#25201 | Link |
There have been no relevant changes between 0.78.0-8 and 0.79, only some minor bugfixes in ffmpeg.
#25202 | Link | |
Both of my affected systems have Nvidia GPUs and AMD CPUs. Don't know if you need more information than that. I don't know if Ultra Low Latency mode has issues with the newer versions or if it's something else in the code. I would like to help get this sorted as I don't want to miss out on newer versions. Let me know what info you need. One system is an older AMD Ryzen 5 3600 with 64GBs DDR4 and a 1080 Ti and the other is a AMD Ryzen 9 5950X with 128GBs of DDR4 and a 4090 RTX. Neither system has an issues playing MKV files (mainly remuxes) with older versions pre-0.78.0-10. New version just freezes or skips every 2-3 seconds with frame rate dropping to 21 or 22 fps (average according to MPC VR). madVR has the same behavior but displays the frame rate of the file as 23.976. ![]() ![]() Hmmm...seems it has something to do with HDR. It seems only HDR files are affected with the frame pacing issues. Are you guys testing HDR files, the people who are saying they don't have issues? Last edited by AngelGraves13; 28th March 2024 at 01:25. |
#25205 | Link |
Not sure if it's related but it's out of the ordinary for my system to see two playblack crashes within an hour or so, seemed to be similar to memory overlocking/timing instability with the player crashing during playback. Thinking it's previous latest nightly LAV 0-8 as that's the only thing in the chain that's been updated recently and previously everything has been super stable.
I've reverted to 0.78.0-5, so far no issues. CPU & RAM are at defaults. |
#25206 | Link |
I've been looking at the glitch issue and identified that its limited to HEVC video only, and looking into a fix.
#25207 | Link |
There is a new nightly up at https://files.1f0.de/lavf/nightly/LA...s-0.79.0-1.exe if you could test on your end.
#25208 | Link | |
#25209 | Link |
LAV Filters 0.79.1
LAV Video - Fixed: Resolved a glitch when playing HEVC video A tiny update on top of 0.79 to fix a glitch when playing HEVC videos. For 0.79 check here: https://forum.doom9.org/showthread.p...24#post1999624 As always, report issues and regressions, in as much detail as possible.
#25210 | Link |
Assuming there will be a fixed release soon, could you consider also including the animated webp patches? They were just posted on ffmpeg mailing list, and have gone through review before.
MPC-HC 2.4.3.6 |
#25211 | Link |
I don't generally cherry-pick major features before they land in the tree. Its just a chore to maintain a patchset of 11 patches and then figure out their conflicts later when it gets merged officially.
But you are also too late.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th March 2024 at 18:09. |
#25212 | Link |
LAV Filters 0.79.2
LAV Splitter - Fixed: Buffering media from a high latency source was slower then expected (since 0.79) LAV Audio - Fixed: Bitstream AC3 audio could fallback to PCM on streams that start with a corrupt audio frame (since 0.78) - Fixed: Resolved a memory leak when bitstreaming AC3 Another set of fixes for issues that have been reported recently, which impacted the playback experience. For 0.79 check here: https://forum.doom9.org/showthread.p...24#post1999624 As always, report issues and regressions, in as much detail as possible.
#25216 | Link |
@nevcairiel
Testing x264 lossless compression ratio in another thread I found that on a cpu i5-1035G1 with MPC-HC accelerated hardware decoding of h264 works without problems with "standard" compression But the HW acceleration is not used when playing lossless x264 (done with Ultrafast preset or others). Is that an expected behaviour? Thank you Last edited by Tlen; 18th April 2024 at 20:37. |
#25219 | Link | |
her an image of mpv actually doing that: https://i.postimg.cc/8DLDkRH8/x265lossless.png 355 mb for low motion 4 sec just perfection. btw the same file encoded from the lossless h265 10 bit file in other lossless codex default preset: 8 bit h264 --crf 0 131 mb not fair 8 bit 10 bit h264 from 2017 i can't find newer binaries 264 mb needs --qp 0 btw. h265 has no p frames: "keyint=1:lossless=1" i tried it without keyint=1 but it was not lossless. https://trac.ffmpeg.org/wiki/Encode/...sslessencoding making is very questionable level indeed. btw. nvidia can also decode and encode 4:4:4 lossless too. Last edited by huhn; 18th April 2024 at 23:45. |
#25220 | Link | |
Microsoft is actually in the process of extending the DXVA specification for RExt HEVC profiles, which will likely be available in the next major Windows update and hopefully graphics drivers also supporting it by then (and since its not actually tied to Windows functions, maybe also works on older Windows with newer drivers then). But for H264, there is no further development on that front that i'm aware of.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 19th April 2024 at 09:27. |
