Old 26th April 2014, 13:00   #1  |  Link
zee944
opening DTS-HD MA with NicAudio
I've tried opening a DTS-HD MA track with this script:
LoadPlugin("NicAudio[2.0.4].dll")
a=NicDTSSource("movie.dts", DRC=1)	#a=NicAC3Source("movie.ac3", DRC=1)
flr = GetChannel(a, 1, 2)
fcc = GetChannel(a, 3)
lfe = GetChannel(a, 4)
lfc = MixAudio(fcc, lfe, 0.2071, 0.2071)
mix = MergeChannels(lfc, lfc)
lrc = MixAudio(flr, mix, 0.2929, 1.0)
blr = GetChannel(a, 5, 6)
MixAudio(lrc, blr, 1.0, 0.2929)
Normalize()
ConvertAudioto24bit()
AudioDubEx(BlankClip(length=Int(25*AudioLengthF(last)/Audiorate(last)), width=32, height=32, pixel_type="RGB24", fps=25), last)
VirtualDub opens this seemingly fine, but when I press play it just freezes, and the same happens when I want to save the audio.
Simplifying the script to this...:
...it doesn't freeze, but no audio plays, and can't save the wave either. Why's that?
What I actually wanted to do is a proper stereo downmix of the DTS-HD MA 5.1 track.
zee944 is offline   Reply With Quote
Old 26th April 2014, 13:38   #2  |  Link
filler56789
SuperVirus
filler56789's Avatar
You'd better try DirectShowSource (with LAV Audio + Arcsoft's DTS decoder).
filler56789 is offline   Reply With Quote
Old 26th April 2014, 14:39   #3  |  Link
zee944
How do I do that?
BTW, I've already decoded the six channels with eac3to. So I have 6 wavs. I can open them instead if that's easier, but I don't know how to make a stereo mix out of them.
Old 26th April 2014, 16:46   #4  |  Link
zee944
Originally Posted by HolyWu View Post
Doesn't eac3to also have -downDpl and -downStereo options to do the downmix job?
You're perfectly right! I forgot about it.
I can't do dynamic range compression with that though - as far as I know, players do this when they downmix to stereo. Any suggestions?
Old 27th April 2014, 08:53   #5  |  Link
Richard1485
Posts: n/a
NicDTSSource() does not decode DTS-HD MA. Extract the core with eac3to and try your first script again.
Old 27th April 2014, 12:18   #6  |  Link
tebasuna51
tebasuna51's Avatar
NicAudio DRC parameter only work with AC3 than have DRC info in the stream, DTS audio don't have this info and the use of DRC parameter is useless.
And yes NicAudio can't decode DTS-MA, sometimes work decoding only the 'core' but is not recommended.
With (output.wav or other):
eac3to movie.dts output.wav -downStereo
you have the same downmix than with your avs script.
Old 27th April 2014, 12:43   #7  |  Link
zee944
I did that and it works now, thanks!
Now the question is: is my first script "right"? Should I handle a DTS track the very same way as an AC3 track? Will my stereo mix be good?
Old 27th April 2014, 13:41   #8  |  Link
zee944
Thanks! I guess it is a "proper" stereo downmixing of a DTS track then.
Old 27th April 2014, 14:37   #9  |  Link
Richard1485
Posts: n/a
The script looks right. The downmix is fine, but I prefer this.
fcc = GetChannel(a, 3, 3)
lrc = MixAudio(flr, fcc, 0.3694, 0.2612)
MixAudio(lrc, blr, 1.0, 0.3694)
I normalize after downmixing to stereo. If you're concerned about dynamic range simply because you want to listen in a home environment, you can recompress to AC-3 at a bitrate that is high enough to be transparent (e.g. 384 kbps) and apply a DRC profile and dialnorm value e.g. film standard and -27. You can do this with WAV to AC3 encoder. I do this quite often for friends who dislike high dynamic range. Give it a try.
Old 27th April 2014, 18:48   #10  |  Link
zee944
How a player do the downmixing? Like "my" script do, or like yours?
I'm only concerned about the dynamic range because as far as I know, players do DRC compression if the AC3 is flagged that way. I didn't know that in the case of DTS, this flag doesn't exist.
Old 27th April 2014, 19:37   #11  |  Link
Richard1485
Posts: n/a
The script that I posted discards the LFE, which is what Dolby recommends. You can, of course, mix the LFE if you wish.
In that case, you need only the PCM. You mentioned earlier that you successfully used eac3to to split your audio into WAVs. Does this mean that you have access to Arcsoft? If so, forget NicDTSSource and proceed to make your stereo PCM.
Old 28th April 2014, 09:07   #12  |  Link
zee944
Yes, I have Arcsoft DTS Decoder.
I'm not sure what do you mean. You mean use eac3to and its -downStereo option?
Old 28th April 2014, 19:31   #13  |  Link
Richard1485
Posts: n/a
I mean use eac3to to decode the DTS-HD MA. As I understand it from reading back through the thread, you chose to use NicDTSSource() despite the fact that it decodes only the lossy core because you thought it could apply DRC. Now that you have found that that is not the case, you might as well use Arcsoft
Either use eac3to input output.wav -downstereo if you want the built-in downmix or use eac3to input output.wavs if you want to apply the one I use. Better still, try them both and pick the one you like the best.
Old 29th April 2014, 14:54   #14  |  Link
zee944
Could you modify your script to use the six WAVs and put the LFE into the mix as well? It would be very helpful.
Old 30th April 2014, 00:39   #15  |  Link
Richard1485
Posts: n/a
You might as well use the stereo downmix that eac3to uses. The discarding of the LFE is a big part of why I like the mix. But you might ask Tebasuna if he thinks it's possible. He's the expert.
dts, dts-hd, nicdtssource
