Old 25th June 2023, 00:21   #1  |  Link
Argaricolm
AVS Softlight
Realization of cuda soflight negative average blend.
Example
Brightness example
Plugin is x64 (cuda toolkit 12.3 & 11.8)
You could see on youtube videos about removing color cast using photoshops softlight blend of negative average. This is a cuda realization of it that process every frame.
Input is YUV420, YUV444, RGB32(BGR - avisynth only).
There are different modes:
Softlight(mode)
Mode 0 is default.
I'll explain first mode in detail.
Steps done in first mode:
1. YUV->RGB conversion
2. Calculates sums of all pixels in R,G,B planes (for each).
3. Get average from these sums (sum / number of pixels).
4. Get negative from this sum (255 - sum)
5. Use softlight blend of each plane with above negative. After this step we have same as photoshop does. But brightness of frame will be changed. To have brightness intact we need to restore it to original. That what other steps do.
6. We get HSV planes. V plane from orignal image (RGB > V). And HS from result after softlight. Then we do HS(changed) + V(original) -> RGB -> YUV
So first mode will neutralize only colors (hue + saturation) in frame and not brightness (volume).
Also keep in mind that you need to remove black bars in video for correct processing (if there are any). Or they will affect average sum.
1 mode:
Same as mode 0 but planes S & V restored to their original values. So this mode only normalizes lightness/brightness and does not change colors.
2 mode:
Same as mode 0. But plane S is also boosted (softlight is done for each pixel with itself).
3 mode:
Same as first but without brightness restoration. Use it if you want to make brigtness also average (makes dark frames brighter).
4 mode:
Same as mode 3 but each of RGB planes are boosted using softlight.
5 mode:
YUV->RGB->softlight each RGB plane with itself->YUV (color/contrast boost)
6 mode:
YUV->RGB->HSV->boost S->RGB->YUV
8 mode:
TV to PC color range conversion (use it on videos where you see no total black and only grays).
10 mode:
Grayscale.
For RGB32 - this mode uses RGB -> YUV444 -> RGB cuda conversion. U & V planes are set to 128.
For YUV - just U & V planes are set to 128 without cuda.
You can use 3 different softlight formulas:
formula = 0,1,2
0 - pegtop
1 - illusions.hu
2 - W3C
In my opinion - pegtop fomula is the best.
Also mode 1 & mode 3 are my favourite.
Photoshop formula was removed because of discontinuity of local contrast.
Formulas are explained here: https://en.wikipedia.org/wiki/Blend_modes
Usage AviSynth:
Softlight() same as SoftLight(0,0) same as SoftLight(mode=0,formula=0)
Usage VapourSynth:
video = core.Argaricolm.Softlight(video) or core.Argaricolm.Softlight(video,mode=0,formula=0)
Download at github
If you use some modes one after another its better to convert color space to RGB before. You can use convertorgbnv & converttoyuvnv functions from my imagesourcenv plugin.
Like this:
ConvertToRGBNV()
Softlight(8)
Softlight(3)
ConvertToYUVNV()
This way modes will not jump like: YUV -> RGB -> YUV -> RGB - YUV.
Argaricolm is offline   Reply With Quote
Old 25th June 2023, 10:29   #2  |  Link
Would not do any harm to post a few Mode before/after example images.
Postimages.org allows to embed images in your post, without needing Postimages.org account
(and dont need to wait for mods approval)
Postimages.org:- https://postimages.org/
Use, "thumbnail" or "image" for forum, modes. [copies url to clipboard, just paste in your post]
EDIT: If you do post images, I'll try remember to delete this post.
Old 25th June 2023, 14:12   #3  |  Link
Selur
Selur's Avatar
@StainlessS: here's an example: https://imgsli.com/MTg4MTEz
script used:
ClearAutoloadDirs()
SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSMASHSource.dll")
Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi")
LoadPlugin("c:\Users\Selur\Desktop\Softlight.dll")
# loading source: G:\TestClips&Co\files\MPEG-4 H.264\Canon 5D RAW.mp4
# color sampling YV12@8, matrix: bt709, scantyp: progressive, luminance scale: limited
LWLibavVideoSource("G:\TestClips&Co\files\MPEG-4 H.264\Canon 5D RAW.mp4",cache=false,format="YUV420P8", prefer_hw=0)
org=last
Softlight(mode=X)
Interleave(org.Subtitle("Original"), last.Subtitle("Softlight(mode=X)"))
# current resolution: 1920x1080
PreFetch(16)
#  output: color sampling YV12@8, matrix: bt709, scantyp: progressive, luminance scale: limited
return last
@Argaricolm: Any plans for a Vapoursynth version?
