7th October 2021, 04:38 | #61 | Link |
New problem,...
I updated VSGAN: Code:
I:\Hybrid\64bit\Vapoursynth>python -m pip install --upgrade vsgan Requirement already satisfied: vsgan in i:\hybrid\64bit\vapoursynth\lib\site-packages (1.2.1) Collecting vsgan Downloading vsgan-1.3.0-py3-none-any.whl (10 kB) Collecting torch<2.0.0,>=1.9.1 Using cached torch-1.9.1-cp39-cp39-win_amd64.whl (222.0 MB) Collecting numpy==1.19.5 Downloading numpy-1.19.5-cp39-cp39-win_amd64.whl (13.3 MB) |████████████████████████████████| 13.3 MB 2.2 MB/s Requirement already satisfied: typing-extensions in i:\hybrid\64bit\vapoursynth\lib\site-packages (from torch<2.0.0,>=1.9.1->vsgan) (3.10.0.2) Installing collected packages: torch, numpy, vsgan Attempting uninstall: torch Found existing installation: torch 1.9.0+cu111 Uninstalling torch-1.9.0+cu111: Successfully uninstalled torch-1.9.0+cu111 WARNING: The scripts convert-caffe2-to-onnx.exe and convert-onnx-to-caffe2.exe are installed in 'I:\Hybrid\64bit\Vapoursynth\Scripts' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. Attempting uninstall: numpy Found existing installation: numpy 1.21.2 Uninstalling numpy-1.21.2: Successfully uninstalled numpy-1.21.2 WARNING: The script f2py.exe is installed in 'I:\Hybrid\64bit\Vapoursynth\Scripts' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. Attempting uninstall: vsgan Found existing installation: vsgan 1.2.1 Uninstalling vsgan-1.2.1: Successfully uninstalled vsgan-1.2.1 ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts. torchvision 0.10.0+cu111 requires torch==1.9.0, but you have torch 1.9.1 which is incompatible. torchaudio 0.9.0 requires torch==1.9.0, but you have torch 1.9.1 which is incompatible. Successfully installed numpy-1.19.5 torch-1.9.1 vsgan-1.3.0 I:\Hybrid\64bit\Vapoursynth>python -m pip install --upgrade vsgan Requirement already satisfied: vsgan in i:\hybrid\64bit\vapoursynth\lib\site-packages (1.3.0) Requirement already satisfied: torch<2.0.0,>=1.9.1 in i:\hybrid\64bit\vapoursynth\lib\site-packages (from vsgan) (1.9.1) Requirement already satisfied: numpy==1.19.5 in i:\hybrid\64bit\vapoursynth\lib\site-packages (from vsgan) (1.19.5) Requirement already satisfied: typing-extensions in i:\hybrid\64bit\vapoursynth\lib\site-packages (from torch<2.0.0,>=1.9.1->vsgan) (3.10.0.2) Code:
Failed to evaluate the script: Python exception: VSGAN: Either NVIDIA CUDA or the device (cuda) isn't available. Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 2324, in vapoursynth.vpy_evaluateScript File "src\cython\vapoursynth.pyx", line 2325, in vapoursynth.vpy_evaluateScript File "C:\Users\Selur\Desktop\test2.vpy", line 29, in <module> vsgan = VSGAN("cuda") File "I:\Hybrid\64bit\Vapoursynth\Lib\site-packages\vsgan\__init__.py", line 34, in __init__ raise EnvironmentError("VSGAN: Either NVIDIA CUDA or the device (%s) isn't available." % device) OSError: VSGAN: Either NVIDIA CUDA or the device (cuda) isn't available. Code:
# Imports import os import sys import vapoursynth as vs # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") # Import scripts import mvsfunc # source: 'G:\TestClips&Co\files\test.avi' # current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive # Loading source using FFMS2 clip = core.ffms2.Source(source="G:/TestClips&Co/files/test.avi",cachefile="E:/Temp/avi_6c441f37d9750b62d59f16ecdbd59393_853323747.ffindex",format=vs.YUV420P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Bicubic(clip, matrix_in_s="470bg",range_s="limited") # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) from vsgan import VSGAN # adjusting color space from YUV420P8 to RGB24 for vsVSGAN clip = core.resize.Bicubic(clip=clip, format=vs.RGB24, matrix_in_s="470bg", range_s="limited") # resizing using VSGAN vsgan = VSGAN("cuda") model = "I:/Hybrid/64bit/vsgan_models/4x_BSRGAN.pth" vsgan.load_model(model) clip = vsgan.run(clip=clip) # 2560x1408 # adjusting resizing clip = core.fmtc.resample(clip=clip, w=1920, h=1056, kernel="lanczos", interlaced=False, interlacedd=False) # adjusting output color from: RGB48 to YUV420P10 for x265Model clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, matrix_s="470bg", range_s="limited") # set output frame rate to 25.000fps clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Output clip.set_output( Cu Selur |
8th October 2021, 05:39 | #63 | Link | |
PyTorch honestly isnt normally meant to have cuda bundled, its just a possible installation method. By default/normally, it expects it installed on the system globally of course, which is why this deps installation *can* work, but wont for a portable install or those who dont want to manually install cuda. Regardless, I'm glad you have it solved. To reiterate, a new troubleshooting page exists which has this issue listed, if you encounter further issues perhaps refer to it: https://rlaphoenix.github.io/VSGAN/troubleshooting/ |
21st December 2021, 16:56 | #65 | Link |
Chaining models is broken in v1.4.0 due to a FrameEval mistake. Please install from source code or wait for the next version which will be soon hopefully.
