17th November 2014, 16:21 | #1341 | Link |
MediaInfo is very versatile
Want to know all about your media files? http://mediaarea.net/MediaInfo |
19th November 2014, 22:56 | #1342 | Link |
Life's clearer in 4K UHD
DTS with 96/24 extension
Hi Zenitram,
I can't remember if anyone has brought this up before but currently when MediaInfo reads a media file that contains DTS audio that's been encoded with a 96/24 extension flag it's presented, like this: - Code:
Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : 96/24 / Core Mode : 16 Format settings, Endianness : Big Codec ID : 130 Duration : 59s 861ms Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 96.0 KHz / 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 10.8 MiB (47%) Language : English However, when MediaInfo reads a media file that contains DTS-HD MA audio along with a DTS core that also includes a 96/24 extension flag (as found on some Blu-ray HFPA disc's) it's presented very much the same as above, like this: - Code:
Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : 96/24 / Core Mode : 16 Format settings, Endianness : Big Muxing mode : Stream extension Codec ID : 134 Duration : 59s 851ms Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 96.0 KHz / 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 10.8 MiB (14%) Language : English Admittedly, there are very few Blu-ray HFPA disc's which contain DTS-HD MA audio along with a DTS 96/24 core in circulation (I only have three). But I thought you'd like to know Here's a link to a 60 second sample: https://www.sendspace.com/file/kav88b Cheers
19th November 2014, 23:39 | #1343 | Link | |
There is definitely a problem with the way I detect DTS extensions (I keep only one). I see both "lossless" extension "MA" and "96/24" extensions in your file. On my ToDo-list!
20th November 2014, 10:39 | #1344 | Link |
Thanks for the confirmation...
9th January 2015, 00:18 | #1345 | Link | |
Thanks for the new versin 0.7.72 I can confirm that this version now works again with a non-SSE2 CPU. The only thing I can't get working is the info tips (WinXP). Cheers manolito |
9th January 2015, 11:35 | #1347 | Link | |
FYI, there is also a bug with XML output. I'll release a new version soon.
15th January 2015, 20:54 | #1349 | Link |
I'm not sure whether here is the ideal place to ask for MediaInfoXP help, but I did check on LoRd_MuldeR's website, clicked on the MediaInfoXP help and support button, and here I am......
Are there any known issues with MediaInfoXP running on XP? I don't seem to be able to convince it to. Double clicking on MediaInfoXP.exe seems to do nothing. The GUI doesn't open. Am I missing something obvious? I've only tried the version found in the zip file "MediaInfoXP-GUI.2014-11-16.Win32". I think it's 2.13. Thanks. |
2nd February 2015, 00:45 | #1350 | Link |
Hello Zenitram,
thanks for MediaInfo, my app calls it all over the place, countless times. I'd like to report two issues: Using a m2ts file Codec/String shows 'TrueHD / AC3' but when demuxed to a thd+ac3 file with eac3to Codec/String shows only AC3. Code:
thd+ac3 Codec : TrueHD / AC3 Codec/String: AC3 m2ts Codec : TrueHD / AC3 Codec/String: TrueHD / AC3 Another issue is MediaInfo shows everything correct in a mkv file but after demuxing with mkvextract MediaInfo fails on the dts file. The sample is here, it includes both mkv and demuxed dts. |
2nd February 2015, 20:03 | #1351 | Link | |
Although the file version of MediaInfo is 0.7.71 whilst the --version parameter returns 0.7.72, so I'm not sure about which version is really used. Last edited by Brazil2; 4th February 2015 at 15:54. |
16th February 2015, 16:27 | #1352 | Link |
I wrote something about StaxRip's MediaInfo GUI, how it might be integrated into the windows explorer shell, the StaxRip executable might be used alone without all included apps or a new app might be created, it would be easy it separate if there is interest, conversion to C# would also be trivial as there are amazing conversion tools. http://forum.doom9.org/showpost.php?...postcount=4729 |
17th February 2015, 09:59 | #1353 | Link |
Hi Zenitram, PotPlayer(download) is unable to get media infomation when using 'native dxva + vanilla evr' combination with MediaInfo 0.7.71 and later version.
Press 'Ctrl+F1' during playback: http://i2.tietuku.com/7be5c998ac3e8b8c.png Well, it works fine with MediaInfo 0.7.70: http://i2.tietuku.com/e5c828ecf223bda0.png, so PotPlayer dev sticks to an old DLL file. According to PotPlayer dev, the bug is in MediaInfo side, would you take some time to have a look? Thanks. |
17th February 2015, 13:49 | #1355 | Link |
A bit harsh ;-).
I have some pending bugs about the XML output, maybe they use this output, so buggy. But it is in 0.7.72 only, not 0.7.71. Anyway, something weird is "when using (...)", MediaInfo is not aware of this player configuration, so I don't see the relationship between the player config and MediaInfo. I would appreciate some more details than "bug is in MediaInfo side", e.g. which MediaInfo output API is used and which buggy output is provided to the player.
17th February 2015, 14:51 | #1357 | Link |
He can (saying what is the issue with MediaInfo).
17th February 2015, 16:14 | #1358 | Link |
Software Developer
BTW: Is there any ETA for 0.7.73 yet?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th February 2015 at 16:18. |
17th February 2015, 16:23 | #1359 | Link |
ETA is February 1st, 2015. Yes, in the past!
More seriously, even my professional users are currently complaining about delays, and I have a business trip to the US next week and 2 big projects to finish before mid-March, so don't expect a release soon. BTW, if you are interested in being paid for fixing MediaInfo bugs, ping me.
17th February 2015, 16:41 | #1360 | Link | |
Software Developer
Sorry, my time is fully engaged already.
