1st June 2011, 02:29 | #221 | Link | |||
"0-4096;8704-4096;10496-8192;15616-17664;31744-31744;47872-46080;53760-53760;58880-64512;65280-60160",\ Quote:
But I dont want to output/clamp TV range values,but instead work in TV range For example, see this analogy by using smoothcurve Code:
saturation in PC range: "0-0;64-"+string(64-64*sat)+";128-128;192-"+string(192+64*sat)+";255-255" saturation in TV range: "0-16;16-16;74-"+string(74-55*sat)+";127-127;185-"+string(185+55*sat)+";240-240;255-240"
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
1st June 2011, 09:56 | #222 | Link | |||
LaTo INV.
Example: "Invert" the 16 bits clip Code:
SmoothCurve16("0-65535;65535-0") #Easy SmoothCurve16("0.0-255,99609375;255,99609375-0.0") #Your proposition with decimals (65535/256 = 255,99609375) SmoothCurve16("0-255;255-0") #Internal remap: the conversion is wrong (255*256->65280 != 65535) Quote:
Also I doesn't understand why you want to leave theses parts "as-is". If you do that, you will have strange things later. Example: "Desaturate" a clip Code:
SmoothCurve(UVcurve="0-128;255-128") #In "PCrange", all colors are gone SmoothCurve(UVcurve="0-0;16-16;17-128;239-128;240-240;255-255") #In "TVrange", extreme colors are still here I will try to improve a bit the view Last edited by LaTo; 1st June 2011 at 10:23. |
1st June 2011, 11:41 | #223 | Link |
beta4 AVX test
-------------------- Code:
#smoothlevels(gamma=2.0, useOPT=0) # 159 fps #smoothlevels(gamma=2.0, useOPT=1) # 217 fps #smoothlevels(gamma=2.0, useOPT=2) # 92 fps #smoothlevels(gamma=2.0, useOPT=0, useMT=0) # 66 fps #smoothlevels(gamma=2.0, useOPT=1, useMT=0) # 140 fps #smoothlevels(gamma=2.0, useOPT=2, useMT=0) # 33 fps
1st June 2011, 11:43 | #224 | Link | |
I dont know how other applications deal internally with it, and I can't tell you how but Im pretty sure is possible, that's why I tried to fill a bit your empty todo list. Its unintuitive as hell, thats all.
In effect I was totally wrong yey! Some tests a few months ago I remember I could desaturate with no problems, but it makes sense that out of TVrange bounds colors follow a correlation with the curve Quote:
What I expect is a curve behaviour inside the TVRange in the same fashion as PCrange, but leaving the out of bounds values practically untouched. That's why my confusion on whether "0-0;16-16... or "0-16;16-16... because the first seems to be more locked on the extremes by the knobs (thus modifying the curve weight) than PCrange curve. While it being at first glance the ideal approach I can't tell behaviour is the same, Im not mathematician. Then maybe is contradictory. Because "Output_low/output_high at 16/235" in levels is not "0-0;16-16;...;235-235;255-255". Maybe you wanted to say "16,1.0,235,16,235" but this flats values in the range 0-16 to a value of 16. There is no way in levels to do "proper" TVrange like you said in curves "0-0;16-16;...;235-235;255-255" (assuming this is the correct way which I discussed in the previous paragraph.) edit: I think interp=100 doesn't work, using beta4
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 1st June 2011 at 11:59. |
1st June 2011, 17:16 | #225 | Link |
Hmm, I don't know if I am doing something wrong, here...
I wanted to replicate the effect of tweak(hue=+5) using smoothtweak. After some confusion, I realized that smoothtweak's hue1 and hue2 in fact seem to do the same thing as coloryuv's off_u and off_v, respectively. (Acording to my very limited understanding, the hue parameter as used by tweak kind of rotates the color spectrum around the center/white/black/grey (or something like that, excuse me please), and strangely enough, a dvd I am trying to color-adjust for some strange reason seem to respond well to this kind of shifting...) 1) Is my observation correct? if it is so, mybe the parameters could use some additional explanation in readme... 2) Is there a way to do the adjustment tweak does for hue with smoothadjust, with its superior precission? Last edited by mandarinka; 1st June 2011 at 17:29. |
2nd June 2011, 16:36 | #226 | Link | ||
LaTo INV.