Any plans to also allow RGB input and high bit depth support?
Cu Selur
Old 25th June 2023, 18:33   #4  |  Link
Cheers Selur, nice comparison method.
Old 25th June 2023, 19:08   #5  |  Link
Argaricolm
Cu Selur
RGB input is easy. I can do it fast.
Vapoursynth - never compiled for it. If much needed I can do it.
For high bit depth I'm not sure. If I will be able to change softlight code for it - then possible.
Old 25th June 2023, 19:36   #6  |  Link
Selur
Selur's Avatar
More supported color spaces are always better, since it give more freedom.
Vapoursynth would be great, since I mainly use Vapoursynth. https://forum.doom9.org/showthread.php?t=182961 might help with supporting both Avisynth and Vapoursynth.
Cu Selur
Old 29th June 2023, 18:43   #7  |  Link
tormento
Acid fr0g
tormento's Avatar
Am I the only one who doesn't understand what it does?
@turment on Telegram
Old 29th June 2023, 23:03   #8  |  Link
Argaricolm
It does this. But is not changing brightness.
Old 30th June 2023, 11:24   #9  |  Link
Frank62
Interesting. Has this something to do with what they did with the colours on "Moby Dick"? Or later with the BluRay version of "French Connection"?
Frank62 is offline   Reply With Quote
Old 1st July 2023, 21:23   #10  |  Link
Argaricolm
Don't know. I'v got an idea to do it with video. Possibly someone got same idea. But it's possible only using CUDA/GPU. Because summing each frame on CPU is very slow.
Old 2nd July 2023, 16:26   #11  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
How are you defining "possible" and "very slow"?
wonkey_monkey is offline   Reply With Quote
Old 3rd July 2023, 20:11   #12  |  Link
Argaricolm
Possible on CPU too. But it will be around some fps. While cuda version 10x more faster.
Old 3rd July 2023, 23:27   #13  |  Link
Any good for plain C version ? [should be ok for 8K+, req slight mods for 16 bit, probably dont need altscan, or crop coords]
double __cdecl PVF_AverageLuma_Planar(const PVideoFrame &src,const int xx,const int yy,const int ww,const int hh,const bool altscan) {
    const int ystep    = (altscan) ? 2:1;
    const int pitch    = src->GetPitch(PLANAR_Y);
    const int ystride  = pitch*ystep;
    const BYTE  *srcp  = src->GetReadPtr(PLANAR_Y)  + (yy * pitch) + xx;
    __int64 acc        = 0;
    unsigned int sum   = 0;
    const int yhit = (altscan) ? (hh +1)>>1 : hh;
    const unsigned int Pixels = (ww * yhit);
    if(ww == 1) {                                                       // Special case for single pixel width
        for(int y=yhit ; --y>=0;) {
            sum += srcp[0];
            srcp+= ystride;
    } else {
        const int eodd = (ww & 0x0F);
        const int wm16 = ww - eodd;
        for(int y=yhit; --y>=0 ;) {
            switch(eodd) {
            case 15:    sum += srcp[wm16+14];
            case 14:    sum += srcp[wm16+13];
            case 13:    sum += srcp[wm16+12];
            case 12:    sum += srcp[wm16+11];
            case 11:    sum += srcp[wm16+10];
            case 10:    sum += srcp[wm16+9];
            case 9:     sum += srcp[wm16+8];
            case 8:     sum += srcp[wm16+7];
            case 7:     sum += srcp[wm16+6];
            case 6:     sum += srcp[wm16+5];
            case 5:     sum += srcp[wm16+4];
            case 4:     sum += srcp[wm16+3];
            case 3:     sum += srcp[wm16+2];
            case 2:     sum += srcp[wm16+1];
            case 1:     sum += srcp[wm16+0];
            case 0: ;
            for(int x=wm16; (x-=16)>=0 ; ) {
                sum +=  (
                        srcp[x+15] +
                        srcp[x+14] +
                        srcp[x+13] +
                        srcp[x+12] +
                        srcp[x+11] +
                        srcp[x+10] +
                        srcp[x+ 9] +
                        srcp[x+ 8] +
                        srcp[x+ 7] +
                        srcp[x+ 6] +
                        srcp[x+ 5] +
                        srcp[x+ 4] +
                        srcp[x+ 3] +
                        srcp[x+ 2] +
                        srcp[x+ 1] +
                        srcp[x+ 0]
            if(sum & 0x80000000) {acc += sum;sum=0;}                    // avoid possiblilty of overflow
            srcp  += ystride;
    acc += sum;
    double dacc = double(acc);
    return dacc / Pixels;
EDIT: From RT_Stats, v2.0 Beta 13 [8 bit CS only].
