17th August 2021, 20:15 | #19241 | Link | |
https://www.windowscentral.com/how-c...ers-windows-10 |
25th August 2021, 07:43 | #19242 | Link | |
1st thing : My Server is EPYC and There is Not any GPU and Not any Graphics Driver Installed 2nd : I Try to Run Main Ripbotexe and it's Showing Warning That Java Is Not Installed, (But I Had Installed Java, Reboot Server,. But No Luck) When i opened Encoding Server then it worked on older version, and last thing I tried to Completely cleaned and Re-install OS (Win Server 2019) But still Same as I mentioned) Latest Version Showing Decoding error, after Video import and Encoding Server not Working) in Older version : Encoding Server Worked But Main Server isn't Working Please Sir, Do Something, if You Need any Donation/Contribution Then I will as much I Can. Also If you are Available to Develop Ripbot With Some More Audio Formats then it Will Be Better . |
28th August 2021, 03:07 | #19243 | Link |
Grumpy Old Man.
This is the end of my "special" RipBot builds & updates :(
For several months now, I have made available very up to date & modified build's of RipBot264.
I have also provided updates on a regular basic. With many different extra filters & options, that made RB that little bit better than the "vanilla" version, which hasn't seen a substantial update in a very long time. If anyone is keeping track of available updates of the components that RB use's, you'd soon realise just how far behind it is I guess I was also hoping that this might prompt Atak to follow suite, and provide updates, and extra's, but it hasn't had that affect, sadly. Don't get me wrong, RB IS still working well, but maybe Atak is now just "resting on his laurel's", and leaving good enough alone. I also hoped that anyone that was happy to download and use my builds would also be happy to provide some feedback, either good or bad, and even the odd thanks, would have been appreciated, but after 100's of downloads over the period I have been providing these builds & updates, not a single comment...NOTHING !!!, which sadden's me. So as of date of posting this, I will no longer provide this service, and I will keep all my hard work to myself, and for my benefit only. So to the many that did download my "stuff", thankyou, but you've only got yourselves to blame for this to be ending, today !!!
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
6th September 2021, 23:45 | #19245 | Link | |
Wall of text
TL;DR version: take it easy, and on behalf of everyone who asked to use your stuff, thank you. • P.S. I don't know about "resting on his laurels" (which frankly no longer sounds as comfortable as it did back in Ancient Greece) but I'd also really welcome more development pouring into RipBot. Although I'm still a devout user, it's getting harder and harder to stay with it without being forced to use other tools—tools I previously didn't even like. E-AC3, up-to-date HDR/HDR10+/DV tools and support, and perhaps a more comprehensive set of degrain filters like SMDegrain (or whatever better alternatives are out there) would really be appreciated. I know it's a lot to ask from a selfless developer who already sacrificed so much of his time into this free software, but that's what you get when you end up with thousands of people depending on your work. Perhaps, if you feel exhausted, you can reconsider going the open source route? I'm sure someone will be willing to pick up the burden like they did with MPC and MPC-HC/MPC-BE. Wouldn't make your own legacy any less meaningful. Quite the opposite, in fact. |
7th September 2021, 01:15 | #19246 | Link | |
Grumpy Old Man.
Good to hear you're OK, now..sure a crazy time, atm. I actually only got asked by about 3 ppl, and with the 100's of downloads, you'd think that at least 1 or 2 would bother to leave a comment, (good or bad). I know that E-AC3 conversion has been asked about for age's, but is just brushed aside, but there are other app's that do the job very & quickly, and all you have to do is mux it in either before or after a RB encode. I generally do video ONLY for 4K stuff, as I need to convert the TrueHD track & subtitles tracks to be compatible with my equipment. Also have started splitting 4K movies into 20 - 30 minute chunks, then importing them in using the Batch feature, that way you don't have to hope your PC (or RB) will reliably encode for a day or so. A little bit more procedure, but a lot less anxiety, I can tell ya !! I'm sure that HDR could be updated fairly easily, there's always someone out there working on that side of things. Anyway, life goes on. Stay well, my friend.
7th September 2021, 07:49 | #19248 | Link |
yes, but there are free luts can be used.
Da vinci resolve use luts and many others. It's color correction (color grading). Sometime, source video have bad colours can be improved. Avisynth use luts too for editing. |
7th September 2021, 13:06 | #19249 | Link | |
Grumpy Old Man.
I doubt that your request will be addressed.
7th September 2021, 14:06 | #19250 | Link | |
ripbot can handle simple color correction like satutation, contrast etc, so, why can't use external lut? |
7th September 2021, 15:32 | #19251 | Link |
Grumpy Old Man.
Well, if you could upload a .cube and whatever else it needs, might be a starting point for this.
7th September 2021, 15:43 | #19252 | Link |
this is the plugin
http://www.avisynth.nl/index.php/AVSCube and this is a zip with 54 luts freeware inside https://www.swisstransfer.com/d/f66b...c-475c345f893d Thanks in advance Example LUT Source NO LUT: Same Source LUT ON: (Clouseau 54.CUBE) Used in Tmpgenc Mastering Works 7 Last edited by darkio; 7th September 2021 at 21:07. Reason: thank a user |
8th September 2021, 11:26 | #19253 | Link | |
Grumpy Old Man.
I am happy to provide this awesome add-on for RipBot264, at your request. It took me and a new friend of mine, kedautinh12, several hours to get it to work within RipBot. And I think this IS a MAJOR game-changer for the app, so thankyou. ENJOY !!!!!
9th September 2021, 04:59 | #19255 | Link | |
Grumpy Old Man.
OR, wait and see if the dev comes up with a suggestion or a revision to the app.
11th September 2021, 12:43 | #19257 | Link | |
Grumpy Old Man.
You'll have to look elsewhere to use this option.
13th September 2021, 10:01 | #19258 | Link |
NVEnc is not x265. They are different H.265 video encoders. NVEnc uses your Nvidia GPU to encode H.265 video, x265 does not. Furthermore, x265 can be controlled in many more different ways than NVEnc, so it is suited much better for segmented encoding, and also it can run in several parallel instances (your GPU encoder chip can be used only by one process at a time). If you don't need segmented encoding, possibly distributed across a network of many PCs encoding different parts of a video, then you may not really need RipBot264...
13th September 2021, 12:38 | #19259 | Link | ||
Grumpy Old Man.
So, not everyone has compatible nVidia GPU's, and also the fact that Distributed Encoding couldn't be used, then there's not really any point !! So even if Atak took the time to implement this, only limited users would take what ever advantage GPU encoding might offer, if the spped of DE isn't there, and let's face it, DE is the most impressive function of any of the main available Encoding apps. The same probably applies to wanting to use NV Decoding. The only process that is probably an option would be to let RipBot do it's complete process, then before deleting the Temp files, to manually re-encode the files generated by RB, using NVEnc, so basically doubling the time taken to get the desired result. Might be able to use the function introduced some time ago to run the "Job finished successfully.cmd" to automate some script / cli. So just repeating what LigH said :- Quote:
18th September 2021, 11:00 | #19260 | Link |
Can't get RipBot EncodingServer to start
Hiya
Updated to latest version 1.21.6 from a much older version. Now I cant get the EncodingServer to start. Where do I start with finding what I have done wrong? All tools seems to be installed (some with green and some with black icons in the list). |
