Old 25th December 2024, 17:31   #10941  |  Link
DMD
DMD's Avatar
Merry Christmas
Sorry for the stupid question what command should I select to turn off the top left clock during playback?
I can't find it.
Thank you
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 25th December 2024, 17:46   #10942  |  Link
v0lt
Press the "I" key.
v0lt is offline   Reply With Quote
Old 26th December 2024, 09:26   #10943  |  Link
Klaus1189
Updated german translation
some minor improvements
Old 26th December 2024, 22:43   #10944  |  Link
s0meone_new
Hungarian translation updated:
https://easyupload.io/sfq9t2
s0meone_new is offline   Reply With Quote
Old 27th December 2024, 17:48   #10945  |  Link
v0lt
Thanks. Translations have been updated.
Old 28th December 2024, 08:31   #10946  |  Link
LigH
LigH's Avatar
Big Trouble in Little China!
New German Gleitz board
Old 28th December 2024, 19:33   #10947  |  Link
Sunspark
Great movie. Something like that can't be made today.
Old 29th December 2024, 17:00   #10948  |  Link
LenniePaz
I have some 3D rips that I'm trying to play but they never come out of SBS when I press the 3D button on my JVC RS540 remote. Has anyone had any luck playing 3D rips? Here is the video info for the rip:
Video
Format : AVC
Format profile : High@L4.1
MultiView_Count : 2
MultiView_Layout : Side by Side (left eye first)
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
LenniePaz is offline   Reply With Quote
Old 11th January 2025, 22:50   #10949  |  Link
zamar92
Hello,
I'm running latest MPC-BE 1.8.2 x64 with Windows 11 Task Scheduler to play a given MP3 file every 30 min once the playback task is triggered daily at a set time or by a certain event like Manual Run. In the Task Scheduler - Action, I set Start a Program: "C:\path_to_mpc-be64.exe" "Path_to_file.mp3" /play /close
In the player Options - Playback, I set any file to play 3 times repeatedly once open.
However, the /close switch closes the player after the file plays just ones. If I omit the /close switch, the player remains in Paused (prior scheduled task not completed) state upon finishing the loopback, and the task is not auto repeated at the next time interval. If that's a bug can you fix it, or would you suggest the right set of player run switches for the task?
P.S. Found a workaround: added the same media file 3 times to a playlist folder, and pointed the player to that folder instead of the media file, which allowed to use /close command-line switch.
zamar92 is offline   Reply With Quote
Old 12th January 2025, 22:18   #10950  |  Link
ryrynz
ryrynz's Avatar
How to get XYSubfilter to auto load vtt? Internal works fine, using nightly.
Old 13th January 2025, 01:05   #10951  |  Link
lvqcl
AFAIK XYSubfilter does not support .vtt
lvqcl is offline   Reply With Quote
Old 16th January 2025, 00:38   #10952  |  Link
fourbigkids
fourbigkids's Avatar
MPC-BE Audio Renderer Randomly Blipping
Hi all.
Long time user of MPC-BE using MadVR for video rendering and MPC Audio Renderer for the audio on my HTPC. No external filters used. Recently reinstalled the operating system and all software from scratch. Since then I have been getting this random blipping sound on the audio track. Sample in the link below. In this example the track is DTS.
The HTPC is comprised of a Gigabyte H370-HD3 motherboard, Intel i5 8600 CPU, 16GB 2666Hz Corsair Vengeance RAM - DDR4, WD Blue 250GB M.2 SSD, Seasonic 750W Focus GM-750 Gold PSU and the video card is a Gigabyte-GeForce-RTX-3060Ti-Eagle D6X-8G-OCwith 8GB GDDR6X. I am running Windows 11 and MPC-BE v.1.8.2.
The audio and video go from my HTPC via 'high speed' HDMI to a Sony 4K TV with audio pass through all the way to a Sennheiser AMBEO MAX sound bar.
I have reinstalled MPC-BE and also separately installed another instance of the latest MPC Audio Renderer, but I still get the same glitching in the audio track.
The blips occur randomly. When I playback the same portion of video it may or may not occur. The blipping does not occur with VLC or Windows Media Player.
The blipping seems to occur on only some video files. A copy of the MediaInfo for one example is included in my next post. This is in DTS format. However, DTS plays fine in other videos.
Here is a link to a sample:
https://1drv.ms/u/s!Ajkfvd4XPdI2lssO...ICkHQ?e=ivjeJi
Appreciate your advice.
Cheers,
Allan
fourbigkids is offline   Reply With Quote
Old 16th January 2025, 00:39   #10953  |  Link
fourbigkids
A copy of the Media Info for the above media file:
General
Unique ID : 197416254951206678167905459205802489320 (0x9484FCD960DFD298B9A8EF0C6472F5E8)
Complete name : \\xxxxxxx\Public\TV Series\Star Trek- Discovery\Season 01\Star Trek- Discovery.S01E13.mkv
Format : Matroska
Format version : Version 4
File size : 3.28 GiB
Duration : 42 min 49 s
Overall bit rate : 10.9 Mb/s
Frame rate : 23.976 FPS
Encoded date : 2018-11-14 11:41:31 UTC
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : AVC
Bit rate : 9 442 kb/s
Width : 1 920 pixels
Height : 960 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.214
Stream size : 2.82 GiB (86%)
Writing library : x264 core 157 r2935 545de2f
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=30 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9442 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 462 MiB (14%)
Language : English
Default : Yes
Forced : No
Old 16th January 2025, 05:29   #10954  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by fourbigkids View Post
Hi all.
Cheers,
Allan
Do you use Pass-through in internal Audio Decoder ?
Show status (screenshots) MPC Audio Renderer and MPC Audio Decoder when playback.
What show you sound bar when playback - PCM or DTS ?
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 16th January 2025, 05:58   #10955  |  Link
fourbigkids
Hi Aleksoid. Thanks for responding. Yes, it setup for passthrough from HTPC to TV to Soundbar. DTS shows as DTS on the soundbar when it is being played on the HTPC. Screenshots of the MPC Audio Renderer and the Audio Decoder follow:
Cheers.
Old 16th January 2025, 06:37   #10956  |  Link
Aleksoid1978
Screenshot from active player - when playback - right mouse click -> filters ...
If audio is passthrough - i don't know. maybe some incompatible with sound bar. Try change "Device buffer" in MPC Audio Renderer.
Old 16th January 2025, 06:53   #10957  |  Link
fourbigkids
Sorry, my mistake, here is the screenshot from the 'active' player:
In the meantime, I'll check out the Device Buffer
Thanks Aleksoid1978.
Old 17th January 2025, 03:30   #10958  |  Link
ryrynz
ryrynz's Avatar
Bitstreaming has been problematic for a while now, turn it off.
Old 17th January 2025, 03:53   #10959  |  Link
fourbigkids
I adjusted the buffer from 50ms to 100ms, the only options available, and the issue persists.
Cheers ryrynz. I'll give that a whirl.
Old 17th January 2025, 04:13   #10960  |  Link
Aleksoid1978
If there are problems, then only a very small number of users/equipment.
The developers do not have a large amount of equipment for testing.
Anyone can sponsor the purchase of various equipment, but there are no volunteers
