Old 20th December 2010, 18:29   #8881  |  Link
angles
why ripbot why? ok new problem.. i have an .avi file.. i encode with ribot to ipod .mp4.. everything goes good.. but after clicking start.. it keeps on "please wait...initializing.." well ive been staring almost 2 hours at my display.. then aborted.. and tried again.. this time waited 4,5 hours..but it never gets past that!!!!!! why? i 4 times reinstalled all the codecs ffdshow, haALI, ETC,.. i dont know what to do anymore...help! before i trow away my laptop! lol...
angles is offline   Reply With Quote
Old 20th December 2010, 18:38   #8882  |  Link
pacaveli211
try a newer version off FFDshow
pacaveli211 is offline   Reply With Quote
Old 20th December 2010, 18:42   #8883  |  Link
angles
i have the newest version..
Old 20th December 2010, 19:04   #8884  |  Link
pacaveli211
try a full uninstall of ffdshow (anything ffdshow in control panel) reboot, delete any ffdshow folder remaining in program files
reinstall it, try again. maybe try the most recent older one as well.
is the video xvid?
Old 20th December 2010, 19:17   #8885  |  Link
Lighto
The Black Reaper
Lighto's Avatar
Anyone has any idea on how to get x264's slow preset working on RipBot?
I know it can be done on MeGUI by simply adjusting the slider.
Lighto is offline   Reply With Quote
Old 20th December 2010, 19:21   #8886  |  Link
pacaveli211
preset
Default: medium
Change options to trade off compression efficiency against encoding speed. If you specify a preset, the changes it makes will be applied before all other parameters are applied.
You should generally set this option to the slowest you can bear.
Values available: ultrafast, superfast, veryfast, faster, fast, medium, slow, slower, veryslow, placebo.
http://mewiki.project357.com/wiki/X264_Settings
so you should be able to just add --preset ______ to the line in whichever profile you're using
Old 20th December 2010, 19:22   #8887  |  Link
angles
is the video xvid?
yes the video is an xvid .avi file.. ill try again uninstualling
Old 20th December 2010, 19:39   #8888  |  Link
pacaveli211
if you still have problems you may want to try changing the codecs in ffdshow for xvid to something different
I believe there were other causes to this issue (other than codecs) you may want to try the 'search this thread' for the error and see what else you find
Old 20th December 2010, 19:44   #8889  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
... or switch off audio normalization in ripbot.
Old 20th December 2010, 20:29   #8890  |  Link
angles
thanks guys for trying to help me out..
it seems regarding the error that it keeps hanging on "please wait...initializing.." that the solution is this.. first i got tired of installing uninstalling ffdshow haali etc.. so then i thought.. let me try this..
1. uninstall all the codecs, haali, avisytinh, ffdshow.
2. then i installed kaaza mega codec pack 6 (while instaling i selected full and for xvid instead liba.. i selected xvid 1.3
3. after that i installed avisynth the latest beta version
4. i started up ripbot. opened my .avi file.. selected my ipod profile.
added my .sub subtitles. (this time i did not select the option of denoising)
5. i pressed start and it is now passed the please wait..initialization. its encoding the audio!!! yahoo.. now i hope nothing else will go wrong..
but still a few question.. what is normalisation? and what exacly is denoising? because i thought denoising was to remove the little grainy blocky artifacts u sometimes have on video files..
once again thanx.. and if someone else has the same error.. try the steps i took.. cant believe i wasted a whole day to figure this error out! lol
Old 21st December 2010, 02:51   #8891  |  Link
73ChargerFan
73ChargerFan's Avatar
Originally Posted by Usedocne View Post
Why not use --tune animation;
Googling it led me to change filter from 0,0 to 1,1.
My profile is now:
[MAIN 3.0] Cartoons.txt
--level 3.0 --tune animation --aud --nal-hrd vbr --vbv-bufsize 10000 --vbv-maxrate 10000 --filter 1,1
--ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 2
--partitions p8x8,b8x8,i4x4,p4x4 --no-8x8dct --me umh
I'm testing with a scene from a dvd, using CQ18 and resize down to 640x480.
