#19701 | Link | |
Posts: n/a
You'll probably find that there are many other symbols/characters that will cause issues. I doubt that it can be "fixed" within RipBot, however, you've already figured out how to work around this, so just go with that, and edit any file names with these symbols...easy peasy. And, BTW, FYI, because you're new here, any attachments take "forever" to be approved, you would be a lot better off to use site's like "Imgur" or similar to post screenshots, etc. |
#19702 | Link | |
First, I was like, maybe it doesn't support some audio types or maybe something is wrong with these video files, so I tried to process them using other softwares then Ripbot. Then after a month of this, suddenly I figured out it was because of "File Name" ... I was like what a waste..lol. Is there a section where I can find all the known issues ?? Also thanks for the "Imgur" tip, I will use that. Last edited by kingpin; 13th November 2022 at 19:24. |
#19703 | Link | |
Posts: n/a
You're welcome ![]() So even though you're new to the forum, how long have you been using RipBot ?? Are you using Atak's original build's, or are you trying Pauly Dunne's ?? The latter is very update, & has many, many filtering options, I can fully recommend it. As for a section on "known issues", sadly there really isn't one, and searching this thread looking for specific info is pretty time consuming. Fortunately though, there aren't too many issues with RipBot, but there's ALWAY's room for improvement. There is some info on the builds & some feedback comments here:- https://www.videohelp.com/software/R...tory#changelog and here:- https://www.videohelp.com/software/RipBot264 Good luck. |
#19704 | Link |
Posts: n/a
Time for another update...
Here we go yet again...
There has been a few new components become available in the 24 hours or so.. https://www.mediafire.com/file/c5tzr...11-22).7z/file So for the ppl that use my build, simply unpack, and overwrite ALL the files & folders, they will find their own "home". And here's a twist, Atak had released an autoupdate, updating several components, BUT they are STILL not the latest available ![]() So if anyone downloaded & installed the update package, for Atak's version, I posted a few days ago, you might have to repeat the process, IF you've allowed the autoupdate, if not, then it's not a problem. Also, for those using Atak's build, there are some files in this update, that you can copy over. eg:- MKVToolNix, MPC & x265, but that's ALL !!!! PS:- I had a problem with the autoupdate download for Atak's version, there was/is a network problem somewhere, and I could not get it to download, even manually, and I still MANY times. (ffmpeg) http://atak-snajpera.5v.pl/ripbot264update, doesn't reflect the latest version numbers & dates...
#19705 | Link | |
#19706 | Link | |
Posts: n/a
I recall another user was having an issue with something very similar to this, and I think he found a workaround... Have a look here, and several posts after it...might help. https://forum.doom9.org/showthread.p...82#post1972082 I think you will find that it's a problem with eac3to, not RipBot. |
#19707 | Link |
If you are pulling in a 4K UHD ripped source then you will have to use the eac3to that comes with Atak's build. The newer versions of eac3to don't seem to work. It could be there is a new command line option that isn't being used by RB that is causing the error. Either way, rolling back to RB's eac3to version allows it to work fine.
#19708 | Link | |
#19709 | Link | |
Posts: n/a
One thing I've just noticed is the version number of eac3to, I'm pretty sure that Pauly's should be v3.36 ?? ![]() And if you're not ripping UHD disc's, you must be getting them another way (won't say what way that is), but of course they would have been ripped to start with. Did any of my suggestions work, meaning running it thru MKVToolNix first ?? Would you able to upload a sample of the movie you're having trouble with ?? You can do this with MKVToolNix if you want, just load the file, then go to the "Output" tab, choose the "splitting" option, and select or add the length or size you want it split to, then run it until it's completed at least one "chunk", then you can stop it. Upload to Mediafire or similar. Anyway, the choice is yours, if you have found a "workaround", then you're set to go, with future problems. Cheers |
#19710 | Link | |
Posts: n/a
Problem is, he gets the same error with either Atak's or Pauly's, but I've just noticed an eac3to version discrepancy...(see my post, above) |
#19711 | Link | |
I'm ripping Blueray's, not UHD's. I really would prefer to fix my issue than to have some other workarounds. That's what I got this software for. It was an all in one. |
#19712 | Link | |
Posts: n/a
Yes, eac3to DOES come with RipBot, and if you want to update it yourself, you need get the download, https://www.videohelp.com/software/eac3to (unpack it, and then copy it into the "eac3to" folder inside RipBot, under the "Tools" folder, overwriting everything in there.) What are you using to rip the disc's ?? What version of Windows are you running ?? Just trying to help
#19713 | Link |
How ripbot264 correct colorimetry when upscaling dvd contents to 720p/1080p contents?
