#801 | Link | |
Posts: n/a
But why remove it altogether...just add another pre filter (DGDecNV). I'm having enough issues (see post 783), that I haven't really had time to "fix", and then sort of unannounced there is a significant change to the pre-filters in SMDegrain ![]() Last edited by TDS; 8th February 2022 at 10:18. |
#802 | Link | |
Do you have something to prove KNLMeansCL should be back? In my tests it showed poor performance, see the following images (very bad motion estimation). KNLMeans Spatio-Temporal (bug so edited out) KNLMeans Spatial (bug so edited out) DGDenoise ![]() DGDenoise has sharp edges so a bit of blurring afterwards is fine, I will add it. As for the BM3D issues I would first check BM3D works fine on its own so it's not an ex_BM3D() bug.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 8th February 2022 at 13:51. |
#803 | Link |
Results are a bit strange. Isn't DGDenoise also an implementation of nlmeans algo? (but without any temporal filtering)
I mean they should look more similar... Is your source filter frame accurate?
#804 | Link |
I'm using DGDecNV r239 so I it should be frame accurate.
I'm not sure about DGDenoise algorithm, there are several edge aware denoisers like nlmeans, bilateral and variations like smart blur, surface blur and those from the papers; guided blur, etc. To me DGDenoise looks like a bilateral filter but videoh has to confirm. Temporal GPU denoisers in AviSynth is a chimera, both KNLMeansCL and BM3D have issues BM3D CPU is fine though.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 8th February 2022 at 12:14. |
#805 | Link | |
From DGDecodeNVManual.html
#806 | Link | ||
Posts: n/a
if you think that DG's stuff works better, then so be it. You also hinted that there are some issues with BM3D (GPU), but with BM3D (CPU) it's ONLY good for AVX2 CPU's, unless the dev of that updates that function. as for this Quote:
All I can say about that is, that it used to work, but since updating last week sometime, the error showed up, but I can't figure out what versions I changed, that brought it back. I need to back date, and start almost from scratch ![]() BTW, where can I get older builds ??? is there an archive somewhere ?? Last edited by TDS; 8th February 2022 at 13:37. |
#807 | Link | |
![]() @TDS: Wait for v3.4.6 tonight or something and report back if it still doesn't work.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
#810 | Link | ||
Posts: n/a
Thnx ked
![]() @Dogway, nice work, I see what you've done there....will "test" as soon as I can, and report back. Cheers --------------------------------------------------------------------------- So, reporting back, and have had limited success, it works on a stand alone PC, but using the Distributed Encoding feature of RipBot264, the Client encoding servers will not encode ![]() Quote:
I have no idea wtf has gone wrong, 'cause I'm sure it was working a couple of weeks ago before I "blindly" updated everything ![]() --------------------------------------------------------------------------- Another update, I have managed to get a "set" of scripts from and old build of RipBot264, which has most of your "goodies", but rather old builds, BUT those errors have gone ![]() So now I need to update one @ a time, and see where the issue is / was. I'm kinda thinkin' it might be something to do with BM3D, but KNL did the same thing, suspecting some OpenCL problem, but wtfk ! Last edited by TDS; 9th February 2022 at 07:47. |
#811 | Link |
Acid fr0g
I dunno.
I have always used both with a bias for the second because of more detail retaining while doing a good job at helping removing noise. I have never found any artifact in the output video from SMDegrain and I will keep on using BM3D on CUDA, as my CPU is more ancient than simply old. ![]() DGDenoise is a nice add, I still have to evaluate detail retaining and differences with KNLMeansCL.
@turment on Telegram Last edited by tormento; 9th February 2022 at 20:03. |
#812 | Link |
With BM3D you have to be too careful on many aspects. First don't crop with DGSource(). And second, we lack "blocking_step" arg, so the maximum block-free settings are sigma=4, radius=1, which is almost useless for prefiltering. I think it also has issues with FFMS2 loader. With CUDA=false I didn't see any of these bugs.
DGDenoise() is fine for Anime, as it's only spatial filtering. I haven't run benchmarks though, it would be very interesting to compare DGDenoise() and KNLMeansCL().
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 9th February 2022 at 23:40. |
#813 | Link | |
Acid fr0g
I haven't done any serious comparison yet but SMDegrain is way faster when using DGDenoise instead of KNLMeansCL. About denoising, using DGDenoise as prefilter, gives bitrates that are between KNLMeansCL (the lowest ones but with detail loss) and BM3D, that AFAIK was better preserving details, mostly moving ones.
@turment on Telegram |
#814 | Link |
I posted the issue here. Confirmed by other users.