Not that slow really. Similar method for other colorspace in "PVF_ ... " files.
EDIT: The switch stuff only accounts for ww pixel width, does not take srcp memory alignment stuff into account, so could be improved
to better use compiler vectorization type stuff {probably require additional switch thingy for end cases}.
If always full frame {no coords}, then could take some shortcuts. {Avisynth+ frames LHS always aligned, not so for Avs standard 'in place' cropping}
EDIT: Might be handy, [from here:- https://forum.doom9.org/showthread.p...61#post1935661 ]
Function PitchTortureTest(clip c) { # IanB:- https://forum.doom9.org/showthread.php?p=1628159#post1628159
	c
	A=SelectEvery(4, 0)
	B=SelectEvery(4, 1).AddBorders(0,0,8,0).Crop(0,0,-8,0)
	C=SelectEvery(4, 2).AddBorders(0,0,16,0).Crop(0,0,-16,0)
	D=SelectEvery(4, 3).AddBorders(2,0,22,0).Crop(2,0,-22,0)
	Interleave(A,B,C,D)
Could probably be improved if modified to take cropping granularity of colorspace into account.
EDIT: from OP,
Check intent of -ve method.
From posted link for IanB thingy thread, here:- https://forum.doom9.org/showthread.p...16#post1935616
MyAverage, v2.6+
A simple average filter for Avisynth v2.60 standard colorspaces, only.
Returns a clip where each return frame is a single color average of input frame, same size and colorspace as input.
Does an invert on result if Bool Invert==true.
ColorSpace, YV12, YV16, YV24, YV411, Y8, YUY2, RGB24, RGB32, only.
Return clip Y, U and V, or R, G and B, will be channel averages, unless Invert==True, where channels averages will be inverted.
MyAverage(clip c, Bool "Invert"=false,Bool "TV_YUV"=False,Bool "MyYV24"=False)
    Invert,      Default false == sampled average. Otherwise Inverted average.
    TV_YUV,      Default false, If True(And YUV), then photo negative invert around TV levels mid Y(125.5), rather than 127.5.
    MyYV24,      If true and YV24 (only YV24), then process Y,U,V, together, else by planes.
Returns clip same colorspace and size as input.
        if(invert) {    // invert ?
            if(tvy) {   // tv levels invert ? [ TV levels center is 125.5 not 127.5, ie (16 + 235)/2 ]
                ave = int(-(ave_D - 125.5) + 125.5 + 0.5);      // TV_YUV Y mid = 125.5, invert, and Round
            } else {
                ave = int(ave_D + 0.5) ^ 0xFF;                  // PC_YUV Y mid = 127.5, symmetrical about 127.5 [EDIT: ADDED, or ave = 255 - int(ave_D + 0.5)]
            aveU ^= 0xFF ;
            aveV ^= 0xFF;
        } else {
Also
In this snippet from posted source,
            } else {
            aveU ^= 0xFF ;
            aveV ^= 0xFF;
        } else {
            ave = int(ave_D + 0.5);
        ave = max( min( ave, 255) ,0);
Stuff in BLUE ain't exactly correct, xor with $FF would invert $80 U,V center to $7F,
but avoids problem where source U,V == 0 would invert to $100, we invert to $FF in 8 bit range,
also method adopted will arrive back to original source value if inverted twice.
As it is, it aint quite right but method I chose. Maybe I should invert and clip, there should be no source of $00 anyway.
EDIT: Source $00 equivalent to center - 128, and source $FF equiv to center + 127, ie not symmetrical about center 128.
