Old 7th August 2022, 16:21   #601  |  Link
PurpleMarOne
I have a problem with one of my Blu-ray disc, when I try to decrypt it with FindVUK it ends up telling me
Validation failed - VUK/UnitKeys are INVALID!!!!!!!
How can I solve this problem please?
Here is the complete file: 2022-08-07_FindVUK.txt
PurpleMarOne is offline   Reply With Quote
Old 1st September 2022, 21:33   #602  |  Link
nalor
Originally Posted by ron spencer View Post
anyone know what happened to:
http://fvonline-db.bplaced.net/
Nothing there anymore. Anyone have the last file from there?
I thought I wrote an explanation about the reasons - but I think it missed to send it.
Nevertheless here it comes: I'm using the free hosting of https://www.bplaced.net/ and it requires to login at least once within 2 months - and I missed to login and so the website got disabled by the hoster.
And next I missed the messages here so I didn't notice what happened until I stumbled into the problem by myself ...
Sorry for the inconvenience ...
nalor is offline   Reply With Quote
Old 1st September 2022, 21:36   #603  |  Link
nalor
Here is the complete file: Attachment 18171
Hi! Can you upload the logfile somewhere else? I cannot access it here until it has been approved - which can take a while ...
so please just upload it somewhere else and post the link here, thanks
Old 2nd September 2022, 17:40   #604  |  Link
PurpleMarOne
Thank you for the answer! I just uploaded the file on Google Drive: https://drive.google.com/file/d/1tgA...XQf9UOkXp84fqU
Old 4th September 2022, 11:08   #605  |  Link
nalor
Checked your logfile and it's really strange - there's only a single UnitKey that can be used to decrypt at least one file, but it does not work for other files on the disc ...
I've bought the movie now myself, will get it within a week and will check if it's really the same disc as yours (I bought the german disc - but it's hopefully the same as the italien one) and once I've clarified this detail I check why the validation of the unit key is acting so strange ...
Old 4th September 2022, 13:58   #606  |  Link
PurpleMarOne
Thanks for your answer, but unfortunately I already know that the German disc and the Italian one aren't the same
Unlike the Italian disc the German one is already listed in the KEYDB.cfg file so I assume you wouldn't encounter any problem with it.
I'm sorry that you ordered a DVD for nothing, but if it helps, the EAN for the Italian DVD is 8032807057118.
Old 29th September 2022, 22:05   #607  |  Link
nalor
You're right - the german disc worked without problems
I've created a small tool that just copies the first ~12kb of each file into a zipped file so that I can check what's going wrong with this disc (to be exact I decided to copy 2 'aligned_units' of each file = 12288 bytes)
Please
  1. download the small tool: BlurayDebugDump
  2. start it
  3. enter the driveletter of the drive with the disc
  4. finally it creates a zip file with the current date and time as filename in the current directory
Upload the file somewhere and send me the link so I can check the file
Thanks!
Old 1st October 2022, 01:50   #608  |  Link
PurpleMarOne
Please
  2. start it
Thanks!
Thanks! I did what you said, here's the zip file:
https://drive.google.com/file/d/1qqU...rU0NW5I0y2f-b6
Old 18th October 2022, 20:34   #609  |  Link
Grimsdyke
Uploading to the online db seem to be broken !?
2022-10-18 21:28:57 # 77473 # [E] findvuk_bluraymeta / BlurayMeta_UploadAndBackup / unexpected status! >302<
MPC-BE feature wishlist: 1) DiscID
2) Two independent volume control sliders in the UI when using dual-audio-out.
Grimsdyke is offline   Reply With Quote
Old 17th November 2022, 11:33   #610  |  Link
farmerjoe
The site is currently gone, you'll get only a 404 error.
farmerjoe is offline   Reply With Quote
Old 21st November 2022, 20:33   #611  |  Link
nalor
Do you still get a 302 as response?
Hopefully the problem resolved automatically ... the reason has been that the provider "bplaced" offered a free month of an upgraded package and I clicked the button ...
As a result the page tried to redirect each http request to a https address ... with a http 302.
When I noticed this I disabled the automatic redirect and hopefully everything is working again.
Old 22nd November 2022, 19:02   #612  |  Link
PurpleMarOne
Please
  2. start it
Thanks!
Hi nalor, do you have any update on the issue with the Winx blu-ray?
Old 25th November 2022, 16:13   #613  |  Link
Dimensional
If you need a place to store FindVUK, I would suggest ProtonDrive, as opposed to the other Cloud Storage.
Dimensional is offline   Reply With Quote
Old 27th November 2022, 22:51   #614  |  Link
nalor
I will change the check in FindVUK so that it proceeds when all existing keys are valid (currently it breaks because there are video files where no valid key exists ... ).
But I don't know when I will find the time to change it ...
Old 28th November 2022, 07:13   #615  |  Link
PurpleMarOne
Alright, thanks for the update! No worries, I'm in no rush, you can do it whenever you can
Old 19th January 2023, 23:32   #616  |  Link
nalor
Just noticed there's a problem with the most recent Passkey version 9.4.5.1 - but I know everything is still working with 9.4.3.6, so I'd recommend to stay with a 9.4.3.x version until I've found time to analyze the changes DVDfab made in the newer 9.4.5.x versions.
Old 20th January 2023, 14:44   #617  |  Link
Grimsdyke
Version 9.4.5.0. seem to work just fine on my system ! Or is there anything I am not aware of ? Thx
Old 22nd January 2023, 00:43   #618  |  Link
nalor
Indeed - Passkey 9.4.5.0 worked with FindVUK 1.57, but 9.4.5.1 stopped to work.
Just published FindVUK 1.58 that establishes compatibility with 9.4.5.1
Old 22nd January 2023, 00:44   #619  |  Link
nalor
New FindUK 1.58 should fix your problem! Please test and keep me posted, thanks
Old 22nd January 2023, 10:55   #620  |  Link
Grimsdyke
You are a Genius
