Old 3rd October 2023, 16:15   #1  |  Link
DanDare1983
Take an m2ts file and make its own blu-ray folder?
I'd like to to take an m2ts file (not mpls) and put in its own blu-ray folder if possible? I'm sure it's probably easier than I think but I'm looking for a way to do this. I read somewhere that tsmuxer can do this but I always end up with 5min chapters, vbr audio etc. I just want the untouched m2ts with no changes to have its own blu ray folder. Ant help would be appreciated
DanDare1983 is offline   Reply With Quote
Old 4th October 2023, 09:56   #2  |  Link
von Suppé
von Suppé's Avatar
In tsMuxer, the 5min chapters are a set default. In GUI, go to Bluray tab where you'll find radiobuttons for no chapters or custom chapter timestamps.
What do you mean with "ending up with VBR audio"? If you'd refer to setting "Mux VBR" in the General tab, this does not convert CBR audio to VBR audio or vice versa. There's a difference between VBR audio and tsMuxer's VBR muxing. As a sidenote, there are many BD compatible VBR audiostreams.
Originally Posted by DanDare1983 View Post
...but I always end up with 5min chapters, vbr audio etc.
What would "etc." stand for?