mediainfo report itu bt 601 after conversion from NTSC dvd for color matrix, transfer and colorprim. I've forced in custom box x265 --colorprim bt709 --transfer bt709 --colormatrix bt709 but red is over satured. No change in auto script from ripbot, no color conversion. |
#19714 | Link | |
Posts: n/a
You asked about LUT's 12 months or so ago, you could use a LUT, maybe. https://forum.doom9.org/showthread.p...99#post1951599 Or under the Avisynth settings, go to the "Colours" setting, click on the and choose "ON", then a "Tweak" option will appear, where you can manually change the appropriate option, and test. There's also an "ON (3DLUT)", where you can import a LUT. |
#19715 | Link |
yes you are right I asked for the luts about a year ago and it works very well, of that I am very happy.
What I ask now instead is how does ripbot264 correct the colorimetry after a dvd to hd conversion. log file report: 1.26.0 Fixed: Correct colorimetry for DVD sources (ntsc->smpte170m,pal->bt470bg) ok, sound is good, let's try! After upscaling conversion, do not convert to itu bt 709 Rec. https://en.wikipedia.org/wiki/Rec._709, color space is the same of source. Last edited by darkio; 16th November 2022 at 12:10. Reason: details |
#19716 | Link | |
Posts: n/a
Other than that, there is only the Colours setting I mentioned in the previous post. |
#19717 | Link |
HD itu 709 rec. example from mediainfo:
Color range : Limited Colori primari : BT.709 Caratteristiche trasferimento : BT.709 Coefficienti matrici : BT.709v SD content: Color range : Limited Colori primari : BT.601 NTSC Caratteristiche trasferimento : BT.601 Coefficienti matrici : BT.601 Lut are unnecessary for colorimetry correction. I'm asking conversion from bt 601 (smtpe170m/bt470bg) to itu 709 Rec. after upscaling. http://avisynth.nl/index.php/ColorMatrix It seams ripbot simply "copy" source information in to converted dest. file. When you use ripbot to convert uhd disk (hdr) to standard video (sdr), it can convert hdr signal itu bt 2020 rec to normal signal into itu bt 709 rec. When using dvd upscaling ripbot do not convert colorapace. Last edited by darkio; 16th November 2022 at 13:04. |
#19718 | Link | |
Posts: n/a
#19719 | Link |
I'm hope atak fix this issue as soon as possible!
However, avisynth can do colormatrix conversion. Thanks for your reply, friend. ![]() edit: tmpgenc mast. work 7 can import ripbot264 avs file and transform colormatrix into itu bt 709. [IMG] [/IMG]
#19720 | Link | |
Posts: n/a
You're welcome. EDIT:- Good 'ole TMPGENC, I used to use that all the time, back in the day (earlier versions of cause.) I think I may have found something that might do the job, I'll get back to you. Last edited by TDS; 17th November 2022 at 01:13. |
| Tags |
| 264, 265, appletv, avchd, bluray, gui, iphone, ipod, ps3, psp, ripbot264, x264 2-pass, x264 gui, x264_64, x265, xbox360 |
| Thread Tools | |
| Display Modes | |
