Old 20th April 2010, 15:32   #21  |  Link
dstln
Person
dstln's Avatar
Originally Posted by Fr4nz View Post
I've encountered a strange problem so I think it's useful to report here. When playing back both "old" and "new" through DXVA (media player is "media player classic (latest rev.)", videocard is an ATI 5770 and drivers are Catalyst 10.3a) this is what I see:
As you can see, there are noticeable macroblocks on the rays, and few other macroblocks around in the picture. These macroblocks, during the playback, goes away for an instant when there is an I-frame, but then they come back.
Maybe it's non-DXVA compliant? Or is it a DVXA-ATI bug?
I have the same card, same drivers and have had the same problems. They broke something and you need to go down to 3.0 levels for it to work properly...
Extremely annoying.
dstln is offline   Reply With Quote
Old 20th April 2010, 16:08   #22  |  Link
burfadel
Try the 10.4 preview driver (its an official unofficial driver, that is, from AMD/ATI but not WHQL or final 10.4). There are also one or two beta drivers floating around which may react differently. The drivers below are all straight from ATI, and are likely more stable than the leaked drivers, some of which are apparently modified.
There is the normal 10.3 driver, which is the current mainstream driver available here (http://game.amd.com/us-en/drivers_ca...indows-7-64bit), the 10.3 OpenGL driver (http://support.amd.com/us/kbarticles...ew-driver.aspx) and the latest preview/hotfix driver, released 15 April: (http://support.amd.com/us/kbarticles...-4-Hotfix.aspx)
Despite it claiming it has only one fix, it is likely to contain many more fixes but is released just to provide a fix for the above issue. Try it out the 10.4 preview driver and see if the problem still occurs
Old 20th April 2010, 16:57   #23  |  Link
Fr4nz
Hi burfadel, thank you for your suggestion.
I've tried catalyst 10.4 preview drivers, but the macroblock-bug remains
So, maybe it is a bug that affects 5xxx serie...
Fr4nz is offline   Reply With Quote
Old 20th April 2010, 18:58   #24  |  Link
Revgen
Only problem I found was with an old version of VLC Player. Which I only use since it's capturing function isn't broken like newer versions. I usually use newer Mplayers anyway.
Other than that, everything works fine.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 20th April 2010, 20:15   #25  |  Link
Warpman
Nvidia 8800gt dxva ->no issues
ffmpeg-mt -> no issues
microsoft DTV decoder-> no issues
(win7 64bit)
Warpman is offline   Reply With Quote
Old 20th April 2010, 22:54   #26  |  Link
dstln
Person
dstln's Avatar
Used to work perfect to 4.1 (aside from an odd issue limited it to 11 refs but I think that's a dxva global issue tbh). Something got broken :P
Honestly I'd send them an e-mail because they may not even know about it. In fact I may also later.
Old 20th April 2010, 23:09   #27  |  Link
DeeGee
DeeGee's Avatar
I'd guess Terry Makedon aka Catalystmaker would be the person to ask.
His Twitter account http://twitter.com/catalystmaker
DeeGee is offline   Reply With Quote
Old 21st April 2010, 03:12   #28  |  Link
ffmpeg
king.dev
why do we need the feature of reference list reordering?
http://quiclive.com
ffmpeg is offline   Reply With Quote
Old 22nd April 2010, 19:11   #29  |  Link
schweinsz
The DiAVC produce identical output with JM bit by bit for the two bitstreams.
schweinsz is offline   Reply With Quote
Old 22nd April 2010, 19:31   #30  |  Link
z0rc
Same issues on DXVA with ATI Radeon HD4650, Catalyst 10.3, MPC HC r1788 both x86 and x64 builds. It looks like an ATI bug. Also I have another one video with same problem, encoded with x264 r1510 and proper DXVA restrictions.
z0rc is offline   Reply With Quote
Old 22nd April 2010, 20:50   #31  |  Link
anyone23
Both files play fine:
1:
Mobility Radeon HD 2400 XT
Catalyst 10.3
Windows XP SP3
MPC-HC
2.
Radeon HD 4870
Catalyst 10.3b Preview
Windows Vista SP2
MPC-HC
But with Catalyst 10.4 Preview I have the same issues on PC 2. (Didn't test PC 1 with 10.4 Preview).
anyone23 is offline   Reply With Quote
Old 22nd April 2010, 20:55   #32  |  Link
G_M_C
I'm curious too. I've searched around on Google, found some explanations referring to better motion vectors because you can reference "better frames", but i also found some articles speaking of multi-view encoding.
G_M_C is offline   Reply With Quote
Old 22nd April 2010, 20:58   #33  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
It's required to make basically any multi-ref H.264 encoder work correctly. This test was just to see if a particularly obnoxious corner case (that we didn't create previously) caused any problems in any decoders.
Old 22nd April 2010, 21:03   #34  |  Link
G_M_C
Ahh, i see. Thx for the info
I'll let up to someone else to go into subject of the meaning of your "obnoxious corner case"
Old 22nd April 2010, 21:12   #35  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Count me out! ^_^
Midzuki is offline   Reply With Quote
Old 23rd April 2010, 05:26   #36  |  Link
radiant chains
Just a few more confirmations of working decoders - both files play fine with all of the following:
Intel 4500mhd DXVA
WDTV v2
Microsoft Xbox 360
radiant chains is offline   Reply With Quote
Old 23rd April 2010, 07:08   #37  |  Link
G_M_C
Looks like all decoders work fine with this
The error displayed by the The Ati, must have been the decoders fault, cause it seems to be the only decoder that displayed errors. Also there are different posts in the MPC-HT thread mentioning errors too. So it might not even be related.
Personally: I've just ordered a HD5770, so i do hope they fix the problem
development, testing, x264
