#401 | Link |
Other encoders may add padding (bucket loads of zeros) to acquire required bitrate,
perhaps AV1 dont do that or not as yet implemented. As suggested earlier, ask in appropriate forums. [EDIT: Perhaps AV1 is not yet at a stage where they wanna add unnecessary stuff, perhaps will be added eventually]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 23rd November 2025 at 13:20. |
#403 | Link |
Seems to work ok for me, just updated eac3to and ffmpeg.
#406 | Link |
![]() Join Date: Feb 2005
It is managed by the HDStreamsExtractor code inside MeGUI, like you see in the track names now eac3to inform about the 3 ISO 639 set 2 characters instead the full language names like before.
Then HDStreamsExtractor code can't undestand them and show all like 'english' If you can't modify the code it is better preserve the previous eac3to version 3.54 with no major changes except that. Last edited by tebasuna51; 1st December 2025 at 07:35. Reason: add link |
#407 | Link |
Video damager
@Kurt.noise
1) "svt-av1-psy" in the updated program is not "psy" anymore. Rename it to "svt-av1". 2) Doing "svt-av1-psy" job, the program is passing "crf" as float ["33.0" for example] - that leads to error.
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling Last edited by VoodooFX; 1st December 2025 at 08:13. |
#408 | Link | |
#410 | Link |
why could it be? megui executing, showing splash and ... nothing happened. I need to kill process to stop it.
latest version, doesn't matter 32 or 64. previous the same Last edited by nechto; 16th December 2025 at 23:28. |
#412 | Link |
Solved it (crash) Kurt,
Needs updated Redist files (too old for the compiler used for Avs+, ie old 2019_x64), Here:- https://forum.doom9.org/showthread.p...20#post2026220
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st December 2025 at 10:32. |
#414 | Link | |
Redistributables are well due for update.
#416 | Link |
Just say what the error is or post on some image host eg Postimages.org
#417 | Link |
Cannot use update server http://megui.org/auto/fork/. Reason: Update server is not available
#419 | Link | |
TRJB
Cheers, The REAL Joe |
#420 | Link |
Another request if possible...
I have some material which was originally shot at 23.976FPS, but when released as a PAL retail disc, it was encoded at 25.000FPS, with the audio having been sped-up. I'm re-encoding those discs back to the original 23.976FPS and using the built in default AC3 encoder to slow-down the audio track to remove the "chipmunk" effect. "AutoEncode" lets me do just about everything I want, EXCEPT, the FPS selector is greyed out in the "Adaptive Muxer" and won't let me set it to 23.976, it is set at 25.000, the original source frame rate. Are you able to unlock that so that I can select 23.976 and have the process automatically mux all of the new tracks at the corrected frame rate? ![]() Many thanks! TRJB
| Display Modes | |
