Old 25th August 2014, 03:08   #41  |  Link
alexxdls
Originally Posted by Myrsloik View Post
And remember that ffms2 also works for image reading if you want to try something else.
I dubt it supports high bit depth images...
alexxdls is offline   Reply With Quote
Old 25th August 2014, 12:35   #42  |  Link
kolak
It does, as it's based on ffmpeg.
Old 27th October 2014, 12:29   #43  |  Link
vcmohan
! am confused. I tried to load the imwri.dll from test3.
It gave a message cannot load plugin
Should I use test 2 plugin? I am using 32 bit only.
mohan
my plugins are now hosted here
vcmohan is offline   Reply With Quote
Old 6th November 2014, 03:06   #44  |  Link
Reel.Deel
@Myrsloik
Any possibility of a single plugin for r25?
Old 6th November 2014, 10:34   #45  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by Reel.Deel View Post
@Myrsloik
I at least have one workaround in mind so dllpath won't be needed anymore now that plugins can get their own path in r25. No idea if my mingw skills will be enough to slap it into single file submission though. But I'll try. Higher on the list is alpha support in FFMS2 though. Poor linux users can have no alpha...
Myrsloik is offline   Reply With Quote
Old 25th November 2014, 16:54   #46  |  Link
Myrsloik
Myrsloik's Avatar
Posted test4 in both 32 and 64 bit versions. This one removes dllpath and needs vs R25. In combination with vs R25 it can easily be loaded with loadplugin or autoloaded (if you dump that huge lump of files into the autoload directory, not recommended but it should work).
It also has a slightly newer imagemagick but with ffmpeg.exe removed (don't try to read mpeg files it). Try it and see what happens. Apart from being usable there are no other improvements since I don't feel like making my own imagemagick distribution.
Old 21st December 2014, 00:16   #47  |  Link
MonoS
I get this error using VapourSynth Editor
vapoursynth.Error: Read: Failed to read image properties: vsedit-32bit.exe: RegistryKeyLookupFailed `CoderModulesPath' @ error/module.c/GetMagickModulePath/662
The script is this one
import vapoursynth as vs
core = vs.get_core()
core.std.LoadPlugin("C:/Program Files (x86)/VapourSynth/plugins32/imwri/imwri.dll")
src = core.imwri.Read('C:/Users/MonoS/Desktop/Personale/B2wAZhvIgAEraOP.png')
src.set_output()
MonoS is offline   Reply With Quote
Old 21st December 2014, 00:22   #48  |  Link
Myrsloik
Myrsloik's Avatar
Does that happen with all image files or just that one? Does it work outside the editor?
Old 21st December 2014, 17:12   #49  |  Link
MonoS
Nothing, tried using vspipe and changing file, but nothing, still the same error
Old 23rd December 2014, 15:05   #50  |  Link
18fps
What it does not supports is image sequences, only single images.
18fps is offline   Reply With Quote
Old 27th December 2014, 15:35   #51  |  Link
kolak
It does support sequences also, just use ffmpeg naming convention for image sequences.
Old 7th January 2015, 21:06   #52  |  Link
Myrsloik
Myrsloik's Avatar
Confirmed. Apparently it still looks for the already installed imagemagick binaries for some reason.
Old 14th January 2015, 00:18   #53  |  Link
Myrsloik
Myrsloik's Avatar
After an evening of debugging I can proudly report that ImageMagick has some of the worst code I've looked at in a while. Including my own ancient YATTA code.
It automatically initializes itself when its dlls are loaded and it misuses its own api to set the path to use so it can never work. I suggest you send hate letters to the ImageMagick developers so they stop writing code. The world will be better off that way.
Old 14th January 2015, 02:32   #54  |  Link
Reel.Deel
That's a pity to hear that. If I'm understanding correctly this is the end of imwri? Are there better alternatives? Could ffmpeg be used to write images (similar to ffms2 but for exporting)?
Old 14th January 2015, 02:37   #55  |  Link
Myrsloik
Myrsloik's Avatar
It's only a maybe end. If they apply the changes in my bug report it can still be made to work. Have to wait and see. I could also compile my own fixed binaries but that's extremely annoying and the build system on windows is a joke.
Old 14th January 2015, 14:55   #56  |  Link
Myrsloik
Myrsloik's Avatar
A small update. My fix has been accepted and the next ImageMagick release will have it. Expect a new and finally properly self contained release when version 6.9.0-4 is out.
Old 19th January 2015, 01:38   #57  |  Link
MonoS
The impossible is happened
Thank you
Old 28th January 2015, 23:45   #58  |  Link
Myrsloik
Myrsloik's Avatar
HAHAHA! YOU THOUGHT THE STORY WOULD END HERE? FOOLS!
The ImageMagick developers decided to simply release the broken 6.9.0-3 binaries as 6.9.0-4. Because why not? They've now wasted yet another evening for me. Maybe one day they'll get around to release updated binaries...
Old 29th January 2015, 12:47   #59  |  Link
MonoS
WTF, wonderful!
I saw some 7.0 binaries in some repo, maybe they are preparing your commit for the next release??
Old 12th February 2015, 00:36   #60  |  Link
Myrsloik
Myrsloik's Avatar
Here's test6. Tell me if it works. Only briefly tested.
Had to compile my own imagemagick binaries because that's how shit the official ones are. At least it appears to work.
