20mins, still it is strange when the file is added to tsMuxeR the tracks are in the correct order as MediaInfo reports, I know it probably doesn't affect anything when muxed to an .m2ts/.ts file but was curious all the same.
oniiz86 is offline   Reply With Quote
Old 4th October 2021, 12:54   #1103  |  Link
xledentaldj
Still waiting for a proper fix and source code/compile build
for MacOS 11.6 arm. I cant compile this correctly
on my Mac Mini M1 2020 along with the dylib dependency
errors I get on any nightly build. And no, that special
build you made still has that same dependency
issue on my Mac. I have some ability to compile,
so, if you want me to help, I can. All my home brew
is up to date, I have the dylibs installed, X-Code
is up to date and Docker installed. justdan96, lets get this fixed for
MacOS Please?
__________
Oppo-203
xledentaldj is offline   Reply With Quote
Old 8th October 2021, 10:08   #1104  |  Link
oniiz86
@justdan96 I was wondering why some muxes successfully complete at 99.8% it seems to be random too, the majority do reach 100%, just found it strange why some stop at 99.8%?
Old 18th October 2021, 16:18   #1105  |  Link
Nico8583
Thanks for this new version
Do you think you could add an option to demux (or remux) AC3/DTS core and keep TrueHD/DTS-HD ? Not only the current option to keep DTS-HD/TrueHD or DTS/AC3 core.
Thanks !
Nico8583 is offline   Reply With Quote
Old 4th November 2021, 10:02   #1106  |  Link
alestew
Hello everyone ... let's see if it happens to someone else.
I have the Oppo clone m9201 model and everything is great, except with some m2ts files in dolby vision.
The problem is that it only happens to me with the fulluhd with Dolby Vision that I pass to m2ts without the audios and subtitles that do not interest me and respecting the DV.
I play that movie with Dolby Vision in that m2ts format and great, I stop it and switch to the next movie, the format doesn't matter and I get this image ...
the movie is heard in the background but it looks like this. It is only solved by restarting the player.
I have noticed that my m2ts have the 4k base and the separate Dv, with which they are joined in 1 it does not fail.
Any ideas?
alestew is offline   Reply With Quote
Old 4th November 2021, 12:17   #1107  |  Link
von Suppé
von Suppé's Avatar
For narrowing things down, first thing I would do is trying to determine whether it's a problem with tsMuxer or other, like firmware.
Using an untouched copy of the original m2ts file and see if the issue remains, might help.
Old 5th November 2021, 14:05   #1108  |  Link
a5180007
Yes it must be the infamous "green screen bug" reported e.g. here. I couldn't solve and cannot carry out trials and errors as I don't have any Bluray player myself.
a5180007 is offline   Reply With Quote
Old 5th November 2021, 14:06   #1109  |  Link
a5180007
Good news, updated MPEG-TS standard for VVC has been made public yesterday https://www.itu.int/rec/T-REC-H.222.0-202106-I/en
Old 5th November 2021, 22:06   #1110  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Nice one. So we'll soon have muxers and decoding in software players
Old 9th November 2021, 10:24   #1111  |  Link
alestew
But the film works perfectly, only when I put another one (m2ts / mkv) I get the layer in front ... Well my solution today is to create an Iso instead of m2ts and zero problems
Old 11th November 2021, 02:23   #1112  |  Link
mattl0
Two possible enhancements of tsMuxer for versions after 2.7.0:
1. TrueHD
Mpeg-ts is compatible with interleaved ac3/TrueHD frames. One solution to mux pure TrueHD would be to interleave empty 32kbit ac3 frames. Indeed not as good as transcoding an ac3+thd with eac3to, as the playing of the ac3 would be blank. Is it of any interest ?
2. Dolby Vision
Profile 7 dual tracks is supported by Blu-ray player SoCs only. For non-Blu-ray modes, tsMuxer could transmux those to profile 6 single track dual layer, deprecated but a priori compatible with most STB/TV SoCs. Is it of any interest ?
is profile 6 still happening on tsmuxer? I want to test some p6 to test on ugoos my tv and a bluray player
mattl0 is offline   Reply With Quote
Old 11th November 2021, 21:48   #1113  |  Link
imhh11
+1
I would really really like those 2 enhancements to be implemented.
imhh11 is offline   Reply With Quote
Old 11th November 2021, 22:48   #1114  |  Link
xledentaldj
Hello folks, I've compiled a MacOS 11.6.1 Arm/M1 build of tsmuxer 2.6.16-dev for anyone on MacOS to try:
https://mega.nz/file/JAI3DSrY#qV8ofw...Pan5WepCVpMq8A
It still has issues making compliant 4K UHD BD ISO for my Oppo-203 (RU JB). It did successfully take my 4K BD trailer that was in an mkv container remuxed back into a BD ISO and was playable on my Oppo-203.
The tsmuxerGUI has some errors while it was compiling. Something about offsets width and qt. But it runs.
__________
Oppo-203
Old 16th November 2021, 18:12   #1115  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Out of interest....
Where are people able to download the newest 'GitHub builds' of TSmuxer GUI?
Old 16th November 2021, 19:52   #1116  |  Link
von Suppé
von Suppé's Avatar
Here you go: https://github.com/justdan96/tsMuxer/releases
Old 16th November 2021, 21:24   #1117  |  Link
SeeMoreDigital
Many thanks
Old 5th December 2021, 21:38   #1118  |  Link
MrVideo
MrVideo's Avatar
I tried creating an ISO that contained a 4K HDR video with DD+ and DD, but my Sony X800M2 UHD player refuses to play it. It does the loading, but doesn't play. Instead it just reports that it is a UHD disc. That was using an April nightly. So, I downloaded the 12/05 nightly and the same thing happens. The only difference during the ISO creation is that the file only has a DD+ audio stream. tsMuxer complains about a pure DD+ not being Blu-ray compliant. No kidding. It is a 4K video, so a UHD compliant disc does allow for DD+.
Old 5th December 2021, 23:10   #1119  |  Link
SeeMoreDigital
Was your .iso file 'unpacked' before being burned onto a UHD disc?
Just-so you know... Technically, DD+ encoded audio without a regular DD core is not Blu-ray spec compliant.
Old 6th December 2021, 10:48   #1120  |  Link
MrVideo
MrVideo's Avatar
Burned onto a BD-RE disc.
Correct. But it is allowed for UHD. I'm trying to create UHD spec discs, but burned onto BD media, specifically 25GB media. My Sony player will play what BDRB creates, or if I place M2TS files on a BD-ROM.
As for BDRB, it recodes the E-AC3 to AC3 and I just replace that stream with the original E-AC3 stream. Due to a reason I do not know, doing that doesn't exactly work out. More in the BDRB thread.