Old 4th July 2023, 03:45   #14  |  Link
Further to above,
W            = 3 * 1280 # 3840
H            = 3 * 720  # 2160
STATICFRAMES = False
SECONDS      = 5 * 60
FRAMES       = Round(29.97 * SECONDS)
# SECONDS seconds @ 29.97 FPS. STATICFRAMES, If set to false, generate all frames. Default true (one static frame is served)
Colorbars(Width=W,Height=H,pixel_type="YV12",staticframes=STATICFRAMES).Trim(0,-FRAMES)
# Comment one of below out
Return Scriptclip("AverageLuma() return last")                        # Avs+ builtin. Always full frame.
#Return Scriptclip("RT_AverageLuma() return last")                    # RT_Stats, RT_AverageLuma. Used to be faster than AVS 2.60 Standard.
4K : AVS+ AverageLuma : STATICFRAMES = FALSE
c:\Z>avsmeter64 test.avs
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021
AviSynth+ 3.7.3 (r3996, master, x86_64) (3.7.3.0)
Number of frames:                     8991
Length (hh:mm:ss.ms):         00:05:00.000
Frame width:                          3840
Frame height:                         2160
Framerate:                          29.970 (30000/1001)
Colorspace:                           YV12
Audio channels:                          2
Audio bits/sample:                      32 (Float)
Audio sample rate:                   48000
Audio samples:                    14399985
Frames processed:                   8991 (0 - 8990)
FPS (min | max | average):          554.7 | 890.6 | 843.1
Process memory usage (max):         104 MiB
Thread count:                       16
CPU usage (average):                7.9%
Time (elapsed):                     00:00:10.664
4K : RT_AverageLuma : STATICFRAMES = FALSE
Frame width:                          3840
Frame height:                         2160
Colorspace:                           YV12
Audio channels:                          2
FPS (min | max | average):          220.2 | 382.7 | 329.0
Thread count:                       14
CPU usage (average):                8.0%
Time (elapsed):                     00:00:27.328
4K : AVS+ AverageLuma : STATICFRAMES = TRUE
Frame width:                          3840
Frame height:                         2160
Colorspace:                           YV12
Audio channels:                          2
FPS (min | max | average):          2335 | 3244 | 3082
Process memory usage (max):         81 MiB
Thread count:                       16
CPU usage (average):                6.9%
Time (elapsed):                     00:00:02.917
4K : RT_AverageLuma : STATICFRAMES = TRUE
Frame width:                          3840
Frame height:                         2160
Colorspace:                           YV12
Audio channels:                          2
FPS (min | max | average):          511.8 | 859.5 | 801.5
Thread count:                       16
Time (elapsed):                     00:00:11.218
Clearly, Pinterf did some improvements to Avs+ AverageLuma,
Suggest steal some of his code [I will not tell him].
Also note, Scriptclip would slow it quite a bit compared with GetFrame() in plugin.
We did not assign AverageLuma to variable in scriptclip, as that would likely greatly affect results.
However, FPS for the RT_AverageLuma aint so very bad for 4K, and you would likely want pure C version anyway.
EDIT: Numbers above on i7-8700.
[No Prefetch {also Scriptclip single thread}, so I assume fully single core numbers]
EDIT: Yep, Resource meter seems to show single core in use.
Old 13th July 2023, 13:49   #15  |  Link
Selur
Selur's Avatar
A Vapoursynth version would be really nice.
Old 10th September 2023, 14:25   #16  |  Link
Selur
Selur's Avatar
btw. since yuv->rgb is used internally: How about also supporting RGB input?
Old 25th November 2023, 03:36   #17  |  Link
Argaricolm
I'm planning to add vapoursynth, YUV444, RGB support soon.
So far a new release.
Old 25th November 2023, 08:59   #18  |  Link
Selur
Selur's Avatar
Thanks! Looking forward to it!
Old 28th November 2023, 00:42   #19  |  Link
Argaricolm
Added YUV 444 support and VapourSynth support. And a small bugfix.
Old 28th November 2023, 19:28   #20  |  Link
Selur
Selur's Avatar
Nice! Thanks!
Did some quick tests, seems to work fine in Vapoursynth.
About color space support:
Would be cool if you could also add 10, 16, 32bit support, if possible.
(in detail: RGBS, RGBH, RGB48,RGB30, YUV420P10, YUV420P16, YUV420PS, YUV420PH, YUV444PH, YUV444PS, YUV444P10, YUV444P16)
Cu Selur