Edit: Fixed in 1.4.1 Last edited by PRAGMA; 22nd December 2021 at 01:22. |
22nd December 2021, 01:22 | #66 | Link |
RealESRGAN support has been added. It's code is NOT great, but it works. Its basically using new-arch of normal ESRGAN (which is restrictive and annoying) but is necessary for the new models RealESRGAN uses.
It will be in the next release after 1.4.1. EDIT: Full Real-ESRGAN support, including 2x and 1x scale models is added to code, and it no longer uses new-arch, so it works a lot better now. It will be in v1.5.0. Last edited by PRAGMA; 23rd December 2021 at 18:44. |
27th December 2021, 05:37 | #68 | Link |
Thanks also for A-ESRGAN
https://github.com/aesrgan/A-ESRGAN Code:
v1.5.0 Latest Adds support for ESRGAN+ models, Real-ESRGAN models (including 2x and 1x if pixel-shuffle was used), and A-ESRGAN models |
29th December 2021, 09:08 | #69 | Link |
Ok so more updates.
Support for half-accuracy was added to all models. This means you can reduce accuracy, which reduces VRAM in ultimately half, which also increases speed by up to double in some cases. It will decrease the accuracy of course, but yeah. For those with very limited VRAM, half accuracy + seamless chunk mode may help quite a bit. This half mode will be applied when you use load_model with `half=True` and will be added to the next version (probably 1.5.1). Support for ESRGAN+, Real-ESRGAN, and A-ESRGAN are now supported in v1.5.0. With Real-ESRGAN v2 (basically ultra-lite Real-ESRGAN) coming in the next version. What may appear in next version, if not then the version after is support for EGVSR, which is an inter-frame architecture taking in data from n neighboring frames. It's still in testing and still being worked on but its going well. It is at a state where basic models work, but detection of arch settings has not been worked on yet. Once auto-detection of arch settings can be done, support will be added in whatever the next version from then is. |
30th December 2021, 13:04 | #71 | Link |
nice
From my experience with other FP16 Models, Quality still is fine in most cases - and the speedup (on FP16 2:1 vapable cards like recent AMD, GEN20 RTX..) as well as the halved VRAM needed is a very good thing - rarely turning back to FP32 models these days. |
24th January 2022, 09:05 | #72 | Link |
Ok v1.6.0 has been released, with a fairly big change to how VSGAN is ultimately used. This update includes the previously talked about features like half-precision, Real-ESRGANv2, EGVSR, and more.
There's also an upgraded tiling system that will automatically enable or disable depending on if you need the VRAM or not. It will also recursively tile to reduce VRAM even further (if necessary of course). Please note though, that EGVSR does not auto-detect settings from the model file yet. So you should manually override any settings that needs it when you load the model for correct results. For more details see the changelog: https://vsgan.phoeniix.dev/en/stable/changelog.html Last edited by PRAGMA; 24th January 2022 at 09:12. |
24th January 2022, 15:37 | #73 | Link | |
Thanks for adding EGVSR.
