28th January 2008, 16:09 | #81 | Link |
@glen8
I just tried this with Txformrs and it didn't play back on my Pc properly but that might be due to it being an old P4. SMPlayer seemed to try and play it back but in slomo. The aspect ratio did look correct but could not be displayed for the file properties. MPC plays back a really strange video - 112x3840 is the playback resolution! Tall and narrow! Weird! I'm going to try splitting this final .m2ts I made and then try it on the USB HDD into the PS3. Please try it yourself and make sure you select to change the fps to "24/1001" in the selection when you go to mux your audio and video. Let us know if it works for you. |
28th January 2008, 16:11 | #82 | Link | |
28th January 2008, 16:17 | #83 | Link | |
I have tried many things to get HD-DVD over to Blu-Ray and nearly succeeded lastnight. I can get the video changed to 23.976 no probs but the audio is always out by 5secs. I tried adding a delay -5000 which makes no difference. It's weird!! I already have transformers on blu-ray so I know it's possible I shall try this new tool tonight Last edited by glen8; 28th January 2008 at 16:20. |
28th January 2008, 16:27 | #84 | Link | |
28th January 2008, 17:19 | #85 | Link |
@glen8
Just tried it before work and it worked great! It looked like the audio was in perfect sync but I could only play a few minutes. I will try all the segments tonight. Because of the fat32 limitation for the external USB HDD we have to cut each segment to not more than 4GB. I will also try re-encoding to x.264 to get the movie smaller in size, hopefully tonight. Now the question becomes can tsmuxer do the same for a VC1 movie?? I don't believe that the PS3 can playback a VC1 movie from the XMB (cross media bar). Luckily Txformrs was AVC/x.264 and it worked. Can anyone else shed light on whether a VC1 movie will work from XMB or is it just from a disc?? |
28th January 2008, 17:24 | #86 | Link |
great tool - I have successfully converted an AVC stream from HDDVD to bluray (with Tsremux help) and converted audio to ac3. It plays fine on PS3 when i do as is.
further observations - video is flagged at 29.97fps - when i select 23.97 as frame rate, it stutters, no longer smooth wish for future versions: blu ray option (like tsremux) with setting of time stamps and correct signalling of multiple audio streams ; possibility to set language code to be included in playlist |
28th January 2008, 17:56 | #87 | Link |
musicman,
Can you please detail all the steps you took to convert your HD-DVD AVC to Bly-Ray please. I have Top Gun sat at home so I can try that tonight. I have already demuxed the AVC H.264 stream and eac3to the DD+ to AC3 I will report back my findings. Thanks. |
28th January 2008, 18:27 | #88 | Link |
Well i tried a wmv yesterday that was 1920 x 800
i extracted the vc1 stream and muxed to m2ts with tsmuxer. After muxing to blu-ray with tsremux video plays on ps3 but with big green bar on bottem... so its not working I havent tried x264 with tsmuxer yet, but from earlyer experience with other tools its the same result. |
28th January 2008, 19:09 | #89 | Link |
hi again, unfortunately I noticed that even with unchanged settings, i.e. kept the 29.97 fps, playback was still not smooth. I will do it again to exclude errors on my part.
What I did: 1. add feature 1.evo 2. append feature 2.evo 3. remove any audio tracks shown 4. add ac3 elementary stream file (converted earlier with eac3to) 5. run tsmuxer with .m2ts output 6. run result through tsremux 0019 with blu ray output (folders) 7. burn on BD-RE (for testing) 8. play on PS3 ok? PS: I noted that latest version (1.2.3) showed less audio streams (one) from evo compared to version 1.2.0 (showed all) |
28th January 2008, 19:30 | #90 | Link |
Wow, this is RAPID development:-)
I am holding to my copy of The Lives of Others on Blu-Ray, hoping that Roman will implement subtitles soon, so I can put it on my hard drive as an MKV and put away the disk (I hate dealing with disks:-). |
28th January 2008, 19:49 | #91 | Link |
Thanks musicman
I just tried pretty much the same thing. It works on the PS3 but the audio is well out of sync. Tested on Nero showtime and its out aswell, fps shows as 24fps and video and sound look ok (ie no slowdown) Tried again with 24000/1001 setting. This time audio and video are in perfect sync, audio is great but video has some very slight slowdown...nero reports as 19fps whereas Elecard converter studio tells me its 23.98fps It's only very very slight but enough to put you off watching it If this guy can get HD-DVD > Blu-Ray working I think this will be the tool of 2008!!!!! :edit: I'm going to try running the video through H.264Info and manually setting the framerate throughout the entire file. Then muxing with this tool. Worth a try I guess Last edited by glen8; 28th January 2008 at 20:11. |
28th January 2008, 21:39 | #93 | Link | |
please also state which version of h264info you used and what movie. I had problems with h264info and recent movies on hddvd |
28th January 2008, 22:08 | #96 | Link | |
29th January 2008, 00:17 | #98 | Link |
Thanks again for a great apps, just wanted to mention a bug i found.
I remuxed 2 Blu-rays since they only had DTS or True Dolby tracks an no PS3 compatible AC3 tracks. I re-did the audio with eac3to, then I added the original /Stream/000xx.M2TS from the BD into TSmuxer, and then added the new .AC3 muxed them together as m2ts and everything looked good. However on both videos, I noticed about 12-20 visible video glitches throughout the movie. I suspected it may have something to do with the straight use of the .M2TS.. Witht the same movies, I then used xport to demux the H264 AVC file seperately, then I muxed the AVC+the recoded AC3 together with Tsmuxer, and watched the same movies, and they did not display any video glitches. Perhaps this is a bug, just wanted to report my findings. Since I used the same method on both BDs. I'm also having trouble creating a 1080 AVC file to mux and playback on PS3, can anyone point me to a guide for converting a VC1 to H264 (playable on ps3). I used to convert a VC1 HD-DVD to Mpeg2 with no problems using Henc, however since the birth of Tsmuxer, I figure I'll increase quality and save space by instead encoding to AVC/X264 Thanks for all of the help. ps. for the above poster. VC1 remuxed into a .TS container does not work for ps3. VC1 is only playable in a WMV and it's very picky, from what i have seen, no-one has successfully remuxed a VC1 HD-DVD into WMV without a complete re-compression for PS3 play. |
29th January 2008, 01:36 | #100 | Link | |
tsmuxer |