Left is Source, Middle is no denoise, Right has Anime Denoise on
ps - sorry for not using thumbnail, imageshack really annoys me
OOPS - the images had filters enabled in mpc-hc, I'll have to try making them again...
73ChargerFan is offline   Reply With Quote
Old 21st December 2010, 03:28   #8892  |  Link
73ChargerFan
black blotches
The beginning of the cartoon is a dark grey background. The original is "dirty" with small blocks and a lot of noise.
The encode has huge moving black blocks, in a uniform grey background.
I had the same blotches when I tried encoding Batman TAS a few years ago, and I gave up. Is there something I can do about it now? I did not adjust colors for this encode.
Old 21st December 2010, 07:28   #8893  |  Link
benjyv
benjyv's Avatar
I hope someone will dare to answer this question:
How can I access the option " poster " ?? how would I be able to view it ??
Well, Atak??
...being the newest improuvement of this soft, you could kindly solve this problem and respond to my question without having to come back and insist so much.. ;-)
benjyv is offline   Reply With Quote
Old 21st December 2010, 20:35   #8894  |  Link
Atak_Snajpera
http://forum.doom9.org/showthread.ph...40#post1418040
Old 22nd December 2010, 05:46   #8895  |  Link
benjyv
benjyv's Avatar
Yeah, I remember that screenshot ...
Nor the first time and even now I didn't understood how can I see that posters...
Maybe should I have installed Vista or Win 7 , because On my Win XP SP3 cannot see the posters
I just can see these :
Confusion in my head regarding this topic is like the beginning ....
If you don't define this topic I understand that it is a superfluous issue which not deserve attention..
Thanks anyway for your answer....
Old 22nd December 2010, 10:45   #8896  |  Link
legend63
hello, how to crop when resize to 1280X720?
legend63 is offline   Reply With Quote
Old 22nd December 2010, 12:13   #8897  |  Link
soneca
benjyv,
Only works for mp4 files.
soneca is offline   Reply With Quote
Old 22nd December 2010, 13:24   #8898  |  Link
benjyv
benjyv's Avatar
THANKS SONECA !!!!!
finally....
Old 23rd December 2010, 01:57   #8899  |  Link
diggityDawg
I'm sure this has been answered, but can't find it in a search of the thread... Just downloaded the latest version and it requires Java. So I downloaded and installed JRE 6u23. Still says I don't have it installed. I rebooted, still says I don't have installed. I tried to install Java again, just to be sure, and it says it's installed, do I want to remove it. It's definitely installed, so why does RB keep saying it's not? How do I get around this so I can run it? THX!!
diggityDawg is offline   Reply With Quote
Old 23rd December 2010, 11:29   #8900  |  Link
zazon
Running a .m2ts through RipBot and I'm getting a demuxing error message. Here's my log:
eac3to v3.24
command line: "D:\Blu\RipBot\Tools\eac3to\eac3to.exe" "E:\Usual Suspects.m2ts" 1: "D:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 2: "D:\temp\RipBot264temp\job1\audio_Undetermined.dtsma.w64" -down16 -progressnumbers -log="D:\temp\RipBot264temp\job1\demuxlog.txt"
M2TS, 1 video track, 1 audio track, 1 subtitle track, 1:46:04, 24p /1.001
1: MPEG2, 1080p24 /1.001 (16:9)
2: DTS Master Audio, 5.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz)
3: Subtitle (SRT)
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Decoding with ArcSoft DTS Decoder...
[a02] Reducing depth from 24 to 16 bits...
[a02] Writing W64...
[v01] Muxing video to Matroska...
[a02] Creating file "D:\temp\RipBot264temp\job1\audio_Undetermined.dtsma.w64"...
[a02] The ArcSoft DTS Decoder reported an error while decoding. <ERROR>
Aborted at file position 15589179392. <ERROR>
zazon is offline   Reply With Quote