I'm getting bizarre results with the "EGVSR_iter420000.pth" model - it looks like some fine grid pattern overlaid |
24th January 2022, 18:18 | #74 | Link | |
maybe this issue was made by you? not sure. |
24th January 2022, 18:24 | #75 | Link | |
(That guy should IVTC first) Adding nb=10, degradation="BD" fixes it, thanks Code:
load(r'PATH\EGVSR_iter420000.pth', nb=10, degradation="BD") |
24th January 2022, 19:48 | #76 | Link |
Small question, so when using a ESRGAN,ESRGAN+,Real-ESRGAN or A-ESRGAN model I use
from vsgan import ESRGAN Code:
from vsgan import EGVSR Also: Does anyone know a source for EGVSR models? (only one I found so far is from https://github.com/Thmen/EGVSR/tree/...trained_models) Last edited by Selur; 24th January 2022 at 20:05. |
24th January 2022, 19:59 | #77 | Link | ||
24th January 2022, 21:00 | #78 | Link |
Ah, okay.
Things seem to work fine with ESRGAN models (like BSRGAN), but using: Code:
# Imports import os import sys import vapoursynth as vs # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") # Import scripts import mvsfunc # source: 'G:\TestClips&Co\files\test.avi' # current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive # Loading source using FFMS2 clip = core.ffms2.Source(source="G:/TestClips&Co/files/test.avi",cachefile="E:/Temp/avi_6c441f37d9750b62d59f16ecdbd59393_853323747.ffindex",format=vs.YUV420P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Bicubic(clip, matrix_in_s="470bg",range_s="limited") # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # adjusting color space from YUV420P8 to RGB24 for vsVSGAN clip = core.resize.Bicubic(clip=clip, format=vs.RGB24, matrix_in_s="470bg", range_s="limited") # resizing using VSGAN from vsgan import EGVSR vsgan = EGVSR(clip=clip,device="cuda") model = "I:/Hybrid/64bit/vsgan_models/4x_iter420000_EGVSR.pth" vsgan.load(model, nb=10, degradation="BD", out_nc=3, nf=64) vsgan.apply() # 2560x1408 clip = vsgan.clip # adjusting resizing clip = core.fmtc.resample(clip=clip, w=1920, h=1056, kernel="lanczos", interlaced=False, interlacedd=False) # adjusting output color from: RGB48 to YUV420P8 for x264Model clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P8, matrix_s="470bg", range_s="limited") # set output frame rate to 25.000fps clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Output clip.set_output() Code:
CUDA out of memory. Tried to allocate 56.00 MiB (GPU 0; 8.00 GiB total capacity; 6.62 GiB already allocated; 0 bytes free; 6.76 GiB reserved in total by PyTorch) If reserved memory is >> allocated memory try setting max_split_size_mb to avoid fragmentation. See documentation for Memory Management and PYTORCH_CUDA_ALLOC_CONF Code:
Python exception: apply() got an unexpected keyword argument 'overlap' Cu Selur |
24th January 2022, 21:31 | #80 | Link |
Okay, also got another issue with the current version.
Using: Code:
# Imports import os import sys import vapoursynth as vs # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") # Import scripts import mvsfunc # source: 'G:\TestClips&Co\files\test.avi' # current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive # Loading source using FFMS2 clip = core.ffms2.Source(source="G:/TestClips&Co/files/test.avi",cachefile="E:/Temp/avi_6c441f37d9750b62d59f16ecdbd59393_853323747.ffindex",format=vs.YUV420P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Bicubic(clip, matrix_in_s="470bg",range_s="limited") # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # adjusting color space from YUV420P8 to RGB24 for vsVSGAN clip = core.resize.Bicubic(clip=clip, format=vs.RGB24, matrix_in_s="470bg", range_s="limited") # resizing using VSGAN from vsgan import ESRGAN vsgan = ESRGAN(clip=clip,device="cuda") model = "I:/Hybrid/64bit/vsgan_models/4x_BSRGAN.pth" vsgan.load(model) vsgan.apply() # 2560x1408 clip = vsgan.clip # adjusting resizing clip = core.fmtc.resample(clip=clip, w=640, h=352, kernel="lanczos", interlaced=False, interlacedd=False) # adjusting output color from: RGB48 to YUV420P8 for x264Model clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P8, matrix_s="470bg", range_s="limited") # set output frame rate to 25.000fps clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Output clip.set_output() when using "vsgan.apply(overlap=16)" the same happens. -> at least here the new version does only work for one frame. I also tried different other models, all seem to have the same effect on my system. I sometimes I can step through a few frames (two work, third always fails), but then vram gets stuck and thats it. Last edited by Selur; 24th January 2022 at 21:33. |
esrgan, gan, upscale, vapoursynth |
