Old 26th September 2023, 15:51   #1  |  Link
tormento
Acid fr0g
tormento's Avatar
Getnative via AVS functions
I am starting to encode anime to their original resolution as I can save space and remove many bad resizing artifacts.
I use getnative, but it's easily fooled when some filtering is used after the upscaling.
Plus, it needs VS to be used.
I went thru the FFT theory but, guys, I can't really read FFT graphs.
Is it possibile to have an AVS+ version, possibly smarter?
In short terms, I am looking a better way to find anime original resolution. I think it should apply to live action videos too.
@turment on Telegram
Old 27th September 2023, 19:07   #2  |  Link
DTL
You can test: downscale to some test size, upscale to input size, subtract original and upscaled to see how much difference.
Old 27th September 2023, 20:37   #3  |  Link
ChaosKing
That's what getnative does
@GUID You need to test multiple frames. Sometimes credits have a different resolution. In this case you can use a mask to protect the text from upscaling (or downscaling).
Old 28th September 2023, 12:38   #4  |  Link
Kogarou
Well, of course.
Kogarou is offline   Reply With Quote
Old 28th September 2023, 14:47   #5  |  Link
tormento
Acid fr0g
tormento's Avatar
It means at least 540 trials... at least.
Old 28th September 2023, 19:36   #6  |  Link
DTL
You can try iterative - first test 1/2 size. If it too small - test 1/2+1/4=3/4. And divide residual size to 2 to found direction to make next step.
