11th February 2010, 17:09 | #122 | Link |
No, I just showed up at my PC and it was like that.
another weird thing is that after it failed, I decided to start it again. So i clicked "start". At this point everything had been already demuxed and the stream list was already populated. Whats weird is that the encoding finished, but it looks like it never remuxed anything. So in the working folder, I have the mkv file it made called <prefix>_video.mkv that seems to be complete but in my target folder is empty. Also, the working directory button is broken in the SVN. I don't know anything about windows programming, as I am a J2EE programmer by profession, but are you looking for any help with this app? Last edited by mackworth; 11th February 2010 at 17:46. |
12th February 2010, 08:39 | #123 | Link | |
BluRip author
I'll take a look, why it won't mux after an error. I'll also check the working directory button. If you think that you can help me with C# that would be great
BluRip : 1-Click BluRay/m2ts to h264 mkv converter http://code.google.com/p/blurip/ |
12th February 2010, 08:40 | #124 | Link |
BluRip author
Thanks. Maybe I'll add this for the queue (you always can queue a single project).
15th February 2010, 00:33 | #125 | Link | |
DirectoryInfo di = Directory.GetParent(settings.workingDir); If settings.workingDir is empty, then this throws an exception, so I just moved the settings.workingDir != "" to include that. Would it be worth adding another tab, maybe for UI exceptions? How about splitting up MainForm.cs to make it a little more "manageable"? Visual Studio is def a lot different than Eclipse, that's for sure. Is there anything easy that needs to get done that I can take a swing at? |
15th February 2010, 23:24 | #127 | Link |
BluRip author
Yep, good idea. I'll add this.
18th February 2010, 00:33 | #130 | Link |
BluRip author
Its already in current svn. Will be in next version.
18th February 2010, 00:34 | #131 | Link |
BluRip author
What options do you mean?
18th February 2010, 02:19 | #132 | Link |
DVD Magistrate
hi....the options I am referring to are in mkvmerge...check the gui out. There you can add in info about the mkv, such as aspect ratio of the video; I often find it useful to have the aspect ratio specifed.
also, mkvmerge needs frame rate of h264 to be specified manually (usually 24000/1.001 unless interlaced). Do you pass this along in the muxing to mkv? thanks for a great program!!! |
18th February 2010, 04:55 | #134 | Link |
@toathis
did you replace the included MediaInfo.dll? what version of BluRip are you using? @_hawk_ what's the eta on the next release i cant wait to see what you coded buddy keep up the great work
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 18th February 2010 at 07:09. |
18th February 2010, 09:15 | #135 | Link |
BluRip author
Maybe I finish new version today.
Atm I don't pass any options to mkvmerge. I demux video as mkv so info about framerate should not be lost? If its necessary I'll add this.
18th February 2010, 13:58 | #136 | Link |
BluRip author
New version online:
v0.4.5 - DGDecNv support - Option to use untouched audio - Option to shutdown after queue - Option to convert DTS to AC3 - More subtitle mux/copy options - Recognize more Ac3 types
18th February 2010, 15:26 | #137 | Link | |
DVD Magistrate
When I use eac3to manually to demux a blu ray and it is h264 and whatever audio, when I use mkvmergui it tells me I manually need to specify the frame rate of H264 as mkvmerge cannot detect the frame rate as it is (unlike VC-1 which it can detect the frame rate). Try it out with mkvmerge gui frm the mkvtoolnix package and you will see this. So I suspect you will need to add this into your gui for the user to add. In 99.9% of cases (unless interlaced) the frame rate will be 24000/1001. thanks |
18th February 2010, 15:28 | #138 | Link | |
DVD Magistrate
thanks for the update...Cheers!!! Last edited by ron spencer; 18th February 2010 at 20:35. |
18th February 2010, 15:38 | #139 | Link | |
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264 |