DGDenoise is purely spatial, you would need to compare with spatial KNLMeansCL as it's spatio-temporal in SMDegrain, and do some matching with strengths. For visual comparison you can use show=true or directly compare the filters outside SMDegrain. EDIT: I made a benchmark between both. Code:
ex_DGDenoise(str=0.10,UV=3,LFR=0) # P(4) 83 ex_KNLMeansCL(a=2,s=2,d=0,h=6.0,wmode=1,chroma=true,device_type="GPU",LFR=0) # P(4) 80
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 10th February 2022 at 02:37. |
#815 | Link | |
function HighlightLimiter(clip v, float "gblur", bool "gradient", int "threshold", bool "twopass", int "amount", int "method") { bi = BitsPerComponent(v) fs = propNumElements (v,"_ColorRange") > 0 ? \ propGetInt (v,"_ColorRange") == 0 : false grad = Default (gradient,true) gblur = Default (gblur, grad ? 100 : 5) thres = Default (threshold,160) #The lower the value, the more sensitive the filter will be. twopass = Default (twopass,false) amount = Default (amount,20) method = Default (method, 0) # 0 or 1 amount = ex_bs(abs(amount), 8, bi, true) darken = v.ex_binarize(thres,hi=-1) blurred = grad ? darken.ex_gaussianblur(0.073*gblur+17.78,UV=1) : \ darken.ex_gaussianblur(0.064*gblur+ 3.75,UV=1) multiply = (method==0) ? v.ex_lut("x dup * range_max /", fulls=fs) : v.ex_lut(Format("x {amount} + ")+(!fs?"ymax min":""), fulls=fs) multiply = !twopass ? multiply : \ (method==0) ? multiply.ex_lutxy(v,"x y * range_max /", fulls=fs) : \ multiply.ex_contrast(0.15, 1, 163, tv_range=!fs) return mt_merge(v,multiply,blurred) } function HighlightLimiterMod(clip v, int "threshold", int "dark", float "rad",int "mode", float "gamma1_2") { w = Width (v) h = Height(v) bi = BitsPerComponent(v) fs = propNumElements (v,"_ColorRange") > 0 ? \ propGetInt (v,"_ColorRange") == 0 : false thres = Default (threshold,160) dark = Default (dark, 255) rad = Default (rad, 64) mode = Default (mode, 0) # 0,1,2 gamma1_2= Default (gamma1_2, 0.6) # for mode 1,2 m = min(w,h) dark = ex_bs(dark, 8, bi, true) rad = round(m/rad/4) < 1 ? max(round(m/4.0),16) : rad darken = v.ex_binarize(thres,hi=-1) blurred = darken.ex_GaussianBlur(rad*0.83825-0.0631,pad=true,UV=1) multiply = (mode==0) ? v.ex_lut(Format("x dup * {dark} /"), fulls=fs) : \ (mode==1) ? v.ex_levels(gamma=gamma1_2,tv_range=!fs) : \ v.ex_lut(Format("x dup * {dark} /"), fulls=fs).ex_levels(gamma=gamma1_2,tv_range=!fs) return mt_merge(v,multiply,blurred) }
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 12th February 2022 at 03:03. |
#816 | Link |
Posts: n/a
Success :)
Hey Dogway,
I've had a major win (several win's, actually). So I started from an old "set" of your scripts, and worked thru until they worked. I even got the DGDecNV pre-filter to work ![]() So this is my script for KNLMeansCL, is there any "fine tuning" that could be done to it, as I noticed you changed the instructions a bit in SMDegrain 3.4.6d Code:
LoadPlugin("%AVISYNTHPLUGINS%\masktools\masktools2.dll") LoadPlugin("%AVISYNTHPLUGINS%\MedianBlur2\MedianBlur2.dll") LoadPlugin("%AVISYNTHPLUGINS%\mvtools\mvtools2.dll") LoadPlugin("%AVISYNTHPLUGINS%\KNLMeansCL\KNLMeansCL.dll") LoadPlugin("%AVISYNTHPLUGINS%\RgTools\RgTools.dll") Import("%AVISYNTHPLUGINS%\scripts\extras\ExTools74.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\LSFmod50ex.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\Resizers Pack78.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\Sharpeners Pack34.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\SMDegrain346d.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\Zs_RF_Shared.avs") pre=ex_KNLMeansCL(video,a=2,s=4,d=1,h=4,wmode=0) video=SMDegrain(video,tr=4,thSAD=400,thSADC=200,thSCD2=80,contrasharp=true,prefilter=pre,refinemotion=true) Code:
LoadPlugin("%AVISYNTHPLUGINS%\dgdecnv\DGDecodeNV.dll") LoadPlugin("%AVISYNTHPLUGINS%\dfttest\dfttest.dll") LoadPlugin("%AVISYNTHPLUGINS%\masktools\masktools2.dll") LoadPlugin("%AVISYNTHPLUGINS%\MedianBlur2\MedianBlur2.dll") LoadPlugin("%AVISYNTHPLUGINS%\mvtools\mvtools2.dll") LoadPlugin("%AVISYNTHPLUGINS%\RgTools\RgTools.dll") Import("%AVISYNTHPLUGINS%\scripts\extras\ExTools74.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\LSFmod50ex.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\Sharpeners Pack34.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\SMDegrain346d.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\Transform Packv1.0 RC36.avs") Import("%AVISYNTHPLUGINS%\scripts\extras\Zs_RF_Shared.avs") pre=ex_DGDenoise(video,str=0.10) video=SMDegrain(video,tr=2,thSAD=400,thSADC=100,thSCD2=80,contrasharp=true,prefilter=pre,refinemotion=true) It was fairly easy to change the CUDA settings from "True" to "False", but with this latest build, that doesn't seem to apply. ![]() Thanks Last edited by TDS; 10th February 2022 at 06:27. |
#817 | Link |
Hey Dogway, i added some ex_ family into f3kgrain. Can you check it's complete replace ex_ into f3kgrain or not?? Thanks
https://github.com/kedaitinh12/AVSPl...n_v0.4MOD.avsi |
#818 | Link | |
@TDS: You should be able to use CUDA by setting it to true here. For the KNLMeansCL prefilter, test with wmode=1, depending on content you might like it more. By default with 'd' > 0, LFR is used, you can try disabling it with LFR=0, but it will smear quite a bit. ex_DGDenoise() seems also to smear quite a bit, so for next version I will also add LFR argument. CUDA in BM3D is broken really, you can try comparing them CUDA vs CPU outside SMDegrain, I posted this in the BM3D thread.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 10th February 2022 at 12:15. |
#819 | Link | |
#820 | Link |
Oh shii... the AVS filter is so undocumented it looks like shady business haha
block_step, that is: https://github.com/WolframRhodium/Va.../kernel.cu#L49
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 10th February 2022 at 13:05. |
avisynth, dogway, filters, hbd, packs |
