14th October 2022, 11:39 | #581 | Link | |
- There is a maintenance release available, it has two important bug fixes. https://github.com/mpvnet-player/mpv.net/releases I'm kind of in a similar situation than with staxrip, no longer using the application since I migrated to Linux in order to properly learn Linux. I moved the project to https://github.com/mpvnet-player/mpv.net, opening it up for collaboration, in case somebody interested helping with maintenance and implementing Linux support.
8th November 2022, 20:53 | #582 | Link | |||
(It didn't, for me.) Quote:
16th November 2022, 21:25 | #583 | Link |
Just to note (mpv updated to an 0.35 release) & the libmpv (mpv-2.dll, from https://sourceforge.net/projects/mpv.../files/libmpv/) looks to be fine in mpv.net.
8th December 2022, 16:52 | #585 | Link |
Not that I know what "dolby visision" is, per se... but if this is "dolby vision"...
https://developer.dolby.com/tools-me...ision-streams/ https://media.developer.dolby.com/Do..._15200kbps.mp4 then I don't know that you need to do anything "special" at all. Simply open the file in mpv.net. |
13th December 2022, 05:02 | #586 | Link | |
iOS_P5_GlassBlowing2_1920x1080@59.94fps_15200kbps.mp4 Pink instead of red. And other color distortions. As far as I remember, the same problem in mpv. There is something that needs to be forced to configure for such videos, which is very inconvenient, because I have different types of videos (SD, HD and others). I would like to hear an explanation from the developers about this.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
13th December 2022, 09:09 | #587 | Link |
_
Sorry I don't know anything about HDR, Dolby Vision, 4k. I don't know how you can use settings in mpv.net but in mpv, to test latest fixes, you need to use gpu-next option (which allows the use of libplacebo).
In mpv, you need to have a line with vo=gpu-next in your config (mpv.conf) For the original question, I'm letting the pros answer you (maybe nevcairiel has answers since he works on libplacebo). |
16th January 2023, 18:41 | #589 | Link |
I mention MPV_HOME back here, http://forum.doom9.net/showthread.ph...64#post1944164.
Now where it's at currently, if actually used or not, not quite sure? Though, mpv.net can use a /portable_config/ directory (within the program's "instalDir") to make a "portable" configuration (if you will). |
21st January 2023, 09:16 | #590 | Link |
I don't remember it, so probably not supported, I created a ticket for it here:
https://github.com/mpvnet-player/mpv-gui/issues/3
20th July 2023, 20:07 | #595 | Link | |
Took me forever to trace the problem to the .dll change, but had to roll back to the mpv-2.dll bundled with mpvnet. Last edited by djones; 20th July 2023 at 20:12. |
17th August 2023, 11:21 | #596 | Link |
Version 6.0.4.0 is released.
https://github.com/mpvnet-player/mpv...6.0.4.0-stable |
3rd October 2023, 20:18 | #598 | Link | |||
Here, Windows 7 #12330. (I like the second comment ;-).) Last edited by therube; 3rd October 2023 at 20:32. |
12th November 2023, 12:35 | #599 | Link |
I am currently looking into the edl function and I did get it to work on mplayer relatively fast after a few trial&errors.
But I can't figure out the syntax in mpvnet ! Maybe I am just to blind to see the obvious. So, to make it easy, I did put the video and the edl into the mpvnet-directory. Fired up a consol and tried : mpvnet edl:// 01.edl then: mpvnet edl://01.edl then: mpvnet -edl:// 01.edl So I thought that maybe it expects txt-files and tried the same again with 01.txt. # mpv EDL v0 WhiteRabbitJeffersonAirplane.mp4,30,20 # The video plays otherwise just fine. Does anyone maybe have any ideas ?
MPC-BE feature wishlist: 1) DiscID 2) Two independent volume control sliders in the UI when using dual-audio-out. |
21st November 2023, 10:10 | #600 | Link |
Does it play with mpv? In that case, it's likely a mpv.net bug.
