Old 3rd June 2007, 04:07   #101  |  Link
Galileo2000
Originally Posted by FoxDisc View Post
BtCB made it clear where it came from. He used Ed Felten's automatic key assignment proggie on that web page. Wow! It's amazing that he happened to be assigned a valid PK! I wonder what the chances are that it will happen again..... say shortly after the next revocation.
@FoxDisc:
I love this post. I love Ed Felten's automatic key assignment on the web page.
Now it is clear how the key was obtained.
Chances are high the key will be obtained again pretty soon using the same assignment.
Galileo2000 is offline   Reply With Quote
Old 3rd June 2007, 10:09   #102  |  Link
Hyp-X
Originally Posted by awhitehead View Post
If AACS takes off, and there are 30 or 50 licensees, just brute-forcing will no-longer works, esp if my hypothetical Black Box Server does something to rate-limit the number of VUKs it will generate per "customer" per day. If you need to do 30 tries to figure out which device key I use, and I tell you that you can run the test once every 3 days.... By the time you know, I will probably be on a new key.
Not really. Finding the key used out of 30 possible takes 5 tries using divide and conquer.
Also finding the key of Black Box Server is not harder for them than finding which key is used in AnyDVD.
(And rate limiting doesn't necessarily work if one uses a different machine with a different IP for each query.)
Hyp-X is offline   Reply With Quote
Old 10th June 2007, 12:18   #103  |  Link
arnezami
@Boing99 and @FoxDisc: please log on and read your pms.
arnezami is offline   Reply With Quote
Old 11th June 2007, 04:07   #104  |  Link
blutach
Country Member
blutach's Avatar
If he wanted to do that Gilileo2000, he woulda posted it instead of using PMs. The "P" in PM stands for private.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 11th June 2007, 04:17   #105  |  Link
Galileo2000
Regards
OK.
Deleted.
"Gilileo2000" is not my user name.
Regards.
Old 11th June 2007, 14:43   #106  |  Link
blutach
Country Member
blutach's Avatar
My apologies for the typo.
Regards
Les
Old 17th June 2007, 21:18   #107  |  Link
arnezami
Does anybody else find that the AACS LA is a little silent lately?
No response to any of the new events since May 7th.
Old 18th June 2007, 02:36   #108  |  Link
Galileo2000
They are silent, mostly thanks to you and Ed Felten's method of discovering the keys
They are facing a big dilemma along with their customers I think.
They can try full-strength and tremendously increase the manufacturing costs for the formats that are not mature yet and haven't been established into the mainstream.
This way they will cut on profits and might just kill both formats.
And yet they have no guarantee it will be bullet-proof 100%.
Or they can do nothing. And see what happens to the sales figures.
I know I won't be buying their "newly protected" stuff. (unless we need it for testing ).
Just think about the following picture for a second:
- I don't use AnyDVD and don't decrypt the disc.
- I just put my purchased Matrix HD DVD into my purchased Xbox HD DVD to play on my carefully assembled HTPC ( and the video card is HDCP-compliant btw ). PowerDVD flashes nice bitmap which says something about 5 years in federal prison and then puts a dialog saying it cannot play because my driver (the latest ATI driver) is not good enough.
I have no HD DVD or Blu Ray STB boxes.
If I have no tools at my disposal to play HD DVDs I bought, I will return them for the full refund and will never buy them again.
They should thank people for opening the gate.
They got their money.
We got our HD DVD playback and spent money they got.
Old 18th June 2007, 10:44   #109  |  Link
Johhn
Maybe they are waiting until software players have to be "updated" again, and then the press releases on their site dated January 24th 2007, February 15th 2007, and April 16th 2007, will, in true Hollywood fashion, be re-released.
Johhn is offline   Reply With Quote
Old 19th June 2007, 01:21   #110  |  Link
bourke
Sounds plausible - it will probably give them an extra week's worth of security by not telling us when the new keys are due to come out!
That way we wont be able to have a day-0 (or day -1) attack ready ;-)
bourke is offline   Reply With Quote
Old 26th July 2007, 11:15   #111  |  Link
jojo4u
Originally Posted by FTX View Post
Probably only on the 8600/8500 cards because only they come with the VP2 while the 8800 only has VP1
Source: german printed magazine C't 15/07 page 136.
Yes, nvidia is supposed to encrypt the data over the PCIe bus (AES 128 bit engine). This probably only works for VP2. The author speculated wether ATI does not encrypt since the CPU load with encryption is lower. Also nvidia only considers Vista and PCIe for security reasons.
jojo4u is offline   Reply With Quote
Old 30th July 2007, 04:23   #112  |  Link
noclip
I seem to recall some research that looked into the feasibility of obtaining the LA root certificate using some heavyweight cryptanalysis (and 10^7 revoked keys). Is this being looked into? I'm doubtful it's possible, but I imagine it would be be checkmate for the LA if we got our hands on it.
noclip is offline   Reply With Quote
Old 30th July 2007, 06:14   #113  |  Link
abcx
10^7 revoked keys?! Where would we get that?
abcx is offline   Reply With Quote