2. No sorry Yes, just a bad scaling... 50 is in fact 100, so higher than 50 produces strange result (fixed in the next beta) Quote:
Can you try the 2 dlls in this package > SmoothAdjust.AVXtest.zip < and report FPS here (with useMT=0)? Thanks! Last edited by LaTo; 2nd June 2011 at 16:58. |
3rd June 2011, 11:46 | #227 | Link |
@LaTo: I was doing some tests and investigations using vectorscope for accuracy. Indeed SmoothLevels can work with TVrange like this "SmoothLevels(16,1.0,235,16,235..." but by doing so you cant avoid out of 16 and 235 values to not be flatten. This procedure overrides limiter=0. I can post samples but dont want to make the post too bulky.
I also noticed that there is no way you can match smoothcurve and smoothlevels in a simple gamma tweak, I get different curves, and results. So I think you are using another valid approach Im not aware of or something is missing. Code:
SmoothCurve(Ycurve="0-0;128-136.3;255-255",smooth=0,dither=0,interp=50,show=true) != SmoothLevels(0,1.1,255,0,255,smooth=0,show=true,dither=0,limiter=0) Also is it broken decimals input in beta4?
3rd June 2011, 18:58 | #228 | Link | ||
LaTo INV.
Not broken, input points are integer from the beginning. Decimals added in next beta. |
3rd June 2011, 20:04 | #229 | Link |
You are right, I get the same identical results as of levels with "mt_lut(yexpr="x 255 / 1 1.1 / ^ 255 * ",Y=3,U=2,V=2)" then what is the "correct" gamma for smoothcurves? Is there an interp value to conform the power curve?
4th June 2011, 17:35 | #231 | Link |
@Lato
I do get back a lot more contrast on Lmode1 when using very conservative setting on BrightSTR. Varying DarkSTR is quite safe on the other hand. Q1. If I use gamma=1, will smoothing be turn off. Q2.If set Smode=1, will it be on at all time? At certain situation, I want it to be on at all time with gamma=1. Q3. Same behavior between v1.74 and v2? |
4th June 2011, 20:06 | #232 | Link | |
LaTo INV.
Update 2011/06/04
4th June 2011, 20:31 | #233 | Link | |
LaTo INV.
Q2: Smode=0 -> always OFF // Smode=1/2 -> always ON Q3: Yes but Smode is removed ( smooth>0 -> always ON // smooth=0 -> always OFF ) Here is a fast comparison of v1.74 & v2.xx with strength/smooth=100 (very strong): Source image Smoothing OFF v1.74 (Smode=2) v2.00beta5 (More effective, more details & sharpness, no artifact...) Code:
SmoothCurve(Ycurve="0-16;16-16;64-128;128-224;235-235;255-235",Ucurve="0-0;64-192;128-128;192-64;255-255",Vcurve="0-255;64-64;128-128;192-192;255-0") Last edited by LaTo; 4th June 2011 at 20:37. |
4th June 2011, 21:09 | #234 | Link | |
Kid for Today
4th June 2011, 21:12 | #235 | Link |
LaTo, thanks a lot! This plugin feels profesional, I wonder what SmoothCustom is... : D
btw how do you get that fancy colors in the UV debug, the Cb Cr colors...
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 5th June 2011 at 09:07. |
5th June 2011, 17:34 | #237 | Link | |
beta5 AVX test
------------------ Quote:
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 5th June 2011 at 17:38. |
5th June 2011, 18:54 | #238 | Link | ||
LaTo INV.
6th June 2011, 09:23 | #239 | Link | |
AVXtest (test)
