3rd March 2010, 21:44 | #661 | Link | |
I have no idea about the reason they change the name and the position in the image for the same angle, but if they do not change the angle, 5.1 back = 7.1 side (both at 90-110°) For MediaInfo, 90-110° angle must have only ONE name (and the discussion was about Side vs Surround). Back is already reserved for 135-150°, it can't be reused for 90-110° whatever are the pictures and names, and you demonstrated with the image that your 5.1 channel have "surround" channels at 90-110°... So "Side", and not "Back (135-150°) If the image is wrong about angles(if speaker position is right), another name for this "new" angle must be found ("Surround"?), so 5.1 would have Front+Surround, and 6.1 or 7.1 would have Front+Side+Back. But in order to do this, I must be sure that speaker positions are not same (90-110°), and I currently saw no other angles... About "Sub", I already spoke about it, I don't remember where, but people demonstrated that LFE and Subwoofer names are different, and that "LFE" is better, I use it. I don't display "Yes" because I hide "LFE" if it is not present. I admit this is not the best presentation because separation between the last field and LFE is not great, but this is the best I currently have (I am not sure that ", Back: L R, LFE: Yes" is better than ", Back; L R, LFE". And additionnaly, this is more difficult for translation, L and R are common and understable as Left and Right in the language of people so I let it as is, but "Yes" is a bit too much "english") Note: I changed "rs" to "Back" for TrueHD On http://www.dolby.com/consumer/setup/...ide/index.html , Dolby's website, 5.1 channels are named "Surround", not "Back"... I don't know where you saw this image.
Want to know all about your media files? http://mediaarea.net/MediaInfo |
3rd March 2010, 22:20 | #662 | Link |
Life's clearer in 4K UHD
I see...
I have taken new "lifts" from Dolby's web site for further reference: - Cheers
4th March 2010, 10:29 | #664 | Link | |
Sufficed to say though... The "front" left, centre and right speakers are "surround speakers" too! Personally... I prefer to have identified where all my surround speakers need to be located. ie: the ones to the "side" and/or the ones to the "back" EDIT: FFdshow's "naming" convention is very understandable: - Cheers
25th April 2010, 02:21 | #666 | Link |
I've been doing some testing with AVStoDVD, and it's transcoding some of my DVD compliant files because Mediainfo isn't reporting the Standard field for these files. The files in question are MPEG-2 @ 352x240, which is a valid NTSC DVD combination. It seems that 'NTSC' is only reported for files that are 720x480, but not 704x480, 352x480, or 352x240. Likewise, 'PAL' is only reported for 720x576, not 704x576, 352x576, or 352x288. The resolutions are also listed here:
http://www.videohelp.com/dvd#tech For all those resolutions, could the Standard field also report 'NTSC' or 'PAL'? |
2nd May 2010, 18:46 | #667 | Link | |
2nd May 2010, 18:52 | #668 | Link |
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
3rd May 2010, 14:49 | #669 | Link |
Software Developer
Zenitram, may I ask why there is no source package available this time? Or did I miss something?
[EDIT] Never mind. I managed to manually check out the "v0.7.32" tags from the SVN repository.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd May 2010 at 17:08. |
3rd May 2010, 21:00 | #670 | Link | |
4th May 2010, 21:22 | #671 | Link |
[QUOTE=LoRd_MuldeR;1396890]Zenitram, may I ask why there is no source package available this time? Or did I miss something?[EDIT]
A bit late, but the source package is avaialble. This is exactly the same as the SVN tag 0.7.32, no need to update if you used the SVN.
5th June 2010, 16:46 | #672 | Link |
brontosaurusrex
mediainfoDroplet.app (OS X) updated with MediaInfo_CLI_0.7.33
more info and download here: http://forum.doom9.org/showthread.ph...27#post1336727 (no other changes) Last edited by smok3; 5th June 2010 at 17:06. |
6th June 2010, 11:13 | #674 | Link | |
brontosaurusrex
snap of a 'fil e.m2ts': http://imagebin.ca/view/lpF2JS7.html snap of a 'fil e 蚞ȊŽ.m2ts': http://imagebin.ca/view/6-ri3Fn.html mods: can someone split this from post 672 to a new thread with name: mediainfoDroplet.app (OS X) (i did not expect a debate ) Last edited by smok3; 6th June 2010 at 11:26. |
12th June 2010, 09:31 | #676 | Link |
7.1Ch Dolby Digital Plus Sources
Hi Zen,
I just thought you may be interested in this one... I have a "7.1 channel" Dolby Digital Plus sample for you, which is not currently supported by MediaInfo... In-fact it's not currently supported in most applications. I am able to play it on my Xtreamer (hardware media player) and send the bit-stream output to my Onkyo amplifier. So I can confirm it works. Any chance you can provide support for such sources? Here's a link to the source: http://www.megaupload.com/?d=Q4YSDD48 Cheers
12th June 2010, 13:10 | #677 | Link | ||
Audio Format : E-AC-3 Format/Info : Audio Coding 3 Duration : 3mn 34s Bit rate mode : Constant Bit rate : 732 Kbps Sampling rate : 48.0 KHz Stream size : 18.7 MiB (bit rate is wrong due to how the file is created) Quote:
Actually, you file has 2 E-AC-3 streams interleaved! (One 7.1 frame, one 5.1 frame, One 7.1 frame, one 5.1 frame, ...) On my ToDo list. But there are some development to do, not quick, and my ToDo list is currently very long, so do not expect it soon.
12th June 2010, 15:19 | #678 | Link |
Hi Zenitram,
Thanks for the information... So it's two audio files in one. I wonder if this is the reason why TSmuxer GUI does not recognise it
22nd June 2010, 10:37 | #680 | Link |
As far as I know...
None of todays surround sound audio formats generate streams offering a dedicated "rear centre" channel...
