23rd October 2012, 22:13 | #20285 | Link | |
Win 7, using madVR+LAVFilters and DXVA. Anyone have a suggestion? |
24th October 2012, 06:31 | #20286 | Link |
Does the settings on VSFilter color tab work? It seems to always output YUY2 to EVR.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 |
24th October 2012, 06:57 | #20287 | Link |
Broadband Junkie
On regular VSFilter, the colors tab has been broken for as long as I remember. Though the reason you are seeing YUY2, is because AMD/ATI GPUs don't support YV12 with EVR, and regular VSFilter doesn't support NV12. What will usually occur, is VSFilter will take YV12 input from the decoder, and then do a color conversion to YUY2.
xy-VSFilter has a fully functional colors tab, and it also supports NV12. Though unlike regular VSFilter, xy-VSFilter will never perform color conversions. Input format from decoder to xy-VSFilter = Format supported by Video Renderer = Output format from xy-VSFilter to Video Renderer. Last edited by cyberbeing; 24th October 2012 at 06:59. |
24th October 2012, 10:28 | #20288 | Link | |
Anyone know how those PowerDVD and TMT plug-ins for Windows Media Center works? On Windows Media Center you can add Blu-rays and DVD's into movie library but you will need a plug-in for Blu-rays, for example PowerDVD, when you launch a BD from the WMC library it opens the movie on PowerDVD on top of WMC. You can get MPC-HC to load also but the problem is that it can't properly communicate with MPC-HC to start the playback. I think it would need some plug-in that wouldn't require much code to start MPC-HC on full screen and start playback with the correct switches.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 24th October 2012 at 10:49. |
24th October 2012, 16:20 | #20289 | Link |
Almost got mpc-hc to load when hitting play in Windows Media Center Movie Library. Only thing is that WMC passes this to MPC-HC
"C:\Program Files (x86)\mpc\mpc-hc.exe" -embed 393972H:/AVATAR/ So I would need to compile a MPC-HC build that has for example -fullscreen switch name replaced to -emblem so that is accepted and at the same time mpc-hc lauches in full screen. Other change would be to make mpc-hc to discard those six numbers in the path. Anyone here who has everything already set up and compiles MPC-HC builds often? I could do it myself but I have VS 2012, dunno if it will work. Also it takes a while to setup everything.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 24th October 2012 at 17:26. |
25th October 2012, 14:45 | #20290 | Link | |
MPC-HC Helper xD
import subprocess import sys if "__main__" == __name__: path = sys.argv[2].lstrip("0123456789") subprocess.call(["C:\Program Files (x86)\mpc\mpc-hc.exe", path])
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook Last edited by vBm; 25th October 2012 at 14:50. |
25th October 2012, 15:50 | #20291 | Link | |
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 25th October 2012 at 16:40. |
25th October 2012, 21:49 | #20292 | Link |
I have improved the pan&scan rotation functionality. With this change it is easier to flip and rotate the video. Old behavior was a 2 degree step for all 6 directions. New behavior is to take 180/90 degree steps in 3 of those directions.
Alt+2 = vertical flip Alt+6 = horizontal flip Alt+3 = rotate 90 degree counterclockwise Here is changed code: Code:
mainform.cpp void CMainFrame::OnViewRotate(UINT nID) ------------------------------ switch (nID) { case ID_PANSCAN_ROTATEXP: m_AngleX = (m_AngleX + 2) % 360; break; case ID_PANSCAN_ROTATEXM: if (m_AngleX >= 180) m_AngleX = 0; else m_AngleX = 180; break; case ID_PANSCAN_ROTATEYP: m_AngleY = (m_AngleY + 2) % 360; break; case ID_PANSCAN_ROTATEYM: if (m_AngleY >= 180) m_AngleY = 0; else m_AngleY = 180; break; case ID_PANSCAN_ROTATEZP: m_AngleZ = (m_AngleZ + 2) % 360; break; case ID_PANSCAN_ROTATEZM: if (m_AngleZ >= 270) m_AngleZ = 0; else if (m_AngleZ >= 180) m_AngleZ = 270; else if (m_AngleZ >= 90) m_AngleZ = 180; else m_AngleZ = 90; break; default: return; }
MPC-HC 2.2.1 |
26th October 2012, 15:32 | #20293 | Link | |
See this image showing how I hacked the DVD Navigator path on my system: Clicking "restore" should revert to the system default. |
26th October 2012, 23:47 | #20294 | Link |
@tiny:
Thanks a lot. I'll try this and report back. Edit: I've completely forgotten about that neat little program for allowing DVD playback with madVR. I set it back to the system default. Then, MPC-HC gave me a "Macrovision fail," as expected. I switched it back to dslibdvdnav.ax in my 32-bit version of dslibdvdnav and tried again. Left is what I get with open disc-> E. Right is what I get with open DVD/BD->E. http://i.imgur.com/MWXqy.jpg The DVD drive whirls for a few seconds after showing me this, then stops. I have Win 7 64-bit by the way. So I tried doing the same with with dslibdvdnav.ax 64-bit version, with no avail. Last edited by Yoshi8765; 27th October 2012 at 14:46. Reason: Adding new info |
28th October 2012, 00:59 | #20295 | Link |
I have this weird problem in fullscreen, all advice is welcome.
Window: http://i.imgur.com/kBqfI.jpg Fullscreen: http://i.imgur.com/ZV9XC.jpg As you can see, target rectangle in fullscreen is very wrong. My monitor is 1680x1050. MPC-HC 1.6.4.6052 LAV Filters 0.52 madVR 0.84.3 It happens with different renderers too, on all videos. |
30th October 2012, 16:42 | #20300 | Link |
@Yoshi8765:
I'm sorry I couldn't test this earlier. I've got AnyDVD running in the background doing the decryption. If I disable AnyDVD the black window & no play problem like you're having occurs. Looks like the MPC/dslibdvdnav.ax/LAV combination doesn't play (normal commercial) encrypted DVDs without some extra help. |
